Dracut[E]: Module problem
This is more of a heads up then asking for help as you can see I’m on Catchy kernel but lts an zen have been having the same build error with dracut which is under the inxi.
The update finishes but, yeah the module errors out. tpm2-tss is installed just fine on the system. As for systemd-pcrphase not sure how to check on that.
All I really know is I’ve seen this error since 6.9.4. but yep just a heads up.
  Kernel: 6.9.4-1-cachyos arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=ed618e85-c1b1-4a62-9eef-7263837ec30d rw rootflags=subvol=@
    resume=UUID=9e39bce2-8148-4e68-83a2-8185da8c85fb loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
  Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
    UEFI: American Megatrends v: 4802 date: 06/15/2023
  Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 4245 high: 4351 min/max: 2200/4426 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 4325 2: 4351
    3: 3600 4: 4288 5: 4325 6: 4324 7: 4287 8: 4324 9: 4329 10: 3836 11: 4325
    12: 4322 13: 4324 14: 4323 15: 4324 16: 4327 bogomips: 115194
  Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] vendor: Sapphire
    driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
    built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
    empty: DP-2, HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 0c:00.0
    chip-ID: 1002:744c class-ID: 0300
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 res: 3440x1440 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd v: N/A glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 7900 GRE (radeonsi navi31 LLVM
    17.0.6 DRM 3.57 6.9.4-1-cachyos) device-ID: 1002:744c memory: 15.62 GiB
    unified: no display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 GRE (RADV NAVI31) driver: mesa radv
    v: 24.2.0-devel (git-15257b65c6) device-ID: 1002:744c
    17.0.6 256 bits) driver: mesa llvmpipe v: 24.2.0-devel (git-15257b65c6)
    (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab30
    bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Texas Instruments PCM2900C Audio CODEC
    lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 08bb:29c0 class-ID: 0300
  API: ALSA v: k6.9.4-1-cachyos status: kernel-api with: aoss
    speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:08b1 class-ID: 0280
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:5 chip-ID: 8087:07dc
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
    lmp-v: 6 sub-v: e00 hci-v: 6 rev: e00 class-ID: 6c0104
  Info: acl-mtu: 1021:5 sco-mtu: 96:6 link-policy: rswitch hold sniff
    link-mode: peripheral accept service-classes: rendering, capturing, audio,
    telephony
  Local Storage: total: 6.5 TiB used: 3.18 TiB (48.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX920 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 32A0T2IA temp: 40.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 44.9 C
  ID-3: /dev/nvme2n1 maj-min: 259:11 vendor: Western Digital
    model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 731100WD temp: 49.9 C scheme: GPT
  ID-4: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX3 size: 111.79 GiB
    serial: <filter> fw-rev: 2.22 scheme: GPT
  ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD20EZAZ-00L9GB0 size: 1.82 TiB block-size: physical: 4096 B
    fw-rev: 0A80 scheme: GPT
  ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 1018.85 GiB (55.2%)
    fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:9
    used: 27.6 MiB (9.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:8
    used: 1018.85 GiB (55.2%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:9
  ID-1: swap-1 type: zram size: 15.53 GiB used: 5.51 GiB (35.5%)
  ID-2: swap-2 type: partition size: 17.07 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:10
  System Temperatures: cpu: 43.0 C mobo: 40.0 C gpu: amdgpu temp: 45.0 C
    mem: 65.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 608
  Memory: total: 16 GiB available: 15.53 GiB used: 5.73 GiB (36.9%)
  Processes: 491 Power: uptime: 11h 30m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 1 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
  Packages: 2560 pm: pacman pkgs: 2532 libs: 625 tools: octopi,pacseek,paru
