Freeze during installation using propietary drivers
Hello everyone!
Im trying to install and try this promising distro, but when I try to install the screen freezes there. It just happens with proprietary drivers, I'm trying to install the gaming edition.
Try with free drivers…?
Try with open source driver.
I too faced this issue..
Later you can install proprietary drivers.
Boot using free drivers, initially. What GPU do you have? System specs will help us help you - the more details, the better.
Welcome :slight_smile: to Garuda Linux.
First, use forum search first then read "Reporting bugs" in wiki, so no pictures needed.
Waiting for user input...
Starting
> Installing video-nvidia-390xx-dkms...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-390xx-dkms/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
downloading chaotic-aur.db...
resolving dependencies...
warning: dependency cycle detected:
warning: eglexternalplatform will be installed before its nvidia-390xx-utils dependency
Packages (28) dxvk-mingw-git-1.8.1.r14.ga520c516-1  egl-wayland-1.1.6-1  eglexternalplatform-1.1-2  haskell-conduit-1.3.4.1-4  haskell-hashable-1.3.1.0-11  haskell-hslogger-1.3.1.0-97  haskell-mono-traversable-1.0.15.1-117  haskell-network-3.1.2.1-39  haskell-network-bsd-2.8.1.0-77  haskell-primitive-0.7.1.0-104  haskell-random-1.2.0-175  haskell-resourcet-1.2.4.2-69  haskell-sandi-0.5-210  haskell-split-0.2.3.4-119  haskell-splitmix-0.1.0.3-80  haskell-unordered-containers-0.2.13.0-50  haskell-utf8-string-1.0.2-24  haskell-vector-0.12.2.0-38  haskell-vector-algorithms-0.8.0.4-39  hedgewars-1.0.0-171  imagemagick-7.0.11.3-1  libxnvctrl-390xx-390.141-1  lib32-nvidia-390xx-utils-390.141-1  lib32-opencl-nvidia-390xx-390.141-1  nvidia-390xx-dkms-390.141-2  nvidia-390xx-settings-390.141-1  nvidia-390xx-utils-390.141-1  opencl-nvidia-390xx-390.141-1
Total Installed Size:  582.14 MiB
Net Upgrade Size:      351.74 MiB
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
(1/2) Creating Timeshift snapshot before upgrade...
E: Commands listed below are not available on this system:
 * rsync
 * /sbin/blkid
 * df
 * mount
 * umount
 * fuser
 * crontab
 * cp
 * rm
 * touch
 * ln
 * sync
Please install required packages and try running TimeShift again
** (process:36891): CRITICAL **: 11:07:42.038: app_lock_remove: assertion 'self != NULL' failed
Unable to run timeshift-autosnap! Please close Timeshift and try again. Script will now exit...
error: failed to commit transaction (failed to run transaction hooks)
Error: pacman failed!
Error: script failed!
Now I'm getting this error when trying to install nvidia drivers using the garuda's hardware manager
Try instead - after rebooting into working snapshot.
sudo pacman -Syu
reboot
then
sudo dkms autoinstall
reboot and test if working nicely.
All found in forum search.
First, use forum search first then read “Reporting bugs” in wiki, so no pictures needed.
Sorry for that, but there was no other way to post that problem, because was during the instalation, no way to copy and paste text. Now I have another problem when I try to install nvidia drivers.
GPU is a 1060 6GB Strix
System Info
System:    Kernel: 5.11.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=3e464092-942b-4881-8173-77d2a274eda8
Desktop: KDE Plasma 5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine:   Type: Desktop Mobo: Micro-Star model: B350 TOMAHAWK (MS-7A34) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 1.M0 date: 01/23/2019
CPU:       Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 81587
Speed: 2703 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz): 1: 2703 2: 2287
3: 3829 4: 3748 5: 2402 6: 2533 7: 3842 8: 3705 9: 3883 10: 3792 11: 3835 12: 3823
Graphics:  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: nouveau v: kernel
bus ID: 1c:00.0 chip ID: 10de:1c03 class ID: 0300
Display: x11 server: X.org 1.20.10 compositor: kwin_x11 driver: loaded: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa
Message: No advanced graphics data found on this system.
