My laptop keyboard is behaving strangely. Sometimes a key stops working for a day or two and then again starts working. It has also happened that a key gets pressed automatically and remains pressed. The issue sometimes gets fixed by a suspend, sometimes by a restart and sometimes I just need to wait it out.
As for the touchpad after watching something on fullscreen it stops responding. After I suspend my pc it starts working fine.
I am new to Garuda. Please help. I love the OS and do not want to switch over such things. Do I need to install a fresh copy?
Welcome,
sounds like a hardware issue.
Post
inxi -Faz
Can you help me how to post well formatted output as I have seen on other question (e.g. in this question Thouchpad Not working proprly)? I have tried looking for such guide or similar stuff, but could not find so. I would have uploaded an image, but I am restricted from that.
Kernel: 5.9.6-zen1-1-zen x86_64 bits: 64 compiler: N/A
root=UUID=fe8e44b4-dc34-4b5e-b708-dc30cfb47020 rw [email protected] quiet
splash loglevel=3
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Garuda Linux
Type: Laptop System: Dell product: Vostro 3580 v: N/A serial:
Chassis: type: 10 serial:
Mobo: Dell model: 0736F2 v: A00 serial: UEFI: Dell v: 1.8.0
date: 02/12/2020
ID-1: BAT0 charge: 21.7 Wh condition: 35.4/42.0 Wh (84%) volts: 11.4/11.4
model: Samsung SDI DELL CYMGM8C type: Li-ion serial:
status: Discharging
Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: B (11)
microcode: D6 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 28800
Speed: 800 MHz min/max: 400/1600 MHz Core speeds (MHz): 1: 832 2: 878
3: 823 4: 825 5: 875 6: 876 7: 801 8: 885
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3ea0
Device-2: AMD Jet PRO [Radeon R5 M230 / R7 M260DX / Radeon 520 Mobile]
vendor: Dell driver: radeon v: kernel alternate: amdgpu bus ID: 01:00.0
chip ID: 1002:6665
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-6:4 chip ID: 0c45:671e
Display: x11 server: X.Org 1.20.9 compositor: gnome-shell
driver: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.9.6-zen1-1-zen
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel port: 3000 bus ID: 02:00.0
chip ID: 168c:0042
IF: wlp2s0 state: up mac:
Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-10:5
chip ID: 0cf3:e009
Local Storage: total: 931.51 GiB used: 14.66 GiB (1.6%)
ID-1: /dev/sda vendor: Samsung model: ST1000LM035-1RK172 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: rev: SDM3 scheme: GPT
ID-1: / raw size: 931.22 GiB size: 931.22 GiB (100.00%)
used: 14.66 GiB (1.6%) fs: btrfs dev: /dev/sda2
ID-2: /home raw size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-1: swap-1 type: zram size: 240.3 MiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 240.3 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 240.3 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 240.3 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 240.3 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 240.3 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 240.3 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 240.3 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
System Temperatures: cpu: 50.0 C mobo: N/A gpu: radeon temp: 46.0 C
Fan Speeds (RPM): cpu: 0
Processes: 289 Uptime: 5m Memory: 7.51 GiB used: 1.74 GiB (23.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1101 lib: 287 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.1.06
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
From
First update your system (Kernel: 5.12.8-zen1-1-zen x86_64),last BIOS installed?
Check for dust or or dried liquids under the keyboard.
This is the output to inxi -Faz ,
System: Kernel: 5.12.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=18960cc3-e31f-434e-a1f2-0a17ab6ec5a5 rw [email protected] quiet splash
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux
Machine: Type: Laptop System: Dell product: Vostro 15-3568 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 05HRPP v: A00 serial: <filter> UEFI: Dell v: 3.3.0
date: 01/17/2019
Battery: ID-1: BAT0 charge: 18.9 Wh (77.5%) condition: 24.4/41.4 Wh (58.8%) volts: 15.6
min: 14.8 model: LGC-LGC2.80 DELL 991XP6B type: Li-poly serial: <filter>
status: Discharging
CPU: Info: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 4E (78) stepping: 3 microcode: E2 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15999
Speed: 1997 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 1997 2: 2000 3: 2002
4: 2000
Type: l1tf
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 0c45:6a05 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: picom v: git-dac85 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.1.1
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70
Sound Server-1: ALSA v: k5.12.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Network: Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: f040
bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-8:4 chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter>
Drives: Local Storage: total: 223.57 GiB used: 22.43 GiB (10.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
rotation: SSD serial: <filter> rev: 052 scheme: GPT
Partition: ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 14.01 GiB (14.0%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 257 MiB size: 253 MiB (98.46%) used: 548 KiB (0.2%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 115.32 GiB size: 115.32 GiB (100.00%) used: 8.42 GiB (7.3%)
fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%) used: 14.01 GiB (14.0%)
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%) used: 14.01 GiB (14.0%)
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
ID-2: swap-2 type: zram size: 949.2 MiB used: 0 KiB (0.0%) priority: 32767
ID-3: swap-3 type: zram size: 949.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-4: swap-4 type: zram size: 949.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-5: swap-5 type: zram size: 949.2 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
Sensors: System Temperatures: cpu: 42.0 C mobo: 40.0 C
Info: Processes: 217 Uptime: 2m wakeups: 1 Memory: 3.71 GiB used: 1.61 GiB (43.4%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 11.1.0
Packages: pacman: 1340 lib: 351 Shell: Zsh v: 5.8 running-in: alacritty
inxi: 3.3.04
It indeed appears that it is a hardware problem. I live booted Ubuntu, and the keyboard, touchpad malfunctioned there too.
Thank you for your time and patience.
Is it possible to switch off the touchpad and the laptop keyboard?
