Hello there,
I am having an issue when i attempt to boot normally. I am still able to boot by going to recovery mode and allowing the GUI to start. My issue is the computer hangs stating the error:
"setfont KDEFONTOP: Function not implemented."
I have looked through other threads but the issue seems to persist. I attempted to place setfont in the binary and execute sudo mkinitcpio -P
link: (SOLVED) KDFONTOP function not implemented - #2 by filo
garuda-inxi:
Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=6cfa68c2-733a-450c-8621-cecc010a30c6 rw single
rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: B450 AORUS M v: x.x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: F50
date: 11/27/2019
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1732 high: 2800 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2800 2: 1550
3: 2668 4: 1375 5: 1550 6: 1550 7: 1550 8: 1550 9: 1550 10: 1550 11: 1550
12: 1550 bogomips: 81445
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 535.54.03
alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 07:00.0 chip-ID: 10de:1f82 class-ID: 0300
Device-2: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2
chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 4480x1440 s-dpi: 107 s-size: 1064x342mm (41.89x13.46")
s-diag: 1118mm (44")
Monitor-1: DP-0 pos: primary,left res: 2560x1440 dpi: 109
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 119
size: 410x230mm (16.14x9.06") diag: 470mm (18.51") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce GTX
1650/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 07:00.1 chip-ID: 10de:10fa class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
Device-3: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
vendor: Gigabyte driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
Local Storage: total: 2.73 TiB used: 99.69 GiB (3.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 43.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 056 scheme: MBR
used: 99.69 GiB (10.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 7.7 GiB used: 6.8 MiB (0.1%) priority: 100
System Temperatures: cpu: 43.4 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 285 Uptime: 7m wakeups: 0 Memory: available: 7.7 GiB
used: 3.66 GiB (47.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1930
libs: 384 tools: octopi,paru,yay Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2022-08-30
Last full system update: 2023-07-01
Thanks in advance,
Luke
