Hey all.
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5a2ed686-9f3f-4d1c-a51e-41bbeea7c18c rw rootflags=subvol=@
Type: Convertible System: LENOVO product: 20FRS08T00
v: ThinkPad X1 Carbon 4th serial: <superuser required> Chassis: type: 31
Mobo: LENOVO model: 20FRS08T00 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N1FET81W (1.55 )
date: 10/11/2022
ID-1: BAT0 charge: 41.4 Wh (87.3%) condition: 47.4/47.4 Wh (100.0%)
power: 16.6 W volts: 16.7 min: 14.8 model: LGC 00HW028 type: Li-ion
Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 700 high: 800 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 400
bogomips: 22399
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 04f2:b531
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP1 model: LG Display 0x04aa built: 2015
res: 1920x1080 hz: 60 dpi: 157 gamma: 1.2 size: 310x170mm (12.2x6.69")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.44 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:1916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0000
Local Storage: total: 1.15 TiB used: 158.92 GiB (13.5%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SN01T size: 953.55 GiB
block-size: physical: 512 B logical: 512 B type: Removable tech: SSD
serial: <filter> scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSCKGF240A5L
tech: SSD serial: <filter> fw-rev: LV8i scheme: GPT
ID-1: / raw-size: 104.65 GiB size: 104.65 GiB (100.00%)
used: 22.11 GiB (21.1%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 502 MiB size: 501 MiB (99.80%)
used: 596 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 104.65 GiB size: 104.65 GiB (100.00%)
ID-4: /var/log raw-size: 104.65 GiB size: 104.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 104.65 GiB size: 104.65 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.61 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C pch: 40.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Processes: 216 Uptime: 27m wakeups: 0 Memory: total: 8 GiB
available: 7.61 GiB used: 3.47 GiB (45.6%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1501
pm: pacman pkgs: 1498 libs: 437 tools: octopi,paru pm: rpm pkgs: 3
Shell: fish v: 3.6.1 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2022-12-02
Last full system update: 2023-11-30
Strange problem since a week or more, (due to updates ?), i cant connect anymore to an external screen with wifi, at school where i’m a teacher.
Normaly i can connect to the screen with a wifi connection, and using gnome-network displays, and choose the number of the classroom (bit like miracast system).
I’m using network manager to connect to the wifi and i can use internet without any problem. I tried t3 different wifi connection for intenet and all 3 are working well.
After a moment i have a message saying : WI-Fi P2P Peer deactivated and autorisation failed because of time.
What could have change with last updates ? Using the same way for monthes without a problem…
I dont know where to search… If you have an idea for me…
SGS
30 November 2023 12:16
2
Use a working snapshot and check the log of garuda-update, but do not update.
One of the apps will be the culprit.
Hey,
I tried all the available snapshots, but with no luck…
I think the problem is a bit older… May be the problem is with gnome-network-displays… I cant find something for kde.
I have read that there are problem with waland but not with X11.
During my searches, i have read something about Pipewire, but it’s too hard for me…
SGS
30 November 2023 12:31
4
I can’t really help, could it be that M$ Win11 has corrupted a module?
So try turning off all fastboot stuff there, and not rebooting from M$, but shutting down the OS completely.
NaN
30 November 2023 12:32
5
You are right this is probably a gnome-network-displays bug.
This open bug report is a year old with sadly no resolution and has the same issue you describe.
Tried that too… Fastboot and other stuffs are off.
Have to go back to MS, to have it usable again…
Not my day, just saying every time, to the students, that Garuda is much much better than MS…
Thanks NaN, not a good news anyway…
Strange thing that it worked perfectly before a couple of weeks…
NaN
30 November 2023 12:46
8
Not really the best advice but you can look at alternatives while you wait to find a fix for this to work. It just sounds like the feature is important to your work and the finding the fix to this might take a while.
That’s what i’m trying to do, but it seems there is nothing like gnome-network-display… I found nothing for KDE for example…
Now i’m just praying that MS is not my only solution
Just joking but… I wouldn’t rule out a classroom prank.
Seriously, maybe try miraclecast
or some other alternative, who knows.
