dracut[E]: Module 'systemd-pcrphase' depends on 'tpm2-tss', which can't be installed
Since a couple of weeks every update give me this error message:
:: Building initramfs for linux-zen (6.9.6-zen1-1-zen)
But, my systems seems to be good.
  Kernel: 6.9.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=e38ee0d4-0c6f-4526-9adf-c7cf1a1f23b5 rw rootflags=subvol=@
  Desktop: Cinnamon v: 6.2.0 tk: GTK v: 3.24.42 wm: Muffin v: 6.2.0 tools:
    avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: VIQYx v: INVALID
    serial: <superuser required> Chassis: type: 10 v: INVALID
  Mobo: LENOVO model: VIQY0Y1 v: 31900006WIN8 STD MBR IPG
    serial: <superuser required> part-nu: LENOVO_BI_IDEAPAD
    uuid: <superuser required> UEFI: LENOVO v: 74CN26WW(107T22)
    date: 05/09/2013
  ID-1: BAT1 charge: 42.0 Wh (100.0%) condition: 42.0/56.4 Wh (74.4%)
    power: 655.4 W volts: 12.1 min: 10.8 model: LENOVO PABAS0241231 type: Li-ion
    serial: <filter> status: full
  Info: model: Intel Core i7-4700MQ bits: 64 type: MT MCP arch: Haswell
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 2646 high: 3400 min/max: 800/3400 scaling:
    driver: intel_cpufreq governor: performance cores: 1: 2394 2: 2400 3: 2395
    4: 3400 5: 2394 6: 2395 7: 2395 8: 3400 bogomips: 38312
  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
    driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
    active: VGA-1,eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0416
  Device-2: NVIDIA GK107M [GeForce GT 750M] vendor: Lenovo driver: nvidia
    v: 470.256.02 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
    status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
    process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:0fe4 class-ID: 0300
  Device-3: Realtek Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0bda:58b9
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa
    dri: crocus gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2966x900 s-dpi: 96 s-size: 784x238mm (30.87x9.37")
    s-diag: 819mm (32.26")
  Monitor-1: VGA-1 pos: left model: LG (GoldStar) 20EN33 serial: <filter>
    built: 2013 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
    size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes:
    max: 1600x900 min: 720x400
  Monitor-2: eDP-1 pos: primary,right model: LG Display 0x033a built: 2011
    res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia platforms: device: 0
    drv: nvidia device: 2 drv: crocus device: 3 drv: swrast surfaceless:
    drv: swrast x11: drv: crocus inactive: gbm,wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.1.2-arch1.1
    device-ID: 8086:0416 surfaces: xcb,xlib device: 1 type: discrete-gpu
    name: NVIDIA GeForce GT 750M driver: nvidia v: 470.256.02
    device-ID: 10de:0fe4 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
    (LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.2-arch1.1 (LLVM
    vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  Device-3: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
  Device-4: Kingston HyperX QuadCast
    lanes: 1 mode: 1.1 bus-ID: 3-4.4.2:9 chip-ID: 0951:16df class-ID: 0300
  API: ALSA v: k6.9.6-zen1-1-zen status: kernel-api tools: N/A
  Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Lenovo
    driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 08:00.0 chip-ID: 1969:10a1 class-ID: 0200
  Device-2: Broadcom BCM4352 802.11ac Dual Band Wireless Network Adapter
    vendor: Lenovo driver: wl v: kernel modules: bcma pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 09:00.0 chip-ID: 14e4:43b1 class-ID: 0280
  IF: wlp9s0 state: down mac: <filter>
  Device-1: Realtek Bluetooth 5.1 Radio driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4.2:6
    chip-ID: 0bda:a725 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci1 rfk-id: 3 state: up address: <filter> bt-v: 5.1
  Device-2: Lite-On BCM20702A0 driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:5 chip-ID: 04ca:200b
  Report: ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.0 lmp-v: 6
    status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 2.27 TiB used: 1.03 TiB (45.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
  ID-1: / raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
    used: 41.38 GiB (41.2%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
  ID-2: /boot/efi raw-size: 1.86 GiB size: 1.86 GiB (99.80%)
    used: 584 KiB (0.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw-size: 309.96 GiB size: 309.96 GiB (100.00%)
    used: 194.33 GiB (62.7%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
  ID-4: /var/log raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
  ID-5: /var/tmp raw-size: 100.42 GiB size: 100.42 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 20.12 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 75.0 C mobo: N/A
  Memory: total: 16 GiB note: est. available: 15.35 GiB used: 5.2 GiB (33.9%)
  Processes: 374 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.11 GiB services: csd-power,upowerd
  Packages: pm: pacman pkgs: 1535 libs: 424 tools: octopi,paru Compilers:
    clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
    running-in: gnome-terminal inxi: 3.3.35
  System install date:     2024-02-04
  Last full system update: 2024-06-23
Any suggestions?
My hardware haven’t TPM. So, this error is only because the update can’t install the module for a hardware that haven’t TPM?
Then, this is not an error?
Yes, you can stay calm, this is NOT an error !!
i have seen same message, when upgrading the Kernel.
Dracut reports this as an error (“[E]” is how dracut announces errors), although for all intents and purposes it is more of an informational warning. You can follow the upstream discussion in this issue if you are interested:
You can also simply exclude the systemd-pcrphase module from the initramfs and dracut will stop trying to add tpm2-tss.
