p2501
August 27, 2022, 4:01am
1
Hello,
as of todays update my system’s unable to boot. I need assistance, but I’m unable to give a lot of information about said system, only that I’ve been updating it daily and that it is in good working order. The error I’m getting is
Failed allocate zstd buffer
right after
booting garuda linux
and that’s it. I cant load any fallback or snapshot because of that same error. I’ve searched a bit for it and it seems to be a grub error, maybe? There has been a kernel update today, so maybe something went wrong with that?
p2501
August 27, 2022, 6:10am
2
This indeed stems from the recent grub issues, it has been resolved via a rerun of grub-install.
grub-install --version
grub-install (GRUB) 2:2.06.r322.gd9b4638c5-1
inxi -Faz
Kernel: 5.19.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=66e5d40a-2370-44f3-b3b6-ddff5b2046cf rw rootflags=subvol=@
ipv6.disable=1 quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=e5f09ca4-2e13-4405-b97d-9a69816c4515 ipv6.disable=1
loglevel=3 ibt=off
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: bspwm
v: 0.9.10 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550 AORUS PRO V2
serial: <superuser required> UEFI: American Megatrends LLC. v: F14e
date: 10/14/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2436 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3140
3: 3800 4: 2200 5: 2200 6: 2200 7: 2787 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2853 14: 2200 15: 2200 16: 2200 bogomips: 121362
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ZOTAC
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 07:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-c4107
driver: X: loaded: nvidia unloaded: modesetting
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x572mm (40.00x22.52")
s-diag: 1166mm (45.9")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 140
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel bus-ID: 1-6.3:6 v: kernel pcie: chip-ID: 19f7:0015
gen: 4 class-ID: 0300 speed: 16 GT/s serial: <filter> lanes: 16
bus-ID: 07:00.1 chip-ID: 10de:228e class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: RODE Microphones RØDE NT-USB Mini type: USB
Sound Server-1: ALSA v: k5.19.4-zen1-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Device-1: sink type: zfs status: ONLINE level: raidz1-0 raw: size: 49.1 TiB
free: 32.6 TiB allocated: 16.5 TiB zfs-fs: size: 32.58 TiB free: 21.57 TiB
Components: Online:
1: sda maj-min: 8:0 size: 16.37 TiB
2: sdb maj-min: 8:16 size: 16.37 TiB
3: sdc maj-min: 8:32 size: 16.37 TiB
Local Storage: total: raw: 50.93 TiB usable: 34.4 TiB used: 12.03 TiB
(35.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP600 PRO XT
lanes: 4 type: SSD serial: <filter> rev: EIFM31.2 temp: 31.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MG09ACA18TE
size: 16.37 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: 0104 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MG09ACA18TE
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MG09ACA18TE
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.02 TiB (57.9%)
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.02 TiB
(57.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.02 TiB
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.02 TiB
Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: zram size: 62.71 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 69.05 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 42.5 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 455 Uptime: 3m wakeups: 0 Memory: 62.71 GiB used: 4.32 GiB
(6.9%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 1571 pacman: 1552 lib: 351
flatpak: 19 Shell: fish v: 3.5.1 running-in: alacritty inxi: 3.3.20```
p2501
August 28, 2022, 3:58am
3
I ran garuda-update sometime after this, and guess what, as I started my computer today it again didn't boot. Had to rerun grub-install. Wtf is happening, what did you guys do?
SGS
August 28, 2022, 4:11am
4
Could it be related to the hardware constellation?
I have updated three PCs, two very old ones and one "new" one, without any problems; I had to repair my two "new" notebooks once via chroot. Since then I have run updates several times without any problems.
Could it also be that if the latest grub was already installed, the system then hangs?
And we guys here are just trying to fix the error caused by the grub update.
Try living without updates for a few days until the grub developers fix the bug, please.
p2501
August 28, 2022, 5:43am
5
Will do, thanks for your hard work!
I don't know if it's due to my configuration, I just know that it's been smooth sailing so far with garuda. I had tried other distros before, some of which weren't able to boot at all. I thinks it's got something to do with my mainboard/nvme combination.
I just ran into this issue also, how do I fix it? I can't get into the system.
rakaw
September 1, 2022, 4:02pm
7
Looks like i started running into this problem after enabling hibernate & the resume function in grub. If a grub-install doesn't fix it, then just keep rebooting until it works... until grub fixes the problem.