NaN
30 November 2023 12:58
11
Not really a very likely thing to happen just a shot in the dark but can you try to create a new user account, log into it and see if that changes anything? If it doesn’t you can just delete it.
A new user account will have the default configs so if this is a simple config issue we can eliminate it.
Have to try that the next day i’m goging there.
filo
30 November 2023 13:05
14
It’s still installed…
That’s what i found with : journalctl -ru NetworkManager
nov 30 07:51:06 jacques-20frs08t00 systemd[1]: NetworkManager.service: Consumed 1.089s CPU time.
nov 30 07:51:06 jacques-20frs08t00 systemd[1]: Stopped Network Manager.
nov 30 07:51:06 jacques-20frs08t00 systemd[1]: NetworkManager.service: Deactivated successfully.
nov 30 07:51:06 jacques-20frs08t00 NetworkManager[581]: <info> [1701327066.2358] exiting (success)
nov 30 07:51:06 jacques-20frs08t00 NetworkManager[581]: <info> [1701327066.1674] device (p2p-dev-wlp4s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
nov 30 07:51:06 jacques-20frs08t00 NetworkManager[581]: <info> [1701327066.0993] device (wlp4s0): set-hw-addr: reset MAC address to 44:85:00:92:3F:DD (unmanage)
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.9420] device (wlp4s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.9408] caught SIGTERM, shutting down normally.
nov 30 07:51:05 jacques-20frs08t00 systemd[1]: Stopping Network Manager...
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.8596] manager: NetworkManager state is now DISCONNECTED
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.8263] device (wlp4s0): set-hw-addr: set MAC address to A6:6D:21:21:72:FC (scanning)
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.8170] dhcp4 (wlp4s0): state changed no lease
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.8170] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.8170] dhcp4 (wlp4s0): canceled DHCP transaction
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.8168] device (wlp4s0): state change: deactivating -> disconnected (reason 'connection-removed', sys-iface-state: 'managed')
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.8163] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.8163] device (wlp4s0): supplicant interface state: completed -> disconnected
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.7360] modem-manager: ModemManager no longer available
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.7306] manager: NetworkManager state is now DISCONNECTING
nov 30 07:51:05 jacques-20frs08t00 NetworkManager[581]: <info> [1701327065.7302] device (wlp4s0): state change: activated -> deactivating (reason 'connection-removed', sys-iface-state: 'managed')
nov 30 07:50:57 jacques-20frs08t00 NetworkManager[581]: <info> [1701327057.6255] device (p2p-dev-wlp4s0): state change: deactivating -> disconnected (reason 'connection-removed', sys-iface-state: 'managed')
nov 30 07:50:57 jacques-20frs08t00 NetworkManager[581]: <info> [1701327057.6068] device (p2p-dev-wlp4s0): state change: config -> deactivating (reason 'connection-removed', sys-iface-state: 'managed')
nov 30 07:50:46 jacques-20frs08t00 NetworkManager[581]: <info> [1701327046.7434] device (p2p-dev-wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
nov 30 07:50:46 jacques-20frs08t00 NetworkManager[581]: <info> [1701327046.7427] device (p2p-dev-wlp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
nov 30 07:50:46 jacques-20frs08t00 NetworkManager[581]: <info> [1701327046.7419] audit: op="connection-add-activate" uuid="eecd4d63-cfcb-4570-a971-a0f4b5435c89" name="Wi-Fi P2P Peer DE:98:40:9E:2B:CE" pid=198>
nov 30 07:50:46 jacques-20frs08t00 NetworkManager[581]: <info> [1701327046.7417] device (p2p-dev-wlp4s0): Activation: starting connection 'Wi-Fi P2P Peer DE:98:40:9E:2B:CE' (eecd4d63-cfcb-4570-a971-a0f4b5435c>
