just downloaded and installed garuda . Restart. first thing update with Garuda update. Cannot update....this is the error
libretro-mame: /usr/lib/libretro/mame_libretro.so exists in filesystem (owned by libretro-mame-git)
i have tried following the tutorial you offer.....it didnt work .... but im am not proficient with terminal...... i can follow specific instructions though
╭─[email protected] in ~ as [
] × garuda-inxi
root=UUID=184128f2-1585-459e-bc4d-b49ab568709f rw [email protected]
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: LENOVO product: 81W1 v: IdeaPad 3 15ADA05
serial: Chassis: type: 10 v: IdeaPad 3 15ADA05
serial:
Mobo: LENOVO model: LNVNB161216 v: SDK0R32866WIN
serial: UEFI: LENOVO v: E8CN20WW date: 04/10/2020
ID-1: BAT0 charge: 15.3 Wh (49.0%) condition: 31.2/35.0 Wh (89.1%)
volts: 7.4 min: 7.6 model: LGC L16L2PB3 type: Li-poly serial:
status: discharging cycles: 85
Info: model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2312 high: 2336 min/max: 1400/2600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2325 2: 2255
3: 2333 4: 2336 bogomips: 20761
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 42.0 C
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-5.1:5 chip-ID: 04f2:b6ce class-ID: 0e02 serial:
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08e5 built: 2019
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 14.0.6 DRM 3.48
6.0.2-zen1-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_sof_amd_renoir
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
IF: wlp2s0 state: up mac:
bus-ID: 1-6:4 chip-ID: 0bda:c123 class-ID: e001 serial:
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address:
Local Storage: total: 119.24 GiB used: 15.66 GiB (13.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM128GDHTNG-8310A size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial:
rev: 80070C00 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 31.31 GiB size: 31.31 GiB (100.00%) used: 15.65 GiB
(50.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 9.2 MiB
(3.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 31.31 GiB size: 31.31 GiB (100.00%) used: 15.65 GiB
ID-4: /var/log raw-size: 31.31 GiB size: 31.31 GiB (100.00%) used: 15.65
GiB (50.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-5: /var/tmp raw-size: 31.31 GiB size: 31.31 GiB (100.00%) used: 15.65
ID-1: swap-1 type: zram size: 5.67 GiB used: 506.5 MiB (8.7%)
System Temperatures: cpu: 43.2 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 225 Uptime: 56m wakeups: 1 Memory: 5.67 GiB used: 2.31 GiB
(40.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1808 libs: 510
Garuda (2.6.8-1):
System install date: 2022-12-10
Last full system update: 2022-12-10
╭─[email protected] in ~ as took 2s
╰─λ
