When I choose to install any theme with the checkboxes for design parameters and widget and window locations enabled, only the open System Settings window remains on the desktop. The theme itself, the desktop, desktop shortcuts, wallpaper, everything disappears, a black screen. If I close the Settings, there will just be a black background. If I set a background image, the system immediately freezes. So with any theme that is installed or downloaded. The applied theme will work after rebooting the computer.
I thought I was the only one with this. So I’m not alone, there are many of us. By the way, this is because of some updates. Because I booted from a bootable USB flash drive and everything was fine. And on the newly installed system, everything was fine too, until the 3GB update arrived after installation.
And it also annoys me that on some themes, and now it’s Breeze, when you open a window to the entire desktop, there are no close or minimize buttons in the corner of the window. But in the Dr460nized theme, if the window is not yet open to the full screen, then the open button is, for example, on the far right, but when the window is open to the full desktop, then the open button is already in the middle. As if they are swapped. Which is a little annoying.
Kernel: 6.13.1-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b78d0f32-bdb0-4fc2-9410-34dbd76a876b rw rootflags=subvol=@
loglevel=3 ibt=off
wm: kwin_wayland tools: avail: lxlock,xtrlock vt: 1 dm: SDDM Distro: Garuda
Type: Desktop System: Micro-Star product: MS-7B89 v: 1.0
Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
Megatrends LLC. v: 2.M0 date: 08/22/2024
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3603 min/max: 550/4208 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3603 2: 3603 3: 3603
4: 3603 5: 3603 6: 3603 7: 3603 8: 3603 9: 3603 10: 3603 11: 3603 12: 3603
bogomips: 86405
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
/ 6900 XT] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3,
Writeback-1 bus-ID: 28:00.0 chip-ID: 1002:73bf class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: Asus ML229 serial: <filter> built: 2012 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 103 gamma: 1.2
size: 475x267mm (18.7x10.51") diag: 545mm (21.5") ratio: 16:9 modes:
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21
LLVM 19.1.7 DRM 3.59 6.13.1-zen3-1-zen) device-ID: 1002:73bf
API: Vulkan v: 1.4.303 layers: 15 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 (RADV NAVI21) driver: N/A device-ID: 1002:73bf
bus-ID: 28:00.1 chip-ID: 1002:ab28 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: ASUSTek TUF GAMING H5/H7
lanes: 1 mode: 1.1 bus-ID: 3-4:5 chip-ID: 0b05:189c class-ID: 0300
API: ALSA v: k6.13.1-zen3-1-zen status: kernel-api with: aoss
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: enp3s0f0u9c4i2 state: down mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.47 TiB used: 987.62 GiB (65.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: AMD Radeon model: R5MP120G8
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: T1103F0L temp: 38.9 C
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN750 SE 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 711250WD temp: 34.9 C scheme: GPT
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
used: 15.96 GiB (14.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 430.66 GiB (92.5%) fs: btrfs dev: /dev/nvme1n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
System Temperatures: cpu: 36.2 C mobo: N/A gpu: amdgpu temp: 38.0 C
mem: 36.0 C
Memory: total: 16 GiB available: 15.54 GiB used: 4.28 GiB (27.5%)
Processes: 421 Power: uptime: 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
Packages: 1873 pm: pacman pkgs: 1846 libs: 546 tools: octopi,pamac,paru
pm: flatpak pkgs: 27 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2025-02-09
Last full system update: 2025-02-09
