Hello,
I’ve been trying to install Garuda, and it initially installs successfully, but the first thing it does after install is try to do updates. That initial update doesn’t work, and gives a message that says if it keeps happening, to check the forums.
After getting no hits on these searches for the error message, I figured it’s time to ask the experts, so here I am How should I proceed?
https://wiki.archlinux.org/index.php?search=octopi-0.16.2-2+and+alpm_octopi_utils-1.0.2-5+are+in+conflict&title=Special%3ASearch&wprov=acrw1_-1
Here is a copy/paste of the failing update transcript:
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur 648.5 KiB 535 KiB/s 00:01 [------------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
:: Replace dbus-python with extra/python-dbus? [Y/n] y
:: Replace lib32-libva-mesa-driver with multilib/lib32-mesa? [Y/n] y
:: Replace lib32-mesa-vdpau with multilib/lib32-mesa? [Y/n] y
:: Replace libva-mesa-driver with extra/mesa? [Y/n] y
:: Replace mesa-vdpau with extra/mesa? [Y/n] y
:: Replace mlocate with extra/plocate? [Y/n] y
:: Replace p7zip with extra/7zip? [Y/n] y
:: Replace qcoro-qt6 with extra/qcoro? [Y/n] y
:: Replace tracker3 with extra/tinysparql? [Y/n] y
resolving dependencies...
:: octopi-0.16.2-2 and alpm_octopi_utils-1.0.2-5 are in conflict. Remove alpm_octopi_utils? [y/N]
n
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Press enter to exit
And here is the output of garuda-inxi:
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1895a608-4ddb-480b-9956-1884fabeae3f rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: Gigabyte product: Z790 AORUS ELITE X AX v: -CF
serial: N/A
Mobo: Gigabyte model: Z790 AORUS ELITE X AX v: x.x serial: N/A
uuid: 03560274-043c-05cb-3c06-770700080009 UEFI: American Megatrends LLC.
v: F7b date: 12/04/2024
Info: model: Intel Core i7-14700K socket: U3E1 bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 14 level: v3 note: check built: 2022+
microcode: 0x12B
Topology: cpus: 1x cores: 20 mt: 8 tpc: 2 st: 12 threads: 28 smt: enabled
cache: L1: 1.8 MiB desc: d-12x32 KiB, 8x48 KiB; i-8x32 KiB, 12x64 KiB
L2: 28 MiB desc: 8x2 MiB, 3x4 MiB L3: 33 MiB desc: 1x33 MiB
Speed (MHz): avg: 808 high: 1048 min/max: 800/5500:5600:4300
base/boost: 3400/8500 scaling: driver: intel_pstate governor: powersave
volts: 1.0 V ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800
6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 1048 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 25: 800 26: 800 27: 800 28: 800 bogomips: 191385
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte
driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm)
built: 2022+ ports: active: none empty: DP-4,HDMI-A-2,HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:a780 class-ID: 0380
Device-2: NVIDIA AD103 [GeForce RTX 4080] vendor: Micro-Star MSI
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1,DP-2,HDMI-A-1 empty: DP-3 bus-ID: 01:00.0
chip-ID: 10de:2704 class-ID: 0300
Device-3: Logitech HD Webcam C615 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11.2:6
chip-ID: 046d:082c class-ID: 0e02 serial: <filter>
Display: server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 8320x2160 s-dpi: 96 s-size: 2201x572mm (86.65x22.52")
s-diag: 2274mm (89.53")
Monitor-1: DP-1 note: disabled pos: center model: HP VH24 serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 530x300mm (20.87x11.81") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: DP-2 note: disabled pos: right model: Acer XV272U V
serial: <filter> built: 2021 res: 2560x1440 hz: 60 dpi: 108 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
Monitor-3: HDMI-A-1 note: disabled pos: primary,left model: Samsung
serial: <filter> built: 2020 res: 3840x2160 hz: 30 dpi: 103 gamma: 1.2
size: 950x540mm (37.4x21.26") diag: 1093mm (43") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
surfaceless: drv: nvidia x11: drv: zink inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.76
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
memory: 15.62 GiB
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4080 driver: nvidia v: 550.76 device-ID: 10de:2704
surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:a780 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
port: 4000 bus-ID: 04:00.0 chip-ID: 10ec:c852 class-ID: 0280
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
IF: enp5s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 0bda:0852
Local Storage: total: 23.74 TiB used: 5.39 GiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:8 vendor: solidgm model: SSDPFKKW020X7
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 001C temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 338d 10h cycles: 80
read-units: 8,048,193 [4.12 TB] written-units: 12,867,500 [6.58 TB]
ID-2: /dev/nvme1n1 maj-min: 259:11 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 3.64 TiB block-size: physical: 512 B
fw-rev: SN022788 temp: 42.9 C scheme: GPT
SMART: yes health: PASSED on: 2 hrs cycles: 15
read-units: 15,670 [8.02 GB] written-units: 4,003,212 [2.04 TB]
ID-3: /dev/nvme2n1 maj-min: 259:0 model: PCIe SSD size: 1.86 TiB
tech: SSD serial: <filter> fw-rev: ECFM13.3 temp: 28.9 C scheme: GPT
SMART: yes health: PASSED on: 3y 287d 22h cycles: 269
read-units: 52,575,599 [26.9 TB] written-units: 82,410,673 [42.1 TB]
ID-4: /dev/nvme3n1 maj-min: 259:1 model: PCIe SSD size: 1.82 TiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: EGFM15.1 temp: 34.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 329d 3h cycles: 114
read-units: 1,437,274 [735 GB] written-units: 2,374,019 [1.21 TB]
ID-5: /dev/sda maj-min: 8:0 vendor: Seagate model: ST16000NE000-2RW103
family: IronWolf Pro size: 14.55 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: EN02 temp: 30 C
SMART: yes state: enabled health: PASSED on: 1y 241d 16h cycles: 60
read: 8.48 TiB written: 10.38 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 5.39 GiB (0.3%)
fs: btrfs block-size: 4096 B dev: /dev/nvme2n1p2 maj-min: 259:3
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme2n1p1
maj-min: 259:2
ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 5.39 GiB (0.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme2n1p2
maj-min: 259:3
ID-4: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
maj-min: 259:3
ID-5: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
maj-min: 259:3
ID-1: swap-1 type: zram size: 62.56 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 28 dev: /dev/zram0
System Temperatures: cpu: 35.0 C mobo: 28.0 C
Memory: total: 64 GiB available: 62.56 GiB used: 4.34 GiB (6.9%)
Processes: 500 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.98 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1306 libs: 375 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
System install date: 2024-12-26
Last full system update: 2024-12-26
Windows dual boot: Yes
Thank you for the help!!
