Hello all,
I'm Lava and I'm quite new to Linux, although I'd been wanting to switch for awhile.
I recently got a convertible HP ENVY x360, and I installed Garuda alongside windows 11 because it looked the prettiest out of anything I'd seen. I really, really like it, but a few weird things are happening. The keyboard is designed to turn off if:
- You fold the laptop back on itself (specifically, past 180 degrees) for use like a tablet, or
- You rotate it enough so that it's sideways or upside-down.
In windows, when the keyboard turns off, the orientation of the display and the input flips to accommodate the orientation of the machine. In Garuda, however, that doesn't happen, and instead both Wifi and Bluetooth become disabled (not disconnected, disabled.) When you return the laptop to its original position, the keyboard comes back on and Bluetooth and Wifi are restored. I can start either connection while the keyboard is off, but they just disable again after a few seconds. All I can figure is that whatever sensors would normally control display and input orientation are controlling Wifi and Bluetooth instead, and I have no idea why. Can anyone tell me what's happening, or even give me a place to start my investigations?
Thanks!
garuda -inxi:
Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=949f1291-843a-49d5-a0cf-30cb83ca910e rw [email protected]
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Convertible System: HP product: HP ENVY x360 Convertible 15-ed1xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
Mobo: HP model: 8825 v: 48.42 serial: <superuser required> UEFI: Insyde
v: F.21 date: 12/13/2021
ID-1: BAT1 charge: 26.5 Wh (53.9%) condition: 49.2/51.0 Wh (96.4%)
volts: 12.3 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Charging
Device-1: hid-0018:04F3:2B11.0001-battery model: ELAN2514:00 04F3:2B11
serial: N/A charge: N/A status: N/A
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x9A
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 594 high: 882 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 440 2: 472 3: 537 4: 564
5: 882 6: 435 7: 854 8: 570 bogomips: 44851
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
Device-2: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 3-5:2 chip-ID: 04f2:b748 class-ID: fe01 serial: <filter>
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.3.6
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.46 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0aaa class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 238.47 GiB used: 12.52 GiB (5.2%)
model: MZVLQ256HAJD-000H1 size: 238.47 GiB block-size: physical: 512 B
rev: HPS4NFXV temp: 33.9 C scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
used: 12.45 GiB (25.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 65.2 MiB (25.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-4: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.38 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: 10.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 257 Uptime: 40m wakeups: 2212 Memory: 15.38 GiB
used: 3.24 GiB (21.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1409 lib: 327 Shell: fish
Garuda (2.5.4-2):
System install date: 2022-02-16
Last full system update: 2022-02-18