nov 30 07:50:20 jacques-20frs08t00 NetworkManager[581]: <info> [1701327020.9722] device (p2p-dev-wlp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
nov 30 07:50:20 jacques-20frs08t00 NetworkManager[581]: <warn> [1701327020.9691] device (p2p-dev-wlp4s0): Activation: failed for connection 'Wi-Fi P2P Peer DE:98:40:9E:2B:CE'
nov 30 07:50:20 jacques-20frs08t00 NetworkManager[581]: <info> [1701327020.9665] device (p2p-dev-wlp4s0): state change: config -> failed (reason 'supplicant-timeout', sys-iface-state: 'managed')
nov 30 07:50:20 jacques-20frs08t00 NetworkManager[581]: <warn> [1701327020.9664] device (p2p-dev-wlp4s0): Activation: (wifi-p2p) connecting took too long, failing activation
nov 30 07:49:57 jacques-20frs08t00 NetworkManager[581]: <info> [1701326997.3340] audit: op="statistics" interface="wlp4s0" ifindex=3 args="2000" pid=1360 uid=1002 result="success"
nov 30 07:49:35 jacques-20frs08t00 NetworkManager[581]: <info> [1701326975.6537] device (p2p-dev-wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
nov 30 07:49:35 jacques-20frs08t00 NetworkManager[581]: <info> [1701326975.6532] device (p2p-dev-wlp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
nov 30 07:49:35 jacques-20frs08t00 NetworkManager[581]: <info> [1701326975.6529] audit: op="connection-add-activate" uuid="b8a2eac0-d8ef-47a0-b5bf-a38e7332cd51" name="Wi-Fi P2P Peer DE:98:40:9E:2B:CE" pid=198>
nov 30 07:49:35 jacques-20frs08t00 NetworkManager[581]: <info> [1701326975.6522] device (p2p-dev-wlp4s0): Activation: starting connection 'Wi-Fi P2P Peer DE:98:40:9E:2B:CE' (b8a2eac0-d8ef-47a0-b5bf-a38e7332cd>
nov 30 07:49:24 jacques-20frs08t00 NetworkManager[581]: <info> [1701326964.7825] audit: op="statistics" interface="wlp4s0" ifindex=3 args="2000" pid=1360 uid=1002 result="success"
nov 30 07:49:18 jacques-20frs08t00 NetworkManager[581]: <info> [1701326958.3616] agent-manager: agent[0b62661987d5ea2e,:1.32/org.kde.plasma.networkmanagement/1002]: agent registered
nov 30 07:49:16 jacques-20frs08t00 NetworkManager[581]: <info> [1701326956.7033] manager: NetworkManager state is now CONNECTED_GLOBAL
nov 30 07:49:16 jacques-20frs08t00 NetworkManager[581]: <info> [1701326956.5582] device (wlp4s0): Activation: successful, device activated.
nov 30 07:49:16 jacques-20frs08t00 NetworkManager[581]: <info> [1701326956.5574] manager: NetworkManager state is now CONNECTED_SITE
nov 30 07:49:16 jacques-20frs08t00 NetworkManager[581]: <info> [1701326956.5571] device (wlp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
nov 30 07:49:16 jacques-20frs08t00 NetworkManager[581]: <info> [1701326956.5569] device (wlp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
nov 30 07:49:16 jacques-20frs08t00 NetworkManager[581]: <info> [1701326956.5172] device (wlp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
nov 30 07:49:16 jacques-20frs08t00 NetworkManager[581]: <info> [1701326956.4024] policy: set '13-guest' (wlp4s0) as default for IPv4 routing and DNS
Dont know if it can help…
filo
30 November 2023 13:59
17
Have you tried rebuilding the package?
I see it has as dependencies several packages which are much newer that its last update.
Do not reinstall it from Chaotic-AUR but build it with e.g.:
paru gnome-network-displays
[root@jacques-20frs08t00 jacques]# paru gnome-network-displays
3 aur/gnome-network-displays-git 0.90.5.r56.g738b3ec-1 [+9 ~0.00]
Miracast implementation for GNOME
2 aur/gnome-network-displays 0.90.5-7 [+26 ~1.05] [Installés : 0.90.5-7.3]
1 chaotic-aur/gnome-network-displays 0.90.5-7.3 [95.15 KiB 296.55 KiB] [Installé]
:: Paquets Ă installer (ex : 1 2 3, 1-3) :
Which one do you think i have to use ?
filo
30 November 2023 14:09
19
I’d say 2.
If that doesn’t work, you could then try 3 (the most current version under development).
Strange… I installed again number 2 (0.90.5-7) and immediately after that, garuda-update told me to install the new version (0.90.5-7.3
