I have been using Garuda Linux as a daily driver for college work on my laptop and it has been amazing. However, ever since FireDragon has updated to being based on Floorp, it has really lost performance on my machines. I’ve done speedometer 3.0 tests for both Floorp and FireDragon on both my desktop (running Manjaro) and laptop and the results are:
Desktop (Manjaro)
Browser
Speedometer Test Result
Floorp
11.1
FireDragon
5.62
Laptop (Garuda)
Browser
Floorp
4.24
FireDragon
1.88
There is a very significant difference here, and one that I’ve noticed through personal use. Browsing the web used to be awesome on the old FireDragon based on LibreWolf, but now it feels so sluggish. I’ve been using Floorp as a result, which feels a lot faster, but I’m missing all those awesome FireDragon customizations and features.
Basically, my question is: why is this performance difference is happening? And how it can be fixed?
First of all, it is essential to carry out these tests with a new, clean profile. Also, no other programs should be running at the same time and you should not do anything on the computer during the test, but leave it completely alone.
Here are my test outputs, which I carried out under the above premises:
Browser
Result
Ungoogled Chromium
12.4
Librewolf
11.3
Floorp
9.07
Firefox-ESR
8.95
Firedragon
4.44
The differences are probably due to the adjustments made in the individual browsers. The test results are influenced by many things.
FGD
23 March 2024 14:12
3
This is the 1st time we get this feedback. It would be very interesting to pinpoint what’s causing this.
Follow the troubleshooting steps as well as tips to identify the config settings that may cause the issue, and plz let us know what your findings are so we can look into possibly adjusting this issue, providing it won’t cause unacceptable downsides elsewhere.
Also plz post your garuda-inxi of all those machines, in case it may be related to some hardware or specific installation situation.
I don’t like what I’m seeing. Are you saying FD is also slower your machine?
Here’s the Manjaro inxi -F, I’ll post the Garuda one from my laptop in a moment.
Manjaro Inxi
Host: REDMOND Kernel: 6.1.80-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.27.11 Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: X570 Steel Legend WiFi ax
serial: <superuser required> UEFI: American Megatrends v: P4.10
date: 10/19/2022
Info: 6-core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP cache: L2: 3 MiB
Speed (MHz): avg: 2473 min/max: 2200/4208 cores: 1: 2309 2: 3505 3: 2468
4: 2200 5: 2195 6: 2196 7: 3084 8: 2531 9: 2655 10: 2195 11: 2241 12: 2099
Device-1: NVIDIA GM206 [GeForce GTX 950] driver: nouveau v: kernel
Device-2: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
driver: amdgpu v: kernel
Display: x11 server: X.Org v: 21.1.11 driver: X:
loaded: amdgpu,modesetting unloaded: radeon,vesa dri: radeonsi,nouveau
gpu: amdgpu resolution: 1: 1600x1200~60Hz 2: 1680x1050~60Hz
API: EGL v: 1.5 drivers: nouveau,radeonsi,swrast
platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.3 vendor: amd mesa v: 24.0.2-manjaro1.1
renderer: AMD Radeon RX 6700 XT (radeonsi navi22 LLVM 16.0.6 DRM 3.49
6.1.80-1-MANJARO)
API: Vulkan v: 1.3.279 drivers: radv surfaces: xcb,xlib
Device-1: NVIDIA GM206 High Definition Audio driver: snd_hda_intel
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
Device-3: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-4: HP HyperX QuadCast S driver: hid-generic,snd-usb-audio,usbhid
type: USB
API: ALSA v: k6.1.80-1-MANJARO status: kernel-api
Server-1: PipeWire v: 1.0.3 status: active
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
IF: wlp6s0 state: up mac: 38:fc:98:25:ae:3b
Device-2: Intel I211 Gigabit Network driver: igb
IF: enp8s0 state: down mac: 9c:6b:00:13:bb:b2
IF-ID-1: virbr0 state: down mac: 52:54:00:c5:81:ad
Device-1: Intel AX200 Bluetooth driver: btusb type: USB
Report: btmgmt ID: hci0 state: up address: 38:FC:98:25:AE:3F bt-v: 5.2
Local Storage: total: 2.98 TiB used: 1.19 TiB (39.8%)
ID-1: /dev/nvme0n1 vendor: TeamGroup model: TM8FP6001T size: 953.87 GiB
ID-2: /dev/sda vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB
ID-3: /dev/sdb vendor: Samsung model: SSD 750 EVO 250GB size: 232.89 GiB
ID-1: / size: 227.88 GiB used: 175.13 GiB (76.9%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/sdb1
ID-1: swap-1 type: file size: 8 GiB used: 9 MiB (0.1%) file: /swapfile
System Temperatures: cpu: 53.0 C mobo: N/A
GPU: device: amdgpu temp: 48.0 C fan: 0 device: nouveau temp: 47.0 C
fan: 0
Memory: total: 16 GiB available: 15.54 GiB used: 4.24 GiB (27.3%)
Processes: 322 Uptime: 45m Shell: Zsh inxi: 3.3.33
I wouldn´t say FD is slowering my machine but FD is running slower than the other browsers on my machine.
