Just updated my roommates machine today and Garuda would not go to the desktop. I rebooted and waited 5 minutes and nothing. I proceeded to reboot and chose the last snapshot from yesterday. It also did not go to the desktop. I let it set to see if it just needed time. When I went to check on it it was setting on a black screen with this message.
[[122.682556] dracut-initqueue[480]: timed out for waiting the udev queue being
Will add once I go back to his system and get it.
EDIT:
Rebooted and left the system set while I went to have a smoke and when I came back it was finally on the desktop after I left it on the screen with the Dracut message. Looks like the system didn't rollback to the Snapshot I chose. I'm assuming that's because I did another restart before Garuda could go to the desktop.
I'm assuming Dracut is having a issue so I guess I need to know how to check it and possibly troubleshoot it if possible. Thanks
βββ ~ ξ° garuda-inxi
Kernel: 6.4.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=c1cfc15c-efa8-4eb9-87c2-ffcc59c77ecc rw rootflags=subvol=@
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2 gen: 3
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3602 high: 3620 min/max: 2200/3906 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3600 4: 3600 5: 3600 6: 3600 7: 3620 8: 3600 bogomips: 57491
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1 bus-ID: 0a:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 45.0 C
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Acer ED322Q serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 815mm (32.1") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon RX 580 Series
(polaris10 LLVM 15.0.7 DRM 3.52 6.4.7-zen1-1-zen) direct-render: Yes
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:aaf0 class-ID: 0403
API: ALSA v: k6.4.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:15f3
IF: enp9s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 1-10.4:11 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 15.86 TiB used: 9.34 TiB (58.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SWORDFISH
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: VC0S032V temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO M.2 120GB
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: Expansion Desk
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 0915 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST330006 50NS
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 7101 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: HGST (Hitachi)
model: HUS 728T8TALE6L4 size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: N/A serial: <filter> fw-rev: 7101 scheme: GPT
ID-6: /dev/sdf maj-min: 8:80 vendor: SanDisk model: USB 3.2Gen1
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
used: 21.2 GiB (9.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 41.1 C mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 2061
Processes: 333 Uptime: 19m wakeups: 4 Memory: total: 16 GiB
available: 15.53 GiB used: 4.3 GiB (27.7%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages: 2154
pm: pacman pkgs: 2142 libs: 552 tools: octopi,pamac,pikaur,yay pm: flatpak
pkgs: 5 pm: snap pkgs: 7 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.28
System install date: 2023-07-21
Last full system update: 2023-07-30
Live ISO, chroot, update in terminal.
I'm assuming that means there is a update coming to address it? Thanks
EDIT:
SGS I take care of both Gary's and my machines and I don't have my login on this machine and visa versa.
There are changes in fstab or something else?
Hardware connections are ok?
SATA, external drives β¦
hey garuda users.
I was updating my system today and got this random error I am not too sure to ignore.
( 5/27) Reloading device manager configuration...
Timed out for waiting the udev queue being empty.
I searched for this issue online but the only results I got were related to boot issues with long boot time which made me more confused and hence here I am for help.
I have attached the full update command output here in privatebin in case it's needβ¦
Check to see if the fallback image boots normally. If it does, run dracut-rebuild and examine the output for errors.
Think I'll leave it for not cause it's not hurting anything. On reboots they're usually just I update the system for him and then I walk away, so waiting a few minutes for it to boot to the desktop I can live with.
system
Closed
14 August 2023 10:38
10
