Failed to mount /sysroot and stuck in emergency mode
I just installed Garuda Linux (just dragonized ) I installed some software and updated Garuda . When I tried to boot up Garuda I got this error
(I AM TYPING THIS BECAUSE I AM UNABLE TO UPLOAD IMAGE )
FAILED TO START VIRTUAL CONSOLE SETUP.
Dependency failed for Initrd Root File System
Dependency Failed for Mountpoint Configured in the Real Root.
Then it says entering emergency mode
And also commands doesn’t work
Please help me
Can you restore the latest working snapshot?
It’s giving the same errors :confused:
Just as a sanity check, make sure that in your BIOS the sata controller is set to AHCI instead of e g. Raid
SATA MODE SELECTION is set to AHCI
(Msi gf63 thin laptop 1000gb)
Try booting on a live USB, connect to your WiFi if used and use the chroot Function in the Garuda Assistant.
When you are in, reinstall the kernel you use (this will trigger also a dracut rebuild, which might help). In case of the zen kernel e.g.
pacman -S linux-zen linux-zen-headers
If this doesn’t help, from the live USB again, use the Function to reinstall the GRUB.
I am using this
And I got an error
Can’t read superblock on /dev/sda2(root)
Try from the live USB
sudo btrfs check /dev/sda2
And in case of errors
sudo btrfs check --repair /dev/sda2
It got fixed with live usb, (I will edit this later with detailed information)