If the differences are not really noticeable, I don’t pay attention to whether a browser needs 100ms more or less to load a page. So this is not a problem for me. I just found it interesting and that’s why I posted my results.
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-zen
root=UUID=895a4f96-fcdf-4b10-83d1-09ac126c3917 rw quiet loglevel=3
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: ASUSTeK model: TUF B450-PLUS GAMING v: Rev X.0x
BIOS: American Megatrends v: 4401 date: 09/04/2023
Info: model: AMD Ryzen 5 2600 socket: AM4 bits: 64 type: MT MCP arch: Zen+
gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1914 high: 3400 min/max: 1550/3400 boost: enabled
base/boost: 3400/3900 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 1550 2: 3001 3: 1550 4: 1550
5: 1550 6: 1378 7: 2800 8: 3400 9: 1550 10: 1550 11: 1550 12: 1550
bogomips: 81599
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASUSTeK
active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1 bus-ID: 0b:00.0
chip-ID: 1002:73ff class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: Samsung serial: <filter> built: 2019
res: 3840x2160 dpi: 103 gamma: 1.2 size: 1872x1053mm (73.7x41.46")
diag: 1093mm (43") ratio: 16:9 modes: max: 3840x2160 min: 720x400
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 17.0.6 DRM 3.57 6.8.1-zen1-1-zen) device-ID: 1002:73ff
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 24.0.3-arch1.2
device-ID: 1002:73ff surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0d:00.3
Device-3: Razer USA Kraken Tournament Edition
lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 1532:0520 class-ID: 0300
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
Local Storage: total: 1.96 TiB used: 124.87 GiB (6.2%)
fw-rev: 2B2QEXM7 temp: 40.9 C scheme: MBR
SMART: yes health: PASSED on: 10d 20h cycles: 712
read-units: 5,312,354 [2.71 TB] written-units: 5,329,466 [2.72 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 2B6Q temp: 21 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 112d 2h cycles: 1172
written: 2.11 TiB
model: WD1600BEKT-00PVMT0 family: Scorpio Black size: 149.05 GiB block-size:
physical: 512 B logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 1A01 temp: 24 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 12d 1h cycles: 3079
Old-Age: UDMA CRC errors: 668 alert: Bad cable/connection?
model: WD5000AAKX-00U6AA0 family: Blue size: 465.76 GiB block-size:
physical: 512 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: N/A
serial: <filter> fw-rev: 1H15 temp: 29 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 117d 20h cycles: 357
ID-1: / raw-size: 50 GiB size: 48.66 GiB (97.33%) used: 17.7 GiB (36.4%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:3
ID-2: /home raw-size: 350 GiB size: 343.44 GiB (98.13%)
used: 107.16 GiB (31.2%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 41.5 C mobo: 18.0 C gpu: amdgpu temp: 37.0 C
mem: 34.0 C
Fan Speeds (rpm): cpu: 909 fan-2: 934 fan-3: 677 fan-4: 786 fan-6: 0
gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.23 gpu: amdgpu watts: 4.00
Memory: total: 16 GiB available: 15.53 GiB used: 3.27 GiB (21.1%)
Processes: 301 Power: uptime: 1h 29m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1577 libs: 504 tools: paru,yay Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: terminator inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-01-16
Last full system update: 2024-03-23 ↻
Relevant software: NetworkManager dracut
Here is my laptop’s garuda-inxi:
root=UUID=347babde-1b23-4ce3-93e7-fcab8c6a103d rw rootflags=subvol=@
intremap=nosid usbcore.autosuspend=-1 rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3
Type: Laptop System: HP product: HP Laptop 15-dy2xxx v: N/A
Mobo: HP model: 87FE v: 57.25 serial: <superuser required>
part-nu: 6K7X6UA#ABA uuid: <superuser required> UEFI: AMI v: F.31
date: 03/25/2023
ID-1: BAT0 charge: 39.2 Wh (100.0%) condition: 39.2/41.0 Wh (95.6%)
volts: 12.9 min: 11.4 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 175
Info: model: 11th Gen Intel Core i3-1115G4 bits: 64 type: MT MCP
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
microcode: 0x36
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 2.5 MiB desc: 2x1.2 MiB
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 952 high: 1272 min/max: 400/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 1272 2: 748 3: 572