    pm: flatpak pkgs: 28 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
    default: fish v: 3.7.1 running-in: kitty inxi: 3.3.34
  System install date:     2024-05-15
  Last full system update: 2024-06-17
(12/24) upgrading lib32-gettext                                           [------------------------------------------] 100%
(13/24) upgrading lib32-libcups                                           [------------------------------------------] 100%
(14/24) upgrading lib32-libnghttp3                                        [------------------------------------------] 100%
(15/24) upgrading linux-headers                                           [------------------------------------------] 100%
(16/24) upgrading linux-lts                                               [------------------------------------------] 100%
(17/24) upgrading linux-lts-headers                                       [------------------------------------------] 100%
(18/24) upgrading linux-zen                                               [------------------------------------------] 100%
(19/24) upgrading linux-zen-headers                                       [------------------------------------------] 100%
(20/24) upgrading minecraft-launcher                                      [------------------------------------------] 100%
New optional dependencies for minecraft-launcher
org.freedesktop.secrets: persistent login support [installed]
(21/24) upgrading perl-html-tagset                                        [------------------------------------------] 100%
(22/24) upgrading rustup-git                                              [------------------------------------------] 100%
You may need to run rustup self upgrade-data
(23/24) upgrading spatialindex                                            [------------------------------------------] 100%
(24/24) upgrading talloc                                                  [------------------------------------------] 100%
( 1/16) Restoring Linux kernel modules...
++ uname -r
+ KVER=6.9.4-1-cachyos
+ test -e /usr/lib/modules/backup/6.9.4-1-cachyos
+ rsync -AHXal --ignore-existing /usr/lib/modules/backup/6.9.4-1-cachyos /usr/lib/modules/
+ rm -rf /usr/lib/modules/backup
( 2/16) Arming ConditionNeedsUpdate...
( 3/16) Updating the MIME type database...
( 4/16) Updating module dependencies...
( 5/16) Install DKMS modules
( 6/16) Updating initramfs...
:: Building initramfs for linux-lts (6.6.34-1-lts)
dracut[E]: Module 'systemd-pcrphase' depends on 'tpm2-tss', which can't be installed
:: Building fallback initramfs for linux-lts (6.6.34-1-lts)
:: Building initramfs for linux-zen (6.9.5-zen1-1-zen)
:: Building fallback initramfs for linux-zen (6.9.5-zen1-1-zen)
( 7/16) Updating linux initcpios...
( 8/16) Foreign/AUR package notification
paru -Qi tpm2-tss
Version         : 4.0.1-1
Description     : Implementation of the TCG Trusted Platform Module 2.0 Software Stack (TSS2)
Architecture    : x86_64
URL             : https://github.com/tpm2-software/tpm2-tss
Licenses        : BSD
Groups          : None
Provides        : libtss2-esys.so=0-64  libtss2-fapi.so=1-64  libtss2-mu.so=0-64  libtss2-rc.so=0-64  libtss2-sys.so=1-64
                  libtss2-tctildr.so=0-64
Depends On      : curl  json-c  openssl  libjson-c.so=5-64
Optional Deps   : None
Required By     : fwupd  gnupg  libsecret  openconnect
Optional For    : gnutls  systemd
Conflicts With  : None
Replaces        : None
Installed Size  : 3.61 MiB
Packager        : Antonio Rojas <arojas@archlinux.org>
Build Date      : Sun 07 May 2023 04:36:50 AM CDT
Install Date    : Sat 18 May 2024 12:31:00 AM CDT
Install Reason  : Installed as a dependency for another package
Install Script  : No
Validated By    : Signature
Already have a thread on this. Basically just a warning that its trying to load a module that it can’t (TPM related). The warning is nothing to worry about, it is just being verbose.
You can omit the module to stop getting the error. Set up a configuration file in /etc/dracut.conf.d, for example with an editor like Micro:
sudo micro /etc/dracut.conf.d/omit-pcrphase.conf
Paste into the file:
omit_dracutmodules+=" systemd-pcrphase "
Save and exit the file, then regenerate the initramfs images.
sudo dracut-rebuild
I’ll do that, I forgot that was a thing haha.
