Hello. I did a reinstall after using Garuda for a good while, and I get an issue I've never had before.
During boot I have a message saying 'a start job is running for Wait for Network to be configured' which takes a good two minutes to complete. Is there something I can do to speed this up?
inxi -Faz
Kernel: 5.15.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=1e990d50-f7c1-4ded-a883-784141da6847 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3401
date: 12/04/2017
serial: <filter> charge: 100% (should be ignored) rechargeable: yes status:
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001129
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3047 high: 3232 min/max: 1550/3500 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3113 2: 2998
3: 2859 4: 3012 5: 3044 6: 3232 7: 3116 8: 3050 9: 3134 10: 2934 11: 2975
12: 3108 bogomips: 83843
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Vega 10 XL/XT [Radeon RX Vega 56/64] vendor: Sapphire Limited
driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:687f class-ID: 0300
Screen-1: 0 s-res: 4480x1601 s-dpi: 96 s-size: 1182x422mm (46.5x16.6")
s-diag: 1255mm (49.4")
Monitor-1: DisplayPort-0 res: 2560x1080 hz: 60 dpi: 81
size: 798x334mm (31.4x13.1") diag: 865mm (34.1")
Monitor-2: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: AMD Radeon RX Vega (VEGA10 DRM 3.42.0 5.15.8-zen1-1-zen
LLVM 13.0.0)
v: 4.6 Mesa 21.3.1 direct render: Yes
Device-1: AMD Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel
v: kernel bus-ID: 0a:00.1 chip-ID: 1002:aaf8 class-ID: 0403
v: kernel bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: RODE Microphones RODE NT-USB type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4:3 chip-ID: 19f7:0003
Sound Server-1: ALSA v: k5.15.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.41 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-3:2 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 2.61 TiB used: 1.47 TiB (56.2%)
rev: 2B2QEXM7 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1500LM006 HN-M151RAD
size: 1.36 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0008 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT120BX100SSD1
type: SSD serial: <filter> rev: MU01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 QVO 1TB
used: 55.22 GiB (23.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.62 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 36.0 C
mem: 31.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1202
Processes: 435 Uptime: 7m wakeups: 2 Memory: 15.62 GiB
used: 4.93 GiB (31.6%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1956 pacman: 1941 lib: 546 flatpak: 15
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: kitty inxi: 3.3.10
I haven't tried anything yet, as I'm not sure if this is a specific Garuda thing or a general thing.
Edit: picture of the boot screen
