I mentioned this before, and the issue persists on a brand new setup so I’ll report it again.
By default, Firedragon has rounded corners. The problem is that it also has big paddings that reduce the visible space considerably. Furthermore, you can no longer select the right scrollbar by moving the mouse to the right, you need to move a few pixels to the left to pick up the scrollbar!
That padding is wasted real-estate; and with inflation, every inch of real-estate is valuable. (seriously, a dozen Chinese people could live in that wasted space)
Inxi
Kernel: 6.9.2-1-cachyos arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=b3842975-a07f-4abe-a1f6-66b8fcf79638 rw rootflags=subvol=@
quiet loglevel=3 intel_iommu=on iommu=pt isolcpus=2-7 nohz_full=2-7
rcu_nocbs=2-7 transparent_hugepage=never rd.driver.pre=vfio-pci vfio
pci.ids=10de:1f15,10de:10f9,10de:1ada,10de:1adb
pcie_acs_override=downstream,multifunction ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: Acer product: Predator PH315-53 v: V2.04
Mobo: CML model: QX50_CMS v: V2.04 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 2.04
date: 08/20/2021
ID-1: BAT1 charge: 40.7 Wh (100.0%) condition: 40.7/58.8 Wh (69.2%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 841 high: 900 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 900 10: 900 11: 800 12: 900 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 550.78
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none off: HDMI-A-1 empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x82ed built: 2018
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.0-arch1.1.1
device-ID: 8086:9bc4 memory: 7.54 GiB unified: yes
API: Vulkan v: 1.3.285 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.1.0-arch1.1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 550.78
device-ID: 10de:1f15 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.0-arch1.1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.9.2-1-cachyos status: kernel-api tools: N/A
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel
Device-2: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI
bus-ID: 08:00.0 chip-ID: 10ec:2600 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 6.83 TiB used: 873.87 GiB (12.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 74.8 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 45.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
model: WD40NDZW-11A8JS1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1023 scheme: GPT
ID-1: / raw-size: 781.15 GiB size: 781.15 GiB (100.00%)
used: 198.58 GiB (25.4%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:3
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p3 maj-min: 259:5
ID-3: /home raw-size: 781.15 GiB size: 781.15 GiB (100.00%)
ID-4: /var/log raw-size: 781.15 GiB size: 781.15 GiB (100.00%)
ID-5: /var/tmp raw-size: 781.15 GiB size: 781.15 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.45 GiB used: 52 MiB (0.3%) priority: 100
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:4
System Temperatures: cpu: 61.0 C pch: 84.0 C mobo: N/A
Memory: total: 16 GiB available: 15.45 GiB used: 4.84 GiB (31.3%)
Processes: 375 Power: uptime: 5h 30m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1637 libs: 445 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date: 2024-05-30
Last full system update: 2024-05-30 ↻
