I'm looking for assistance on Dual Booting and installing Garuda on my external SSD which currently has Wintousb installed on it, i am unable to partition the wintousb volume using the windows disk utility
Or, if gparted is not available in the edition you want to install, search there partition manager, which is for sure available in all the KDE based editions.
Yes, free version of AOMEI and I think it does a good job. You can also format disks in the Linux Ext family as well as the normal ones. What I particularly like is if has Chkdsk functions as well as a Defragger. The Free version is slightly limited in other areas that the (inexpensive) Paid version does but I do not recall what they are. Meanwhile, I'll check out your link, and thank you.
