So I am unable to get (min) 2 monitors to display how I would like worskpaces configured.
With the main monitor, I see the taskbar, with the workspace switcher, and there are essentially 8 workspaces grouped by 2's. Laptop monitor would call 'A', and monitor on the Intel driven HDMI port can call 'B'.
When I click one of the 4 groupings, I get 1A on the laptop, and 1B on the attached monitor.
When I click on another of the groupings, I get 2A on the laptop, and 2B on the attached... Likewise for the workspace groupings 3 and 4.
What I am wanting to drive is essentially laptop monitor with 4 workspaces, and the attached monitor with one unchanging 'workspace'. So basically 1A, 2A, 3A, 4A, and B (or 5B?).
I've read this post and this, installed randr, and poked through a bunch of the wiki and search results and cannot find much information on this distinction with config. Looked into xrandr, bumblebee, arch wiki multihead + extreme multihead.
Admittedly x config stuff is super new to me, as is virtualization of displays. I've played with remote desktop stuff and x forwarding under windows host in the past, but yea, super green with this.
Eventually, I would like to drive primary laptop display with 4 external monitors (3 with the nvidia output (usb-c -> displayport adapter -> displayport MST hub -> monitors), and one with the HDMI/Intel output).
An example of current workspace on taskbar and some config windows.
Here is the xrandr output...
[whiskerbins@thisherelaptop ~]$ xrandr --current
Screen 0: minimum 8 x 8, current 5460 x 1124, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+3540+44 (normal left inverted right x axis y axis) 885mm x 498mm
1920x1080 60.00*+ 59.94 50.00 29.97 25.00 23.98
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1366x768 59.79
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-3 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 60.00*+
DP-4 disconnected (normal left inverted right x axis y axis)
And output of the following required command:
$ garuda-inxi
system:
Kernel: 5.15.73-3-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=52215bb2-0315-4c48-9d72-6c45dfc43166 rw rootflags=subvol=@
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20QNS00P00 v: ThinkPad P53
Mobo: LENOVO model: 20QNS00P00 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N2NET40W (1.25 )
date: 08/26/2020
ID-1: BAT0 charge: 83.6 Wh (100.0%) condition: 83.6/90.0 Wh (92.9%)
volts: 12.7 min: 11.2 model: SMP 02DL028 type: Li-poly serial: <filter>
status: full cycles: 20
Info: model: Intel Core i7-9850H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1006 high: 2580 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800
4: 1348 5: 2580 6: 951 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 62399
prctl and seccomp
Device-1: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1fb8
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:4 chip-ID: 13d3:56bc class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5460x1124 s-dpi: 97 s-size: 1435x295mm (56.50x11.61")
s-diag: 1465mm (57.68")
Monitor-1: DP-3 pos: primary,top-left res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
Monitor-2: HDMI-0 pos: bottom-r res: 1920x1080 hz: 60 dpi: 55
size: 885x498mm (34.84x19.61") diag: 1015mm (39.98") modes: N/A
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
Sound API: ALSA v: k5.15.73-3-lts running: yes
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 52:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp82s0 state: up mac: <filter>
bus-ID: 1-14:6 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 476.94 GiB used: 165.04 GiB (34.6%)
model: MZVLB512HBJQ-000L7 size: 476.94 GiB block-size: physical: 512 B
rev: 5M2QEXF7 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 373.32 GiB size: 373.32 GiB (100.00%) used: 165.04 GiB
(44.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 373.32 GiB size: 373.32 GiB (100.00%) used: 165.04
GiB (44.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 373.32 GiB size: 373.32 GiB (100.00%) used: 165.04
ID-5: /var/tmp raw-size: 373.32 GiB size: 373.32 GiB (100.00%) used: 165.04
ID-1: swap-1 type: zram size: 93.99 GiB used: 9 MiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C pch: 50.0 C mobo: N/A gpu: nvidia
temp: 44 C
Fan Speeds (RPM): fan-1: 1960 fan-2: 1988
Processes: 386 Uptime: 3h 29m wakeups: 12956 Memory: 93.99 GiB used: 7.63
GiB (8.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1533 libs: 378
tools: paru Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-09-21
Last full system update: 2022-10-20 ↻
Windows dual boot: Probably (Run as root to verify) [NO!]
Failed units: dev-binderfs.mount systemd-networkd-wait-online.service
Thanks in advance. Even just hitting me with a good search term or a link with little explanation would be of assistance, as I would really like to learn this configuration properly.
-whiskerbins
