Errors occurred, no packages were upgraded
Hello, I’m new to Garuda.
I’m having trouble updating the system.
I’ve done research and tried solutions with similar results, but to no avail. Could someone help me?
Note: Google translation from Portuguese to Brazilian Portuguese
I get the same result for: “garuda-update”, “pacman -Syu”, “garuda-update remote keyring” and “garuda-update remote fix”
Following:
:: Sincronizando a base de dados de pacotes...
warning: dependency cycle detected:
warning: qt6-multimedia-ffmpeg will be installed before its qt6-multimedia dependency
warning: python-soupsieve will be installed before its python-beautifulsoup4 dependency
warning: insufficient columns available for table display
Total Download Size:       0.84 MiB
Total Installed Size:  22216.33 MiB
Net Upgrade Size:        412.32 MiB
:: Retrieving packages...
garuda-hardware-...     4.9 KiB  4.66 KiB/s 00:01 [------------------------] 100%
libdatachannel-0...   853.0 KiB   311 KiB/s 00:03 [------------------------] 100%
Total (2/2)           857.9 KiB   294 KiB/s 00:03 [------------------------] 100%
(701/701) checking keys in keyring                 [------------------------] 100%
(701/701) checking package integrity               [------------------------] 100%
(701/701) loading package files                    [------------------------] 100%
(701/701) checking for file conflicts              [------------------------] 100%
virt-install: /usr/share/virt-manager/virtinst/__pycache__/__init__.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/_progresspriv.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/buildconfig.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/capabilities.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/cli.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/cloner.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/connection.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/diskbackend.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/domcapabilities.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/generatename.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/guest.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/logger.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/network.cpython-313.pycexists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/nodedev.cpython-313.pycexists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/osdict.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/pollhelpers.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/progress.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/snapshot.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/storage.cpython-313.pycexists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/support.cpython-313.pycexists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/uri.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/xmlapi.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/xmlbuilder.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/__pycache__/xmlutil.cpython-313.pycexists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/__init__.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/audio.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/char.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/controller.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/device.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/disk.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/filesystem.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/graphics.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/hostdev.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/input.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/interface.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/iommu.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/memballoon.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/memory.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/panic.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/redirdev.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/rng.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/shmem.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/smartcard.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/sound.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/tpm.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/video.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/vsock.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/devices/__pycache__/watchdog.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/__init__.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/blkiotune.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/clock.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/cpu.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/cputune.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/features.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/idmap.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/keywrap.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/launch_security.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/memorybacking.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/memtune.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/metadata.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/numatune.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/os.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/pm.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/resource.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/seclabel.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/sysinfo.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/vcpus.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/domain/__pycache__/xmlnsqemu.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/install/__pycache__/__init__.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/install/__pycache__/cloudinit.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/install/__pycache__/installer.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/install/__pycache__/installerinject.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/install/__pycache__/installertreemedia.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/install/__pycache__/unattended.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/install/__pycache__/urldetect.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/install/__pycache__/urlfetcher.cpython-313.pyc exists in filesystem
virt-install: /usr/share/virt-manager/virtinst/install/__pycache__/volumeupload.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/__init__.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/addhardware.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/asyncjob.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/baseclass.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/config.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/connection.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/connmanager.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/createconn.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/createnet.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/createpool.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/createvm.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/createvol.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/delete.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/engine.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/error.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/host.cpython-313.pycexists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/hostnets.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/hoststorage.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/manager.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/oslist.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/storagebrowse.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/systray.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/virtmanager.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/vmmenu.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/vmwindow.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/__pycache__/xmleditor.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/details/__pycache__/__init__.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/details/__pycache__/console.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/details/__pycache__/details.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/details/__pycache__/serialcon.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/details/__pycache__/snapshots.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/details/__pycache__/sshtunnels.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/details/__pycache__/viewers.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/device/__pycache__/__init__.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/device/__pycache__/addstorage.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/device/__pycache__/fsdetails.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/device/__pycache__/gfxdetails.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/device/__pycache__/mediacombo.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/device/__pycache__/netlist.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/device/__pycache__/tpmdetails.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/device/__pycache__/vsockdetails.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/lib/__pycache__/__init__.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/lib/__pycache__/connectauth.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/lib/__pycache__/graphwidgets.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/lib/__pycache__/inspection.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/lib/__pycache__/keyring.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/lib/__pycache__/libvirtenummap.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/lib/__pycache__/statsmanager.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/lib/__pycache__/testmock.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/lib/__pycache__/uiutil.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/object/__pycache__/__init__.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/object/__pycache__/domain.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/object/__pycache__/libvirtobject.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/object/__pycache__/network.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/object/__pycache__/nodedev.cpython-313.pyc exists in filesystem
virt-manager: /usr/share/virt-manager/virtManager/object/__pycache__/storagepool.cpython-313.pyc exists in filesystem
Hi there, welcome to the forum!
This tutorial should explain the problem and possible reasons:
You could check the better way, or simply the I don’t care, better with
garuda-update -- --overwrite '*'
Please always provide your garuda-inxi, as required by the topic template.
