For about 3 hours now, ive been trying to play dying light 2 on my laptop.
The game used to work on me when I used endeavoros on wayland.
I tried to install wayland on garuda. Installed all of the needed packages to my knowledge, plasma-wayland session, wlroots etc. When I select KDE on wayland from the login screen, I am granted a black screen.
I assume these problems come from my intel onboard graphics, they have been the root of 99% of my problems since switching from windows.
https://wiki.archlinux.org/title/NVIDIA_Optimus#Use_NVIDIA_graphics_only
I tried following this, it didn't work.
I wish I could just rip the intel graphics out of this laptop
My specs and output of garuda-inxi are bellow
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3304b4fa-2a9b-471b-aff3-d72993864ec5 rw [email protected]
loglevel=3 ibt=off
wm: kwin_x11 vt: 1 dm: 1: GDM 2: SDDM note: stopped Distro: Garuda Linux
Type: Laptop System: Alienware product: Alienware Area-51m R2 v: 1.17.0
serial: Chassis: type: 10 serial:
Mobo: Alienware model: Alienware Area-51m R2 v: A00
serial: UEFI: Alienware v: 1.17.0 date: 06/07/2022
ID-1: BAT1 charge: 78.6 Wh (97.0%) condition: 81.0/90.0 Wh (89.9%)
volts: 12.7 min: 11.4 model: COMPAL PABAS0241231 type: Li-ion
serial: status: charging
ID-2: hidpp_battery_0 charge: 91% condition: N/A volts: 4.1 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: status: discharging
Info: model: Intel Core i7-10700 bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3538 high: 4606 min/max: 800/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 2900 2: 4499 3: 2900
4: 4600 5: 1845 6: 4606 7: 4602 8: 4600 9: 2900 10: 2900 11: 2900 12: 2369
13: 4600 14: 2900 15: 4600 16: 2900 bogomips: 92796
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Dell driver: i915
active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc5 class-ID: 0380
Device-2: NVIDIA TU104BM [GeForce RTX 2070 SUPER Mobile / Max-Q]
vendor: Dell driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm
non-free: 525.xx+ status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1ed1 class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-7:5 chip-ID: 0bda:5538 class-ID: 0e02 serial:
Device-4: Tobii AB EyeChip type: USB driver: uvcvideo bus-ID: 1-9:7
chip-ID: 2104:030e class-ID: 0e02 serial:
Display: x11 server: [X.Org](http://X.Org) v: 21.1.5 with: Xwayland v: 22.1.6
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 128 s-size: 762x221mm (30.00x8.70")
s-diag: 793mm (31.24")
Monitor-1: DP-0 pos: left res: 1920x1080 dpi: 128
size: 380x220mm (14.96x8.66") diag: 439mm (17.29") modes: N/A
Monitor-2: DP-1 pos: primary,right res: 1920x1080 dpi: 90
size: 544x303mm (21.42x11.93") diag: 623mm (24.52") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce RTX 2070
Super/PCIe/SSE2 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel
bus-ID: 1-2.3:6 v: kernel chip-ID: 1038:12d7
alternate: snd_soc_skl,snd_sof_pci_intel_cnl class-ID: 0300
Device-2: NVIDIA TU104 HD Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7X type: USB
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
IF: wlo1 state: up mac:
Device-2: Realtek Killer E3000 2.5GbE vendor: Dell driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac:
bus-ID: 1-14:10 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address:
Local Storage: total: 4.34 TiB used: 3.59 TiB (82.8%)
model: PC SN730 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: 11170012 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 256GB
type: SSD serial: rev: 4B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: BUP Portable
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: rev: 1707 scheme: GPT
used: 391.74 GiB (82.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.11 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.0 C pch: 41.0 C mobo: N/A gpu: nvidia
temp: 39 C
Processes: 407 Uptime: 2m wakeups: 3 Memory: 31.11 GiB used: 3.6 GiB (11.6%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: 1676 pm: pacman pkgs: 1622 libs: 436
tools: octopi,paru pm: flatpak pkgs: 54 Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.24
Garuda (2.6.10-1):
System install date: 2022-11-23
Last full system update: 2022-12-17
_*,,,,,,,*
*โโโฃโซโ โ โ โ โ โ โ โ โ โ โ โ โ โโโโ*
โฅโขโ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โฅ,
โโ โ โ โ โ โ โ โโโโโโโขโ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ
โฃโ โ โ โ โ โ โ โ โขโฃโขโโ , `"โโ โ โ โ โ โ โ โ โ โ โ โ โ โ โโฅ_ [email protected] โโ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โโโฅโฅโ `"โโ โฌโ โ โ โ โ โ โ โ โ โ โ โฅ, -------------
โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โโฅโฅโฅโฅโโโฌโ โ โ โ โ โ โ โโโ โ โฃโ โ โ โ โขโ OS: Garuda Linux
โฃโ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โฅโฌโฃโ โ โ โ โ โ โ โ โ Host: Alienware Area-51m R2 1.17.0
โโ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ Kernel: 6.0.12-zen1-1-zen
โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ Uptime: 3 mins
โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โฌ ```"โโโขโ โ โก Packages: 1622 (pacman), 54 (flatpak)
โโ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โฃ, โโ โช Shell: bash
โโ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โขโ โ DE: Plasma 5.26.4
`โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ WM: KWin
,โฌโ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ "โ WM Theme: Sweet-Dark
โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ Terminal: yakuake
โ^โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โโฃโ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โ โก CPU: Intel i7-10700
(16) @ 4.8GHz โโ`โโโขโโ โกโขโ "โโ โ โโโโโ"โขโ โ โ โ โ โ โ โ โ โ โฃโฉโขโช GPU: NVIDIA GeForce RTX 2070 SUPER Mobile / Max-Q
โโ" `โ ` โโโ โโฃโ โ โ โ โ โโโ GPU: Intel CometLake-S GT2 [UHD Graphics 630]
โ โ โ Memory: 3.17GiB / 31.11GiB
