Kernel: 6.13.1-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=748fc83f-8edc-436a-a837-2ebf04b7a602 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
UEFI: American Megatrends v: 4021 date: 08/09/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
Speed (MHz): avg: 3593 min/max: 550/4851 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3593 2: 3593 3: 3593
4: 3593 5: 3593 6: 3593 7: 3593 8: 3593 9: 3593 10: 3593 11: 3593 12: 3593
13: 3593 14: 3593 15: 3593 16: 3593 bogomips: 121607
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia
v: 570.86.16 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none empty: DP-1,
DVI-D-1, DVI-D-2, HDMI-A-1 bus-ID: 04:00.0 chip-ID: 10de:1c82
Device-2: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: DP-4 empty: DP-2,
DP-3, HDMI-A-2, HDMI-A-3 bus-ID: 09:00.0 chip-ID: 10de:2504 class-ID: 0300
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
Monitor-1: DP-4 model: Samsung U32J59x serial: <filter> built: 2024 res:
mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 140 gamma: 1.2
max: 3840x2160 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.86.16 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
API: Vulkan v: 1.4.303 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2504
surfaces: wayland device: 1 type: discrete-gpu name: NVIDIA GeForce GTX
1050 Ti driver: N/A device-ID: 10de:1c82 surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 04:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
bus-ID: 09:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
lanes: 16 bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-5: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.4:6
chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
API: ALSA v: k6.13.1-zen3-1-zen status: kernel-api with: aoss
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168
IF-ID-2: wlp6s0f3u3i2 state: down mac: <filter>
Device-1: Realtek 802.11ac NIC driver: btusb,rtw_8821cu type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 0bda:c820
Local Storage: total: 11.83 TiB used: 2.55 TiB (21.6%)
fw-rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000VN004-3CP101
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
used: 640.23 GiB (68.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 40.5 C mobo: 41.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1039 fan-3: 0 fan-4: 857 fan-5: 2783
fan-6: 0 fan-7: 0
Memory: total: 32 GiB available: 31.25 GiB used: 4.02 GiB (12.9%)
Processes: 408 Power: uptime: 28m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2152 libs: 607 tools: octopi,pamac,paru,yay
pm: flatpak pkgs: 0 Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2024-09-28
Last full system update: 2025-02-08
tried this
lookandfeeltool --resetLayout --apply Dr460nized
Trying to change wallpaper
Trying to get new global theme
I can load Breeze Dark and get wallpaper in that global theme
