I think since 3 Weeks I get a really annoying Stuttering and FPS Drops while Gaming after about 30min
First I thought it has something to do with overheating but the temps doesn’t indicate this.
Restarting the game resets that problem.
For solving the problem I tried
- Disabling Steamoverlay
- Disabling V-Sync
- Set Fan Speed higher
- switching Proton Version
- Updating the System
Does anyone have similar problems or solutions ?
Any tips appreciated.
Kernel: 6.11.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
root=UUID=7aa41a81-46e5-4937-aadc-e9b51305eda9 rw rootflags=subvol=@ quiet quiet
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASRock model: B550M-HDV serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends LLC. v: P3.30 date: 09/28/2023
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check
built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 0
microcode: 0xA20102B
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4364 min/max: 550/4663 boost: enabled scaling: driver: amd-pstate-epp
governor: performance cores: 1: 4364 2: 4364 3: 4364 4: 4364 5: 4364 6: 4364 7: 4364 8: 4364
9: 4364 10: 4364 11: 4364 12: 4364 13: 4364 14: 4364 15: 4364 16: 4364 bogomips: 108589
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M
XT] vendor: Tul / PowerColor Red Devil driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-2,DP-3 empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 07:00.0 chip-ID: 1002:73df
Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4 compositor: kwin_wayland
gpu: amdgpu d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-2 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-3 pos: primary,top-left res: 2560x1440 size: N/A modes: N/A
gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi navi22 LLVM 18.1.8 DRM 3.59
6.11.9-zen1-1-zen) device-ID: 1002:73df memory: 11.72 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 9 device: 0 type: discrete-gpu name: AMD Radeon RX 6700 XT
(RADV NAVI22) driver: mesa radv v: 24.2.7-arch1.1 device-ID: 1002:73df
surfaces: xcb,xlib,wayland device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256 bits)
driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.4
chip-ID: 1022:1487 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:4 chip-ID: 0c76:161e class-ID: 0300
API: ALSA v: k6.11.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: ASRock
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-4:3 chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10 status: discoverable: no
pairing: no
Local Storage: total: 2.73 TiB used: 1.19 TiB (43.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: BarraCuda Q5 ZP1000CV30001
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: SU5SS001 temp: 40.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
fw-rev: 0001
ID-1: / raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 313.13 GiB (33.6%) fs: btrfs
ID-2: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 313.13 GiB (33.6%) fs: btrfs
ID-3: /var/log raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 313.13 GiB (33.6%)
fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /var/tmp raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 313.13 GiB (33.6%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 3.38 GiB (21.7%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 55.0 C mem: 56.0 C
Memory: total: 16 GiB available: 15.54 GiB used: 6.11 GiB (39.3%)
Processes: 381 Power: uptime: 6h 49m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 6.19 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 256
Packages: pm: pacman pkgs: 1629 libs: 500 tools: octopi,paru Compilers: gcc: 14.2.1
Client: shell wrapper v: 5.2.37-release inxi: 3.3.36
System install date: 2024-05-17
Last full system update: 2024-11-23
Is partially upgraded: Yes
