I started garuda from a USB stick.
The error message "Failed Light Display Manager" was displayed.
How can I remove error message "Failed Light Display manager"? Is there a boot option for this?
Hi there, welcome.
Try with open source drivers and disabling secure boot and fast boot in BIOS
Yes i use open source drivers secure boot is disabled fast boot is disabled. But its dont start
Just in case, but it should not be the issue, checksum verified?
What tool did you use to burn the USB?
The sha256sum is ok.
I use ventoy.
That's a bit strange, quite frankly.
What are the specs of your hw?
What Garuda edition did you download?
I have garuda-xfce-linux-zen-220101
My Motherboard is Asrock B450 Pro
My CPU is AMD Ryzen 5 2400 g
I have 8 Gb Ram
I think the only option is to try some boot parameters pushing E in the open source driver GRUB line.
I'd start with iommu=soft
If that doesn't help, you could try e.g. forcing the amdgpu driver instead of the Radeon one (I assume the GPU is AMD).
If I remember correctly this was something like
radeon.si_support=0 radeon.cik_support=0 amdgpu.si_support=1 amdgpu.cik_support=1 modprobe.blacklist=radeon
The screen remains black afterwards .
I once had a Ventoy problem with a perfectly good iso, but maybe a few lame cells on the flash disk and couldn't quite get through the installer either. If you still have the iso on your computer, try to re-save it to the Ventoy. Don't delete the old one, just rename it "zz-do_not_use" or similar to avoid reusing that piece of the drive again (if that is the issue).
[quote="BluishHumility, post:10, topic:16874, full:true"]
I also have ventoy
I apologize, it sounds like I was unclear. What I mean to say:
- A few corrupted cells on your USB drive will not be detected by Ventoy, but will disrupt the installation.
- To check, add the garuda-xfce-linux-zen-220101 ISO to the Ventoy again and re-try the installation.
- Do not delete the old image from the Ventoy disk, or Ventoy will potentially reuse those same corrupted cells in the future. Instead, rename the old image (any name) and just leave it.
This might not be a fix, but if the installer still is not working for you it is worth a shot.
The iso is good and not brocken!
The message I am trying to communicate is that the ISO can be good but some of the physical cells on the USB drive--the actual device--can be corrupted.
If this were the case (nothing wrong with the ISO), my advice is rename the old image (right where it sits on the Ventoy) and save the perfectly good ISO to the disk again, a second time. Two of the same image saved to the Ventoy disk at the same time.
Continuing the discussion from Failed Light Display manager:
inxi -fz
Info: 8x 1-core model: AMD EPYC-Rome bits: 64 type: SMP cache:
L2: 8x 512 KiB (4 MiB)
Speed (MHz): avg: 3615 min/max: N/A cores: 1: 3615 2: 3615 3: 3615
4: 3615 5: 3615 6: 3615 7: 3615 8: 3615
Flags: 3dnowprefetch abm adx aes apic arat arch_capabilities avx avx2
bmi1 bmi2 clflush clflushopt clzero cmov cmp_legacy cpuid cr8_legacy cx16
cx8 de extd_apicid f16c fma fpu fsgsbase fxsr fxsr_opt hypervisor ibpb
lahf_lm lm mca mce misalignsse mmx mmxext movbe msr mtrr nopl nx osvw pae
pat pclmulqdq pdpe1gb perfctr_core pge pni popcnt pse pse36 rdrand rdseed
rdtscp rep_good sep sha_ni smap smep ssbd sse sse2 sse4_1 sse4_2 sse4a
ssse3 syscall topoext tsc tsc_adjust tsc_deadline_timer tsc_known_freq
virt_ssbd vme vmmcall x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
I moved the new topic into the initial one, since it's still open.
Please provide garuda-inxi
if available, or at least inxi -Faz
inxi -Faz
Kernel: 5.16.10-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=0c36ac7c-399a-4fd0-b2d4-4382dd28546b rw loglevel=3 audit=0
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.31 vt: 7 dm: LightDM 1.30.0
Distro: Arch Linux
Type: Kvm System: QEMU product: Standard PC (Q35 + ICH9, 2009)
v: pc-q35-5.2 serial: <superuser required> Chassis: type: 1 v: pc-q35-5.2
Mobo: N/A model: N/A serial: N/A BIOS: SeaBIOS v: 1.14.0-2
date: 04/01/2014
Info: model: AMD EPYC-Rome bits: 64 type: SMP arch: Zen 2 family: 0x17 (23)
model-id: 0x31 (49) stepping: 0 microcode: 0x1000065
Topology: cpus: 8x cores: 1 smt: <unsupported> cache:
L1: 8x 64 KiB (512 KiB) desc: d-1x32 KiB; i-1x32 KiB L2: 8x 512 KiB (4 MiB)
desc: 1x512 KiB L3: 8x 16 MiB (128 MiB) desc: 1x16 MiB
4: 3615 5: 3615 6: 3615 7: 3615 8: 3615 bogomips: 57863
Flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
STIBP: disabled, RSB filling
Device-1: Red Hat QXL paravirtual graphic card driver: qxl v: kernel
bus-ID: 00:01.0 chip-ID: 1b36:0100 class-ID: 0300
Display: x11 server: X.org 1.21.1.3 driver: loaded: modesetting
alternate: fbdev,vesa resolution: <missing: xdpyinfo>
Device-1: Intel 82801I HD Audio vendor: Red Hat QEMU Virtual Machine
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e
Sound Server-1: ALSA v: k5.16.10-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Device-1: Red Hat Virtio network driver: virtio-pci v: 1
modules: virtio_pci port: N/A bus-ID: 01:00.0 chip-ID: 1af4:1041
IF-ID-1: enp1s0 state: up speed: -1 duplex: unknown mac: <filter>
Local Storage: total: 40 GiB used: 9.67 GiB (24.2%)
ID-1: /dev/vda maj-min: 254:0 model: N/A size: 40 GiB block-size:
physical: 512 B logical: 512 B speed: <unknown> type: N/A serial: N/A
scheme: MBR
ID-1: / raw-size: 39.99 GiB size: 39.07 GiB (97.69%) used: 9.67 GiB (24.7%)
fs: ext4 dev: /dev/vda1 maj-min: 254:1
Alert: No swap data was found.
Message: No sensor data found. Is lm-sensors configured?
Processes: 236 Uptime: 0m wakeups: 42 Memory: 3.78 GiB
used: 1.23 GiB (32.6%) Init: systemd v: 250 target: graphical.target
tool: systemctl Compilers: gcc: 11.2.0 Packages: pacman: 649 lib: 201
Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.12
Now I'm a bit lost.
This looks like a virtual machine, is it?
VMs are not officially supported, but I don't understand the relation with the initial thread, which was for a non-booting USB.
What is the actual problem?
I cant start from USB.
Use other usb-stick otherusb port and try other hardware for test.
