Driver installation NVIDIA GeForce GTS 250, for Dota 2. Please help.
alex@alex in ~
λ garuda-inxi
Kernel: 5.16.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=4e96d3d8-1bb3-49a1-b65b-83f5633b155e rw rootflags=subvol=@
resume=UUID=bdfc7c0d-289c-4a23-be83-c530e6046560 loglevel=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop Mobo: MSI model: H55M-P31(MS-7636) v: 1.0
serial: <superuser required> BIOS: American Megatrends v: 1.3
date: 12/21/2009
Info: model: Intel Core i3 530 bits: 64 type: MT MCP arch: Westmere
family: 6 model-id: 0x25 (37) stepping: 2 microcode: 0x11
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2246 high: 2922 min/max: 1200/2933 scaling:
driver: acpi-cpufreq governor: performance cores: 1: 1462 2: 1847 3: 2756
4: 2922 bogomips: 23408
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: NVIDIA G92 [GeForce GTS 250] driver: nouveau v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: VGA-1
empty: DVI-I-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:0615 class-ID: 0300
Device-2: Z-Star Micro Venus USB2.0 Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.4:5 chip-ID: 0ac8:3420
class-ID: 0102
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa gpu: nouveau
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: VGA-1 model: LG (GoldStar) E2040 serial: <filter> built: 2010
res: 1600x900 hz: 60 dpi: 92 gamma: 1.2 size: 443x249mm (17.4x9.8")
diag: 515mm (20.3") ratio: 16:9 modes: max: 1600x900 min: 720x400
OpenGL: renderer: NV92 v: 3.3 Mesa 21.3.7 direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
class-ID: 0102
Sound Server-1: ALSA v: k5.16.9-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
lanes: 1 port: e800 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros AR2417 Wireless Network Adapter [AR5007G
802.11bg]
driver: ath5k v: kernel bus-ID: 03:00.0 chip-ID: 168c:001d class-ID: 0200
bus-ID: 2-1.1:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 931.53 GiB used: 499.43 GiB (53.6%)
model: WD2500AAKX-073CA1 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1H17
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS721050CLA362
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A39C scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: HD252HJ
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1113 scheme: MBR
ID-1: / raw-size: 100.04 GiB size: 100.04 GiB (100.00%)
used: 38.25 GiB (38.2%) fs: btrfs dev: /dev/sda8 maj-min: 8:8
ID-2: /boot raw-size: 5 GiB size: 5 GiB (100.00%) used: 136.1 MiB (2.7%)
fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-3: /home raw-size: 100.04 GiB size: 100.04 GiB (100.00%)
ID-4: /var/log raw-size: 100.04 GiB size: 100.04 GiB (100.00%)
ID-5: /var/tmp raw-size: 100.04 GiB size: 100.04 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.69 GiB used: 657.8 MiB (8.4%)
ID-2: swap-2 type: partition size: 7.84 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nouveau temp: 50.0 C
Processes: 273 Uptime: 5h 54m wakeups: 0 Memory: 7.69 GiB
used: 3.83 GiB (49.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1885 lib: 547 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-02-16
Last full system update: 2022-02-27
