I think Garuda Whoogle search is slower than google , some times it takes more time (6-8 sec) to search a keyword . i have started using firedragon instead of firefox firedragon-vs-firefox , every thing works good ... it eat less ram than firefox ,
but the problem happened with garuda search.. and sometimes it shows that refuse cookie error "(but i use default cookie configuration of firedragon)
what that mean and what to do to fix this??
╭─sshanku@shanku in ~
╰─λ garuda-inxi
Kernel: 5.16.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=1c542029-1def-474b-9a7b-a27875482987 rw rootflags=subvol=@
resume=UUID=388ac47a-43b6-4dde-80f6-a8b43e1c5164 loglevel=3
Desktop: KDE Plasma 5.24.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop System: Gigabyte product: H110M-S2 v: N/A
Mobo: Gigabyte model: H110M-S2-CF v: x.x serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: F21 date: 06/09/2017
Info: model: Intel Core i3-6100 bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 29598
Type: l1tf
Device-1: Intel HD Graphics 530 vendor: Gigabyte driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
Device-2: NVIDIA GT218 [GeForce G210] driver: nouveau v: kernel
bus-ID: 01:00.0 chip-ID: 10de:0a60 class-ID: 0300
loaded: modesetting display-ID: :0 screens: 1
s-diag: 414mm (16.3")
Monitor-1: DP-1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
diag: 470mm (18.5")
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.3.6
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-2: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
Sound Server-1: ALSA v: k5.16.10-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
Local Storage: total: 1.36 TiB used: 91.53 GiB (6.6%)
model: WD10EZEX-60WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500413AS
type: HDD rpm: 7200 serial: <filter> rev: JC4B scheme: MBR
ID-1: / raw-size: 127.93 GiB size: 127.93 GiB (100.00%)
used: 52.33 GiB (40.9%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-2: /home raw-size: 147.46 GiB size: 147.46 GiB (100.00%)
used: 39.2 GiB (26.6%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-3: /var/log raw-size: 127.93 GiB size: 127.93 GiB (100.00%)
ID-4: /var/tmp raw-size: 127.93 GiB size: 127.93 GiB (100.00%)
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18
ID-2: swap-2 type: zram size: 7.65 GiB used: 176.5 MiB (2.3%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 39.0 C
Processes: 264 Uptime: 1h 14m wakeups: 0 Memory: 7.65 GiB
used: 5.31 GiB (69.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1651 lib: 377 Shell: fish
Garuda (2.5.5-1):
System install date: 2021-12-28
Last full system update: 2022-02-20
Failed units: bluetooth-autoconnect.service shadow.service
type or paste code here
and after reload the search whoogle turns into white theme
