inxi -Faz
System: Kernel: 5.10.82-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=6a4af797-f4ba-4b69-a457-97f651b8524d
systemd.unified_cgroup_hierarchy=1 loglevel=3 iommu=soft
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: H.C2 date: 12/29/2020
CPU: Info: 6-Core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 family: 19 (25)
model-id: 21 (33) stepping: 0 microcode: A201009 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 88799
Speed: 3684 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 3684 2: 3731
3: 3692 4: 3643 5: 3711 6: 3698 7: 3636 8: 3712 9: 3656 10: 3741 11: 3612 12: 3604
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics: Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: XFX Limited XFX Speedster MERC 319 driver: amdgpu v: kernel bus-ID: 2f:00.0
chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3000x1920 s-dpi: 96 s-size: 791x506mm (31.1x19.9") s-diag: 939mm (37")
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 144 dpi: 82 size: 598x337mm (23.5x13.3")
diag: 686mm (27")
Monitor-2: DisplayPort-1 res: 1080x1920 hz: 60
OpenGL: renderer: AMD Radeon RX 6800 XT (SIENNA_CICHLID DRM 3.40.0 5.10.82-1-lts LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] driver: snd_hda_intel
v: kernel bus-ID: 2f:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO driver: snd_hda_intel
v: kernel bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Licensed by Sony Entertainment America Rocksmith Guitar Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2 chip-ID: 12ba:00ff class-ID: 0300
Device-4: C-Media USB Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-2:3 chip-ID: 0d8c:0012 class-ID: 0300
Sound Server-1: ALSA v: k5.10.82-1-lts running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Micro-Star MSI X570-A PRO driver: r8168 v: 8.049.02-NAPI modules: r8169 port: d000
bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: down mac: <filter>
Device-2: NetGear A6210 type: USB driver: mt76x2u bus-ID: 8-2:2 chip-ID: 0846:9053
IF: wlp49s0f3u2 state: up mac: <filter>
Drives: Local Storage: total: 3.76 TiB used: 49.05 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8000NP size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: C2.2.1
temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 1T00 size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUA723030ALA640 size: 2.73 TiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: AA10
ID-4: /dev/sdc maj-min: 8:32 type: USB model: USB DISK 3.0 size: 7.38 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
Partition: ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 20.87 GiB (17.5%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 20.87 GiB (17.5%) fs: btrfs
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 20.87 GiB (17.5%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 20.87 GiB (17.5%)
ID-1: swap-1 type: zram size: 31.27 GiB used: 3 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 30.8 C mobo: N/A gpu: amdgpu temp: 50.0 C mem: 50.0 C
Info: Processes: 382 Uptime: 4h 40m wakeups: 0 Memory: 31.27 GiB used: 6.37 GiB (20.4%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1829 lib: 547
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
My WiFi USB dongle works fine, I have a terrible connection that has bad lag. I have been able to use my Ethernet connection on Windows 10 prior to switching to linux with no issues. Linux Mint and Manjaro worked fine with the ethernet until Manjaro updated something and it stopped working. Garuda has never worked.
I have already changed the drivers by blacklisting the r8169 module and installing the r8168 module. This has made it so that the network manager went from not seeing the ethernet adapter to now attempting to connect every 10 seconds or so, hanging up on "Setting network address" then coming up with an error message stating "Connection 'Wired Connection 1' deactivated
Any help is appreciated