4: 1216 bogomips: 23961
Device-1: Intel Tiger Lake-LP GT2 [UHD Graphics G4] vendor: Hewlett-Packard
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a78 class-ID: 0300
Device-2: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2
chip-ID: 30c9:0013 class-ID: 0e02 serial: <filter>
Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 338x190mm (13.31x7.48")
s-diag: 388mm (15.27")
Monitor-1: eDP-1 model: AU Optronics 0x20ec built: 2018 res: 1280x720
hz: 60 dpi: 95 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT2)
device-ID: 8086:9a78 memory: 7.23 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics (TGL GT2) driver: mesa intel v: 24.0.3-arch1.1
device-ID: 8086:9a78 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.1 (LLVM
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: 3000 bus-ID: 0000:01:00.0 chip-ID: 10ec:c822 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 0bda:b00c
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 238.47 GiB used: 91.71 GiB (38.5%)
model: MZVLQ256HBJD-00BH1 size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS1NFAV temp: 33.9 C scheme: GPT
used: 91.71 GiB (38.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.41 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Memory: total: 8 GiB note: est. available: 7.41 GiB used: 4.27 GiB (57.6%)
Processes: 241 Power: uptime: 11h 46m states: freeze,mem,disk
suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 2.95 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1714 libs: 423 tools: octopi,pamac,paru,yay
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-07-05
Last full system update: 2024-03-22
Failed units: mnt-H.mount iptsd.service
I followed the troubleshooting steps, and after renaming the firedragon.cfg and firedragon-overrides.cfg files, I still get the same results from Speedometer. Is there anything else FireDragon changes besides these files?
Patches
It’s certainly interesting to see these numbers. We can do some test builds to find out what influences these numbers I guess while Librewolf scores higher, it still feels slower on my system.
I think I figured out the issue, and I think it’s Dark Reader. Floorp does not come with Dark Reader by default, and FireDragon does. Dark Reader seems to cause webpages to load significantly slower.
I tested it against Floorp as well as Mercury, just because I think I might use Mercury for my laptop in the future since it is a $300 HP laptop and doesn’t have crazy specs. Garuda still runs perfectly!
Speedometer 3.0 Tests
Without Dark Reader
With Dark Reader
FireDragon
11.0
5.65
Floorp
8.46
5.03
Mercury
14.1
7.86
(Note: tests were done on Manjaro on my desktop, because my laptop is slower)
So what we can infer is that FireDragon runs significantly slower out of the box than other browsers because of Dark Reader being included by default. When I did my initial tests, it was each browser in their out of the box state.
However, FireDragon runs considerably faster than Floorp without Dark Reader. I think it would be a good call to remove Dark Reader from being default on FireDragon, because new users may not know about this significant performance difference (like me for the longest time) and say FireDragon is slow, when it’s actually a very fast Firefox fork.
FGD
23 March 2024 21:22
10
That’s how it should be done to begin with, good test.
It still feels faster with DarkReader on my machines, but we will certainly keep that in mind and see what can be done.
Tnx a lot!
system
Closed
25 March 2024 21:22
11
Colin
25 March 2024 22:05
13
I was going to post this here but I was 29 minutes too late
I removed Dark Reader from Floorp and returned to the add-on I used to use, namely Dark Background and Light Text . It may be a bit old but it’s stable and works well, it’s open source, and it’s a lot faster than Dark Reader.
If anyone’s looking for a dark mode for a Firefox based browser it’s well worth a try.
elite
28 March 2024 04:43
16
From a quick little look it seems to be when it is enabled you get the slower result when you turn off dark mode for the speedmeter website the speed result is higher so in all likely when it is flipping through the tests its re rendering the dark mode causing the lower score but I didn’t test it with it fully removed.
Kayo
Closed
4 April 2024 04:43
17
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
