Failed to allocate a zstd buffer
Ran garuda update. Restart pc and kaboom i can't boot. I saw this post Failed allocate zstd buffer
But no solution was marked and preety old so i am creating a new.
I have zero idea about boot things. So please be kind.
Try reinstalling grub from a live system as described here: Grub fails after update - #3 by librewish
Connect to the forum from the live system and paste the terminal output into the thread if you need guidance or feedback.
Hey, have you tried booting a snapshot?
no options from the grub menu works, not even shutdown and restart.
i don't a medium to live system currently.
from bios or uefi (the menu you get by pressing f12) i selected the first boot option which take me to the grub which worked absolutely fine. As far as i know, my motherboard always booted the first option cause that is how boot order should work.
i have to do this everytime i start my machine.
(i press power on button, leave my machine, see grub menu counting 5 to 1, says failed to allocate a zstd buffer and no options works.
i press restart button, leave my machine, see....
but if I
i press restart button, press f12, selects first boot option, see grub counting 5 to 1, boots to garuda)
as i can work in my machine now like this, is there any log or command that should i run to help you investigate or to fix it?
sudo grub-install --efi-directory=/boot/efi && update-grub
[root@Mikado ~]# sudo grub-install --efi-directory=/boot/efi && update-grub
Installing for x86_64-efi platform.
Installation finished. No error reported.
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-zen-fallback.img
fgrep: warning: fgrep is obsolescent; using grep -F
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Found Garuda Linux on /dev/nvme0n1p2
Found Ubuntu 20.04.4 LTS on /dev/nvme0n1p2
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2022-09-21 21:48:56 | @/.snapshots/463/snapshot                 | post | alltray libwnck libxres |
Found snapshot: 2022-09-21 21:48:55 | @/.snapshots/462/snapshot                 | pre  | pacman -S alltray       |
Found snapshot: 2022-09-21 19:39:43 | @/.snapshots/461/snapshot                 | post | polybar                 |
Found snapshot: 2022-09-21 19:39:42 | @/.snapshots/460/snapshot                 | pre  | pacman -S polybar       |
Found snapshot: 2022-09-21 19:24:21 | @/.snapshots/459/snapshot                 | post | cmatrix                 |
Found snapshot: 2022-09-21 19:24:20 | @/.snapshots/458/snapshot                 | pre  | pacman -Rsn cmatrix     |
Found snapshot: 2022-09-21 18:54:36 | @/.snapshots/457/snapshot                 | post | spotify                 |
Found snapshot: 2022-09-21 18:54:34 | @/.snapshots/456/snapshot                 | pre  | pacman -S spotify       |
Found snapshot: 2022-09-21 18:31:05 | @/.snapshots/455/snapshot                 | post | luit xbitmaps xterm     |
Found snapshot: 2022-09-21 18:31:04 | @/.snapshots/454/snapshot                 | pre  | pacman -Rsn xterm       |
Found snapshot: 2022-09-15 10:05:32 | @_backup_20221509100720383_before-restore | N/A  | N/A                     |
Found 11 snapshot(s)
Unmount /tmp/grub-btrfs.0SLcmasdlQ .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
i guess it's allright now, but why it detects ubuntu on the same partition of garuda.
Docker containers? Systemd nspawn? One of the two maybe?
no idea about systemd nspawn, it is docker then.