Audio:     Device-1: NVIDIA GP106 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 1c:00.1 chip ID: 10de:10f1 class ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 1e:00.3 chip ID: 1022:1457 class ID: 0403
Device-3: Asuscom Network REDRAGON Live Camera type: USB driver: snd-usb-audio,uvcvideo
bus ID: 3-2:2 chip ID: 0735:0269 class ID: 0102 serial: <filter>
Device-4: C-Media Redragon Gaming Headset type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 3-4.4:6 chip ID: 0d8c:0012 class ID: 0300
Sound Server: ALSA v: k5.11.2-zen1-1-zen
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: f000 bus ID: 19:00.0 chip ID: 10ec:8168 class ID: 0200
IF: enp25s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Asuscom Network REDRAGON Live Camera type: USB driver: snd-usb-audio,uvcvideo
Drives:    Local Storage: total: 2.04 TiB used: 24.33 GiB (1.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: CC46 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD G5 BICS4 size: 931.51 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 00WD
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400M8240G size: 223.57 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 61E1
Partition: ID-1: / raw size: 53 GiB size: 53 GiB (100.00%) used: 24.29 GiB (45.8%) fs: btrfs
dev: /dev/sdc5 maj-min: 8:37
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%) used: 27.9 MiB (29.1%) fs: vfat
dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw size: 53 GiB size: 53 GiB (100.00%) used: 24.29 GiB (45.8%) fs: btrfs
ID-4: /var/log raw size: 53 GiB size: 53 GiB (100.00%) used: 24.29 GiB (45.8%) fs: btrfs
ID-5: /var/tmp raw size: 53 GiB size: 53 GiB (100.00%) used: 24.29 GiB (45.8%) fs: btrfs
Swap:      Kernel: swappiness: 10 (default 60) cache pressure: 75 (default 100)
ID-1: swap-1 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
Sensors:   System Temperatures: cpu: 39.4 C mobo: N/A gpu: nouveau temp: 34.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1417
Info:      Processes: 351 Uptime: 56m wakeups: 0 Memory: 15.64 GiB used: 2.82 GiB (18.0%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1859 lib: 552 Shell: fish
v: 3.1.2 running in: konsole inxi: 3.3.01
thread 'main' panicked at 'Unable to create log dir "/home/weimaru/.cache/starship": Os { code: 13, kind: Perm
issionDenied, message: "Permission denied" }!', src/logger.rs:31:35
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
inxi -Fxxxza
Speed: 2319 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz): 1: 2319 2: 2690
3: 3651 4: 3890 5: 2947 6: 3419 7: 3430 8: 2618 9: 3763 10: 3350 11: 3272 12: 2286
Partition: ID-1: / raw size: 53 GiB size: 53 GiB (100.00%) used: 24.3 GiB (45.9%) fs: btrfs dev: /dev/sdc5
maj-min: 8:37
ID-3: /home raw size: 53 GiB size: 53 GiB (100.00%) used: 24.3 GiB (45.9%) fs: btrfs
ID-4: /var/log raw size: 53 GiB size: 53 GiB (100.00%) used: 24.3 GiB (45.9%) fs: btrfs
ID-5: /var/tmp raw size: 53 GiB size: 53 GiB (100.00%) used: 24.3 GiB (45.9%) fs: btrfs
Sensors:   System Temperatures: cpu: 42.0 C mobo: N/A gpu: nouveau temp: 35.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1505
Info:      Processes: 349 Uptime: 1h 04m wakeups: 0 Memory: 15.64 GiB used: 2.96 GiB (19.0%) Init: systemd
And this is what I get from the console using Garuda Hardware manager, something about timeshift.
Console Output
Starting
 core is up to date
downloading extra.db...
downloading community.db...
Packages (30) dxvk-mingw-git-1.8.1.r14.ga520c516-1  egl-wayland-1.1.6-1  eglexternalplatform-1.1-2  haskell-conduit-1.3.4.1-4  haskell-hashable-1.3.1.0-11  haskell-hslogger-1.3.1.0-97  haskell-mono-traversable-1.0.15.1-117  haskell-network-3.1.2.1-39  haskell-network-bsd-2.8.1.0-77  haskell-primitive-0.7.1.0-104  haskell-random-1.2.0-175  haskell-resourcet-1.2.4.2-69  haskell-sandi-0.5-210  haskell-split-0.2.3.4-119  haskell-splitmix-0.1.0.3-80  haskell-unordered-containers-0.2.13.0-50  haskell-utf8-string-1.0.2-24  haskell-vector-0.12.2.0-38  haskell-vector-algorithms-0.8.0.4-39  hedgewars-1.0.0-171  hypnotix-1.5-1  imagemagick-7.0.11.3-1  libxnvctrl-390xx-390.141-1  zeroc-ice-3.7.5-1  lib32-nvidia-390xx-utils-390.141-1  lib32-opencl-nvidia-390xx-390.141-1  nvidia-390xx-dkms-390.141-2  nvidia-390xx-settings-390.141-1  nvidia-390xx-utils-390.141-1  opencl-nvidia-390xx-390.141-1
Total Download Size:     9.59 MiB
Total Installed Size:  623.29 MiB
Net Upgrade Size:      351.75 MiB
:: Retrieving packages...
downloading zeroc-ice-3.7.5-1-x86_64.pkg.tar.zst...
downloading hypnotix-1.5-1-any.pkg.tar.zst...
checking keyring...
 * rsync
 * /sbin/blkid
 * df
 * mount
 * umount
 * fuser
 * crontab
 * cp
 * rm
 * touch
 * ln
 * sync
** (process:90142): CRITICAL **: 11:49:24.499: app_lock_remove: assertion 'self != NULL' failed
Try rebooting from a working snapshot. Then
sudo pacman -Syu
reboot
then
I posted this earlier, to help you. Many may post, please read your own thread thoroughly.
I was about to try that but for no reason my DE stop working and now I have to reinstall Garuda.
I will try to install with open source, update, reboot and do sudo dkms autoinstall. and see what happens.
Please keep us informed.
For future reference,
The error there should be quite clear.
Egg on my face indicates learning has taken place, Senpai :rofl: (should have clocked that)
Thank you. :heart:
Edit for below - I still didn't clock it, so useful for me also, J. :slightly_smiling_face: Helpers learn too.
Heh, the comment wasn't aimed at you. :wink:
Thanks Fingers, seems like it worked finally!
Summary
Sun Mar  7 14:44:27 2021
| NVIDIA-SMI 390.141                Driver Version: 390.141                   |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 106...  Off  | 00000000:1C:00.0  On |                  N/A |
|  0%   41C    P8     7W / 120W |    483MiB /  6075MiB |      3%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0       647      G   /usr/lib/Xorg                                207MiB |
|    0      2434      G   /usr/bin/kwin_x11                             62MiB |
|    0      2539      G   /usr/bin/plasmashell                          79MiB |
|    0      2564      G   /usr/bin/latte-dock                           40MiB |
|    0      5028      G   ...AAAAAAAAAAAAAAgAAAAAAAAA --shared-files    91MiB |
this should mean that its working correctly right? nvidia-settings is good too
Cool - now enjoy! :slightly_smiling_face:
Sounds kind of like a nickname from your old “Mob” days. Like “No Nose” or "Greasy Thumb”.
:rofl:
Shhhh! :wink:
Question: Why are you installing the 390xx drivers on a GPU that is supported by the 460xx drivers?
