Error in systemctl, systemd, kernel etc
Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ed32595a-d211-4658-b067-e481188b5b26 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.0 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX II (MS-7C02) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.90
date: 07/25/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3691 high: 3700 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3599 11: 3700
12: 3700 bogomips: 88801
Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: PNY driver: nvidia
v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 26:00.0 chip-ID: 10de:2487
Screen-1: 0 s-res: 6960x1920 s-dpi: 109 s-size: 1622x447mm (63.86x17.60")
s-diag: 1682mm (66.24")
Monitor-1: DP-0 pos: bottom-r res: 1920x1080 hz: 60 dpi: 92
Monitor-2: DP-2 pos: primary,top-left res: 1200x1920 hz: 60 dpi: 94
size: 324x518mm (12.76x20.39") diag: 611mm (24.05") modes: N/A
Monitor-3: DP-4 pos: top-center res: 3840x1600 hz: 60 dpi: 111
size: 879x366mm (34.61x14.41") diag: 952mm (37.49") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX
3060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel bus-ID: 5-1.1:4 chip-ID: 0499:170f pcie:
gen: 3 class-ID: 0103 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 26:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Yamaha Steinberg UR22mkII type: USB driver: snd-usb-audio
Device-4: Intel USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:3 chip-ID: 8086:0808
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
bus-ID: 3-1.4:3 chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Local Storage: total: 4.1 TiB used: 1.58 TiB (38.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1014 size: 476.94 GiB block-size: physical: 512 B
rev: 20110000 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
used: 23.76 GiB (5.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 36.8 C mobo: N/A gpu: nvidia temp: 56 C
Processes: 354 Uptime: 4m wakeups: 0 Memory: 31.27 GiB
used: 4.82 GiB (15.4%) Init: systemd v: 253 default: graphical
pkgs: 1715 libs: 446 tools: octopi,pamac,paru Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.14-1):
System install date:     2023-02-18
Last full system update: 2023-02-18
Failed units:            anbox-container-manager.service systemd-networkd-wait-online.service
Hello! I received a couple of errors after $ systemctl --failed and # journalctl -p 3 -b
Anyone with better knowledge knows how to procedure now?
โ•ญโ”€ahbh@linux in ~
โ•ฐโ”€ฮป systemctl --failed
UNIT                            LOAD   ACTIVE SUB    DESCRIPTION
โ— anbox-container-manager.service loaded failed failed Anbox Container Manager
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
ั„ะตะฒ 18 23:01:27 linux-desktop kernel: blacklist: Problem blacklisting hash (-13)
ั„ะตะฒ 18 23:01:27 linux-desktop kernel: usb 3-1.4: device descriptor read/64, error -32
ั„ะตะฒ 18 23:01:27 linux-desktop systemd-modules-load[383]: Failed to find module 'ashmem_linux'
ั„ะตะฒ 18 23:01:27 linux-desktop systemd-modules-load[383]: Failed to find module 'binder_linux'
ั„ะตะฒ 18 23:01:27 linux-desktop systemd-modules-load[383]: Failed to find module 'vboxpci'
ั„ะตะฒ 18 23:01:27 linux-desktop systemd-udevd[417]: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:57 Unknown group 'uaccess', ignoring
ั„ะตะฒ 18 23:01:28 linux-desktop (udev-worker)[488]: hiddev0: /usr/lib/udev/rules.d/69-mixxx-usb-uaccess.rules:57 Only network interfaces can be re>
ั„ะตะฒ 18 23:01:28 linux-desktop bluetoothd[758]: src/plugin.c:plugin_init() Failed to init vcp plugin
ั„ะตะฒ 18 23:01:28 linux-desktop bluetoothd[758]: src/plugin.c:plugin_init() Failed to init mcp plugin
ั„ะตะฒ 18 23:01:28 linux-desktop bluetoothd[758]: src/plugin.c:plugin_init() Failed to init bap plugin
ั„ะตะฒ 18 23:01:42 linux-desktop systemd[3848]: Failed to start Initial Bashrc setup.
ั„ะตะฒ 18 23:01:42 linux-desktop systemd[3848]: Failed to start BTRFS Assistant Snapper check.
ั„ะตะฒ 18 23:01:42 linux-desktop systemctl[4582]: Failed to enable unit: Unit file gamemoded\x3bsetup_dxvk.service does not exist.
ั„ะตะฒ 18 23:02:40 linux-desktop konsole[10789]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KAct>
ั„ะตะฒ 18 23:02:40 linux-desktop konsole[10789]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KAction>
ั„ะตะฒ 18 23:02:40 linux-desktop sudo[10837]:     ahbh : a password is required ; TTY=pts/0 ; PWD=/home/ahbh ; USER=root ; COMMAND=/usr/bin/true
ั„ะตะฒ 18 23:02:41 linux-desktop sudo[10874]:     ahbh : a password is required ; TTY=pts/0 ; PWD=/home/ahbh ; USER=root ; COMMAND=/usr/bin/true
Anbox is all done I think, see Austinโ€™s post here with links and alternative recommendations:
So u think that other errors are as a result of that anbox error?
No, the Anbox thing is the only failed unit. The rest of the output is unrelated to that.
If you want to chase down these errors and clean up your log a bit, do a web search for the journal message and try to figure out what it means. For example:
The very first result in a search query leads me to this thread, which provides an explanation and an additional thread you can follow for updates if you wish:
These kernel messages should be treated as warning, not error. You should not remove blacklisted hashes (i.e. do not clear secure boot keys), this is a security measure to protect against malicious signatures. These kernel messages now show because we hardened this security mechanism, and it now reveals issues with some firmwares. There is an ongoing kernel patch to update this error message: https://lore.kernel.org/lkml/3b997266-0 โ€ฆ gikod.net/
If you are no longer using Windows you can delete the secure boot keys and that will clear up the warning messages, but that guy says they are working on a kernel patch that will suppress the messages without deleting anything.
Long story short: the Anbox thing you should take care of as soon as you get a chance (I would just uninstall it/disable the service). The rest is not critical, but if you care and have time itโ€™s worthy of investigation. Probably some of those would be easy to resolve.
I thought that I did that before, but it seems not.
Yeah, already uninstalled it and I think thereโ€™s no more failed units.
Thank you!
