Hi Garuda dragons
I have just installed Garuda Dragonized edition.
I am running it on dual 1080p monitors but every time the monitor gets in sleep mode (or I switched it off manually) everything resets and all open apps go to the secondary monitor (to the left).
I did tried to run X11 commands but couldn't do it properly as it's not working. One of my monitors is connected via Display Port and the other one HDMI.
Here's my setup
Kernel: 5.19.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=6135c6f1-9f5b-4e40-8fee-77877b12eec8 rw rootflags=subvol=@
resume=UUID=b6fc4d17-5825-4526-819b-74208cc39d04 loglevel=3
Mobo: ASUSTeK model: TUF GAMING Z490-PLUS v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2210
date: 01/15/2021
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 5 microcode: 0xF0
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3311 high: 3800 min/max: 800/5100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 3800 3: 3800
4: 3800 5: 1377 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800
12: 1402 13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121596
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 ports: active: DP-1,HDMI-A-1
empty: DP-2,DP-3 bus-ID: 0000:03:00.0 chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech Logi 4K Stream Edition type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-4:2
chip-ID: 046d:086b class-ID: 0300 serial: <filter>
s-diag: 1052mm (41.43")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Acer VG270
serial: <filter> built: 2021 res: 1920x1080 hz: 75 dpi: 82 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Acer VG270
OpenGL: renderer: AMD Radeon RX 5600 XT (navi10 LLVM 14.0.6 DRM 3.47
5.19.6-zen1-1-zen) v: 4.6 Mesa 22.1.7 direct render: Yes
v: kernel bus-ID: 1-1:2 chip-ID: 0d8c:0134
alternate: snd_soc_skl,snd_sof_pci_intel_cnl class-ID: 0300
bus-ID: 0000:00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 0000:03:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-3: C-Media TONOR TC-777 Audio Device type: USB
Device-4: Logitech Logi 4K Stream Edition type: USB
Sound Server-1: ALSA v: k5.19.6-zen1-1-zen running: yes
port: N/A bus-ID: 0000:00:1f.6 chip-ID: 8086:0d4d class-ID: 0200
Device-2: Microsoft XBOX ACC type: USB driver: mt76x2u bus-ID: 1-3.2:5
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
IF: wlp0s20f0u3u2 state: down mac: <filter>
Hardware-1: Intel Comet Lake PCH-H RAID driver: intel_nvme_remap v: N/A
port: 4020 bus-ID: 0000:00:17.0 chip-ID: 8086:06d6 rev: class-ID: 0104
Local Storage: total: 2.85 TiB used: 29.87 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 2B2QEXM7 temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
type: SSD serial: <filter> rev: 4B0Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 896.85 GiB size: 896.85 GiB (100.00%) used: 29.87 GiB
(3.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.85 GiB size: 896.85 GiB (100.00%) used: 29.87
GiB (3.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 896.85 GiB size: 896.85 GiB (100.00%) used: 29.87
ID-5: /var/tmp raw-size: 896.85 GiB size: 896.85 GiB (100.00%) used: 29.87
ID-1: swap-1 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
mem: 58.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 811
Processes: 387 Uptime: 1h 5m wakeups: 0 Memory: 31.24 GiB used: 6.45 GiB
(20.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pacman: 1441 lib: 426
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-09-04
Last full system update: 2022-09-04 ↻
Snapshots: Snapper (maybe)
I would appreciate step by step guide as I am truly a newbie ![]()
Thank you
Kiril
