Failed to connect to external screen using wifi connection
It is OK. I see that gnome-network-displays has been recently rebuilt in the Chaotic-AUR, so that one should be also OK.
I doubt this will help, but it is something it is always worth trying (reinstalling).
I have to wait for another day back to school to verify if it’s all ok.
Anyway, thanks all for the advices and the help… :+1: :+1: :+1:
Try connecting your cel phone via USB and see if you can cast using your cel.
Although not that likely testing alternate kernels can’t hurt.
Gnome network displays requires p2p mode which is provided by your Wifi driver. As your Wifi adapter is an Intel model there is an outside chance that the kernel or the linux-firmware version could affect this feature. Just in case, try installing the linux-firmware-git package. You could also try downgrading the linux-firmware to a version that was in use when you know your screen casting was last working. After making any changes to your linux-firmware version be sure to reboot.
Try installing gnome-network-displays-git , probably would be best to reboot after installation.
Wouldn’t hurt to try disabling MAC address randomization, (and reboot).
Are you running a firewall, if so is there an entry for ā€œP2P-WiFi-Displayā€ (or similar), and is it set to ā€œallowā€ the connection?
Hello,
Thanks for all the advices… Will try all that hext time i go there… :ok_hand:
