hey garuda users.
I was updating my system today and got this random error I am not too sure to ignore.
( 5/27) Reloading device manager configuration...
Timed out for waiting the udev queue being empty.
I searched for this issue online but the only results I got were related to boot issues with long boot time which made me more confused and hence here I am for help.
I have attached the full update command output here in privatebin in case it's needed
Yeah that always happens. I think powersave tweaks is the package reponsible for it since it started happening after installing it. I checked forum for it once before where filo mentioned an archwiki article explaining how this can be overcome with a kernel parameter but it says this is not for everyone and checking my system and according to archwiki it would be better to ignore that warning.
Thanks for searching meanruse I am sadly not smart enough to understand if I should just ignore this warning like the above one or I need to take some action.
Yeah I wasn't worried about this since we already have a forum post from filo regarding this linking to this archwiki article that explains why this error occurred and how to resolve it if the device supports aspm which in my case isn't.
I am more concerned about the original error in the main post. Though I guess since it's only happened once and hasn't caused any apparent issues yet it should be safe to ignore.
I see I guess I will ignore this for now since I have only faced this issue once and haven't faced any apparent problems yet with my system. I guess I will update my system again today and close the issue if I don't see this error again.
I am guessing the package that triggers reloading device manager configuration hasn't been updated yet
╰─λ garuda-update
[sudo] password for siddharth:
garuda 96.9 KiB 6.23 KiB/s 00:16 [------------------------------------] 100%
core 132.5 KiB 14.0 KiB/s 00:09 [------------------------------------] 100%
extra 8.3 MiB 303 KiB/s 00:28 [------------------------------------] 100%
multilib 141.3 KiB 15.0 KiB/s 00:09 [------------------------------------] 100%
chaotic-aur 2.5 MiB 129 KiB/s 00:19 [------------------------------------] 100%
error: failed retrieving file 'core.db' from mirror.moson.org : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'extra.db' from mirror.moson.org : Connection time-out
error: failed retrieving file 'multilib.db' from mirror.moson.org : Connection time-out
warning: too many errors from mirror.moson.org, skipping for the remainder of this transaction
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
warning: reflector-simple: local (2.0-1.1) is newer than garuda (2.0-1)
resolving dependencies...
Packages (7) dolphin-23.04.1-2 ffmpeg-2:6.0-8 gegl-0.4.44-3 gimp-2.10.34-2 iputils-20221126-2
pam-1.5.3-3 python-pydantic-1.10.8-1
Total Download Size: 41.77 MiB
Total Installed Size: 189.16 MiB
Net Upgrade Size: 0.71 MiB
:: Retrieving packages...
python-pydantic-1.10.8-1-x86_64 1963.7 KiB 183 KiB/s 00:11 [------------------------------------] 100%
gegl-0.4.44-3-x86_64 3.0 MiB 225 KiB/s 00:14 [------------------------------------] 100%
pam-1.5.3-3-x86_64 911.3 KiB 262 KiB/s 00:03 [------------------------------------] 100%
iputils-20221126-2-x86_64 115.4 KiB 181 KiB/s 00:01 [------------------------------------] 100%
dolphin-23.04.1-2-x86_64 4.4 MiB 288 KiB/s 00:16 [------------------------------------] 100%
gimp-2.10.34-2-x86_64 20.0 MiB 780 KiB/s 00:26 [------------------------------------] 100%
ffmpeg-2:6.0-8-x86_64 11.4 MiB 433 KiB/s 00:27 [------------------------------------] 100%
Total (7/7) 41.8 MiB 1578 KiB/s 00:27 [------------------------------------] 100%
(7/7) checking keys in keyring [------------------------------------] 100%
(7/7) checking package integrity [------------------------------------] 100%
(7/7) loading package files [------------------------------------] 100%
(7/7) checking for file conflicts [------------------------------------] 100%
(7/7) checking available disk space [------------------------------------] 100%
==> root: 365
(1/7) upgrading pam [------------------------------------] 100%
(2/7) upgrading ffmpeg [------------------------------------] 100%
(3/7) upgrading dolphin [------------------------------------] 100%
(4/7) upgrading gegl [------------------------------------] 100%
(5/7) upgrading gimp [------------------------------------] 100%
New optional dependencies for gimp
ghostscript: for PostScript support [installed]
(6/7) upgrading iputils [------------------------------------] 100%
(7/7) upgrading python-pydantic [------------------------------------] 100%
( 1/10) Reloading system manager configuration...
( 2/10) Creating temporary files...
Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
( 3/10) Arming ConditionNeedsUpdate...
( 4/10) Foreign/AUR package notification
rootactions-servicemenu 2.7.3-1
ttf-ms-win11-auto 10.0.22621.525-1
( 5/10) Orphaned package notification...
lua53 5.3.6-1
sysfsutils 2.1.1-1
( 6/10) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/default/grub.pacnew
/etc/pacman.conf.pacnew
/etc/plymouth/plymouthd.conf.pacnew
/etc/plymouth/plymouthd.conf.pacsave
Please check and merge
( 7/10) Updating icon theme caches...
( 8/10) Updating the desktop file MIME type cache...
( 9/10) Performing snapper post snapshots for the following configurations...
==> root: 366
(10/10) Syncing all file systems...
System updated! 🐧
╭─[email protected] in ~ as 🧙 took 2m23s
61%
╰─λ cleanup
checking dependencies...
Packages (2) lua53-5.3.6-1 sysfsutils-2.1.1-1
Total Removed Size: 1.13 MiB
:: Do you want to remove these packages? [Y/n]
==> root: 367
(1/2) removing sysfsutils [------------------------------------] 100%
(2/2) removing lua53 [------------------------------------] 100%
(1/6) Arming ConditionNeedsUpdate...
(2/6) Foreign/AUR package notification
(3/6) Orphaned package notification...
=> No orphans found.
(4/6) Checking for .pacnew and .pacsave files...
.pac* files found:
(5/6) Performing snapper post snapshots for the following configurations...
==> root: 368
(6/6) Syncing all file systems...
Though I will just close the thread since I don't really see any apparent issues with my device yet and will just create another thread in case something does pop up or this issue appears again.
