Hello! I have 2 identical Dell P2719H monitors. When I installed garuda, the default monitor setup in KDE settings → Display and Monitors worked perfectly (both side-by-side).
Today I cleaned my setup, so had to unplug and replug the monitors. Now both are showing up in KDE settings, but only one shows display, other shows black screen
(i.e. it’s not that the monitor isn’t detected…it is, but isn’t showing display.)
I can even move a window to the black monitor. But the monitor complains it isn’t receiving a signal. -
Things I tried:
a. Unplugging and replugging hdmi cable, power cable to monitor.
b.garuda-update -
My GPU is an NVIDIA GTX 1650 Super. The working monitor is plugged in via displayport, and the black-screen one is plugged to the VGA port via an HDMI-to-VGA adapter.
garuda-inxi:
root=UUID=aeb3c7e0-45af-4344-ba3f-05339ad86d76 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: Gigabyte model: B550M DS3H AC v: x.x
Megatrends LLC. v: F15 date: 07/29/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3698 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3619 2: 3593
3: 3800 4: 3800 5: 3800 6: 3613 7: 3800 8: 3593 9: 3588 10: 3800 11: 3594
12: 3592 13: 3800 14: 3800 15: 3591 16: 3800 bogomips: 121372
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: ASUSTeK
driver: nvidia v: 555.58 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none off: DP-1,DVI-D-1,HDMI-A-1 empty: none
bus-ID: 06:00.0 chip-ID: 10de:2187 class-ID: 0300
Device-2: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:2 chip-ID: 17ef:4831
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 3840x1080 s-dpi: 80 s-size: 1219x343mm (47.99x13.50")
s-diag: 1266mm (49.86")
Monitor-1: DP-0 pos: left res: 1920x1080 hz: 60 dpi: 82
Monitor-2: DVI-D-0 pos: primary,right res: 1920x1080 hz: 60 dpi: 82
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650
SUPER/PCIe/SSE2 memory: 3.91 GiB
API: Vulkan v: 1.3.204 layers: 20 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 SUPER driver: nvidia v: 555.58 device-ID: 10de:2187
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 17.0.6 256
bits) driver: mesa llvmpipe v: 24.1.2-arch1.1 (LLVM 17.0.6)
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
bus-ID: 06:00.1 chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0aa7
Device-1: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 1948792416 chunk-size: N/A
Components: Online: N/A Spare:
1: sda3 maj-min: 8:3 size: 1.81 TiB state: S
Local Storage: total: 4.1 TiB used: 287.6 GiB (6.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 40.9 C scheme: GPT
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: MBR
fw-rev: 0A80 scheme: GPT
used: 286.8 GiB (60.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.52 GiB used: 22.5 MiB (0.1%)
System Temperatures: cpu: 55.6 C mobo: 31.0 C gpu: nvidia temp: 38 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 27%
Memory: total: 16 GiB available: 15.52 GiB used: 7.49 GiB (48.3%)
Processes: 421 Power: uptime: 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: 2545 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr
pkgs: 0 pm: pacman pkgs: 2544 libs: 531 tools: gnome-software, octopi,
pamac, paru, yay pm: flatpak pkgs: 1 Compilers: clang: 17.0.6 gcc: 14.1.1
alt: 13 Shell: garuda-inxi default: Zsh v: 5.9 running-in: konsole
inxi: 3.3.35
System install date: 2022-01-29
Last full system update: 2024-06-30
xrandr --query(shows both connected)
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
DVI-D-0 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.00*+ 59.94 50.00
1600x900 60.00
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.00*+
1600x900 60.00
1152x864 75.00
800x600 75.00 60.32
640x480 75.00 59.94
DP-1 disconnected (normal left inverted right x axis y axis)
KDE settings screenshot
hwinfo --monitor(this also shows a Viewsonic monitor which I had plugged in in the past)
47: None 00.0: 10002 LCD Monitor
[Created at monitor.125]
Unique ID: rdCR.yYALby+5NDB
Parent ID: vTuk.XIT6vbyxYaB
Hardware Class: monitor
Model: "VIEWSONIC VX2453 Series"
Vendor: VSC "VIEWSONIC"
Device: eisa 0x0c28 "VX2453 Series"
Serial ID: "SDA113811418"
Resolution: 720x400@70Hz
Resolution: 640x480@60Hz
Resolution: 640x480@67Hz
Resolution: 640x480@72Hz
Resolution: 640x480@75Hz
Resolution: 800x600@56Hz
Resolution: 800x600@60Hz
Resolution: 800x600@72Hz
Resolution: 800x600@75Hz
Resolution: 832x624@75Hz
Resolution: 1024x768@60Hz
Resolution: 1024x768@70Hz
Resolution: 1024x768@75Hz
Resolution: 1280x1024@75Hz
Resolution: 1600x1200@60Hz
Resolution: 1400x1050@60Hz
Resolution: 1920x1080@60Hz
Year of Manufacture: 2011
Week of Manufacture: 38
Detailed Timings #0:
Horizontal: 1920 2008 2052 2200 (+88 +132 +280) +hsync
Vertical: 1080 1084 1089 1125 (+4 +9 +45) +vsync
Frequencies: 148.50 MHz, 67.50 kHz, 60.00 Hz
Driver Info #0:
Max. Resolution: 1920x1080
Vert. Sync Range: 50-76 Hz
Hor. Sync Range: 15-83 kHz
Bandwidth: 148 MHz
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #28 (VGA compatible controller)
48: None 01.0: 10002 LCD Monitor
Unique ID: wkFv.6IuzdQ_p8a2
Model: "DELL P2719H"
Vendor: DEL "DELL"
Device: eisa 0x4185 "DELL P2719H"
Serial ID: "3VWB623"
Resolution: 1152x864@75Hz
Resolution: 1280x1024@60Hz
Resolution: 1600x900@60Hz
Year of Manufacture: 2020
Week of Manufacture: 49
Driver Info #0:
Vert. Sync Range: 56-76 Hz
Hor. Sync Range: 30-83 kHz
Bandwidth: 148 MHz
49: None 02.0: 10002 LCD Monitor
Unique ID: +rIN.1MJC74s9H3D
Vendor: DEL "DELL"
Device: eisa 0x4184 "DELL P2719H"
Serial ID: "12YB623"
Driver Info #0:
Bandwidth: 148 MHz
- Help will be much appreciated. Thank you!
