Recently I tried transferring files to a USB pendrive. They are movies, 5 to 10 files of about 1.5GB each
I tried copying them with the Dolphin GUI, with rsync, and with rclone and every time, there’s a spurt of progress at the beginning, but when it reaches 90% to 100% it stops, BUT:
In dolphin, the progress notification either doesn’t go for as long as I waited, or it goes after like 10 minutes
(if the notification doesn’t go, the transfer also doesn’t complete. If I cancel it at 100% the files do not show up on the pendrive)
Rclone shows a steady transfer speed (around 3 MiB/s) even after reaching 100%, which seems nonsensical.
This AskUbuntu post says that this an issue of Linux itself. When a file is copied, the progress it shows is only for copying to a buffer. After it says the transfer is done, it does the actual copy in the background. If I request to eject the pendrive, it waits for the actual transfer to finish.
How have I never heard of this mechanism before?? How do I know when to eject the pendrive? Wait for the 100% notification to go?
Is there a way to show the actual speed of the copy from the buffer to the pendrive, and to know when it will finish?
As the AskUbuntu post said, this issue pops up when copying large files to pendrives because they have lower write speeds.
I found this post on the garuda forum but it only mentioned changing the buffer size or something. Not about showing the progress.
Apologies if I’ve misunderstood the way copying works. Any help will be appreciated. Thank you!
garuda-inxi :
root=UUID=aeb3c7e0-45af-4344-ba3f-05339ad86d76 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: Gigabyte model: B550M DS3H AC v: x.x
Megatrends LLC. v: F15 date: 07/29/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3719 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3593
3: 3593 4: 3800 5: 3800 6: 3800 7: 3591 8: 3800 9: 3800 10: 3800 11: 3637
12: 3800 13: 3800 14: 3639 15: 3591 16: 3664 bogomips: 121363
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: ASUSTeK
driver: nvidia v: 555.58 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none off: DP-1,DVI-D-1 empty: HDMI-A-1
bus-ID: 06:00.0 chip-ID: 10de:2187 class-ID: 0300
Device-2: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:2 chip-ID: 17ef:4831
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
s-diag: 1252mm (49.29")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: left model: Dell P2719H
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: DVI-D-1 mapped: DVI-D-0 note: disabled pos: primary,right
model: Dell P2719H serial: <filter> built: 2020 res: 1920x1080 hz: 60
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650
SUPER/PCIe/SSE2 memory: 3.91 GiB
API: Vulkan v: 1.3.204 layers: 20 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 SUPER driver: nvidia v: 555.58 device-ID: 10de:2187
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 17.0.6 256
bits) driver: mesa llvmpipe v: 24.1.2-arch1.1 (LLVM 17.0.6)
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
bus-ID: 06:00.1 chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0aa7
Device-1: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 1948792416 chunk-size: N/A
Components: Online: N/A Spare:
1: sda3 maj-min: 8:3 size: 1.81 TiB state: S
Local Storage: total: 4.1 TiB used: 379.98 GiB (9.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 38.9 C scheme: GPT
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: MBR
fw-rev: 0A80 scheme: GPT
used: 379.18 GiB (79.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.52 GiB used: 152.8 MiB (1.0%)
System Temperatures: cpu: 58.5 C mobo: 34.0 C gpu: nvidia temp: 41 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 27%
Memory: total: 16 GiB available: 15.52 GiB used: 6.63 GiB (42.7%)
Processes: 414 Power: uptime: 1h 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: 2545 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr
pkgs: 0 pm: pacman pkgs: 2544 libs: 531 tools: gnome-software, octopi,
pamac, paru, yay pm: flatpak pkgs: 1 Compilers: clang: 17.0.6 gcc: 14.1.1
alt: 13 Shell: garuda-inxi default: Zsh v: 5.9 running-in: konsole
inxi: 3.3.35
System install date: 2022-01-29
Last full system update: 2024-07-03
Run sync after the copy. It’s done when it returns.
I think if you use the safely unmount on Dolphin, it won’t allow till it’s actually really finished.
Yes, this has been a possible issue since the days of floppy disks…nothing new here.
Thank you!
Although that will work to check when it’s done but still won’t show progress
Whew . You learn something new everyday.
Just to clarify (since I didn’t say), I don’t know a way to show actual progress either. It’s pretty much the nature of the beast to use buffers,etc.
You may not know this, but Windows (last time I had access to a floppy) doesn’t/didn’t cache and the performance hit of using a floppy was HORRID. It was like the whole system came to a near halt. The linux way is much to be preferred.
I have noticed this on USB drives and on some sata disks too. For over a decade, Linux does file copying faster ( sometimes 2x) and is less glitchy / laggy while doing it. + Opening an archive on Windows is like, unpack and the start copying the file. There is something fundamentally better on linux
I’d make sure the pen drive is minimum 10Mb/s capable… something like 30MB/s would be livable.
system
Closed
5 July 2024 10:56
6
