Hello Garuda users.
I'm a new Garuda user who switched from Manjaro. Previously I managed to use efistub on the Manjaro distro. In the same way why I failed to use efistub on Garuda distro, is it because of btrfs file system?
I tried adding rootflags but it still fails to boot.
This is the command I used to create the efistub:
$ efibootmgr -d /dev/sda -p 1 -c -L "Garuda" -l /vmlinuz-linux-zen -u "resume=UUID=e4ea5eef-411d-409f-88cd-3d339aa6c5cc root=UUID=087dbc54-86c8-4523-a952-5191181b284b rootflags=subvol=ROOT rw quiet splash fbcon=nodefer rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 initrd=/initramfs-linux-zen.img"
I also tried using efistub-git, but it still fails.
Please help.
Thank you
Thanks for the quick reply​
This is the output of garuda-inxi:
$ System:
Kernel: 5.19.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=cc5e68e7-4fe7-40e6-87d9-dde142078ba6 rw rootflags=subvol=@
Type: Laptop System: Acer product: Aspire V5-132 v: V2.05
Mobo: Acer model: Angel_CY v: V2.05 serial: <superuser required>
UEFI: Phoenix v: 2.05 date: 09/04/2013
ID-1: BAT0 charge: 16.9 Wh (95.5%) condition: 17.7/30.1 Wh (58.7%)
volts: 13.0 min: 11.4 model: SANYO AC13C34 type: Li-ion serial: <filter>
status: charging
Info: model: Intel Celeron 1019Y bits: 64 type: MCP arch: Ivy Bridge
built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3A (58)
stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 925 high: 977 min/max: 800/1000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 977 2: 873
bogomips: 3990
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 3rd Gen Core processor Graphics vendor: Acer Incorporated
ALI driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13
ports: active: eDP-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0156 class-ID: 0300
Device-2: Chicony HD WebCam (Acer) type: USB driver: uvcvideo
bus-ID: 2-1.4:3 chip-ID: 04f2:b3f6 class-ID: 0e02 serial: <filter>
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x215c built: 2013 res: 1366x768
hz: 60 dpi: 136 gamma: 1.2 size: 256x144mm (10.08x5.67")
diag: 294mm (11.6") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 2500 (IVB GT1) v: 4.2 Mesa
22.1.7 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Acer
Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k5.19.5-zen1-1-zen running: yes
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
Device-1: Lite-On Atheros AR3012 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:7 chip-ID: 04ca:300b class-ID: e001
Local Storage: total: 465.76 GiB used: 97.96 GiB (21.0%)
model: WD5000LPVX-22V0TT0 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 27.34 GiB size: 27.34 GiB (100.00%) used: 7.05 GiB
(25.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 333.4 MiB
(66.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 63.08 GiB size: 63.08 GiB (100.00%) used: 272.3 MiB
(0.4%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 27.34 GiB size: 27.34 GiB (100.00%) used: 7.05
GiB (25.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 27.34 GiB size: 27.34 GiB (100.00%) used: 7.05
ID-1: swap-1 type: zram size: 5.68 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 5.96 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 66.0 C mobo: N/A
Processes: 203 Uptime: 3h 53m wakeups: 2 Memory: 5.68 GiB used: 2.25 GiB
(39.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1169 lib: 303 Shell: fish v: 3.5.1
Garuda (2.6.6-1):
System install date: 2022-09-01
Last full system update: 2022-09-02
Btw, the UUID I'm using is same as the output from garuda-inxi not the same as the one I posted
How exactly? Are you getting an error or a problem when booting?
Simbamalaka:
Try
rootflags=subvol=@
Are you sure this is right? The -l flag is for specifying the loader ( the default is \EFI\arch\grub.efi).
Thanks very much. this is the solution​
I'm not sure, just following what the internet says​
system
Closed
4 September 2022 18:45
10
