Don’t enable HTTPS-Only Mode --Firedragon (Not Working)
  Kernel: 6.10.0-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=06ceeb9f-eb5d-400b-b1c9-1120b55c6af1 rw rootflags=subvol=@
  Desktop: Hyprland v: 0.41.2 with: waybar tools: avail: xautolock vt: 8
  Type: Laptop System: Hewlett-Packard product: HP EliteBook 840 G2
    v: A3009D510203 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 2216 v: KBC Version 96.56
    serial: <superuser required> part-nu: N0Y03UC#ABU uuid: <superuser required>
    UEFI: Hewlett-Packard v: M71 Ver. 01.09 date: 09/01/2015
  ID-1: BAT0 charge: 8.3 Wh (98.8%) condition: 8.4/8.4 Wh (100.0%) volts: 12.3
    min: 11.4 model: Hewlett-Packard Primary type: Li-ion serial: <filter>
    status: not charging
  Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1846 high: 2211 min/max: 500/2900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1762 2: 1204 3: 2210
    4: 2211 bogomips: 18358
  Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard ZBook 15u G2
    Mobile Workstation driver: i915 v: kernel arch: Gen-8 process: Intel 14nm
    built: 2014-15 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
  Device-2: Cheng Uei Precision Industry (Foxlink) HP EliteBook integrated
    HD Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 2-7:5 chip-ID: 05c8:0374 class-ID: 0e02
    compositor: Hyprland v: 0.41.2 driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model: AU Optronics 0x233e built: 2012 res: 1600x900
    dpi: 132 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1600x900
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
    HD Graphics 5500 (BDW GT2) driver: mesa intel v: 24.1.4-arch1.2
    device-ID: 8086:1616 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.1.4-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
    chip-ID: 8086:9ca0 class-ID: 0403
  API: ALSA v: k6.10.0-zen1-2-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e
    v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
  IF-ID-1: podman0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-2: veth0 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-3: veth1 state: up speed: 10000 Mbps duplex: full mac: <filter>
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:3 chip-ID: 8087:0a2a
    lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
    v: 3.0 port: 5060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 111.79 GiB used: 86.51 GiB (77.4%)
    model: WD1200BEVS-60UST0 size: 111.79 GiB block-size: physical: 512 B
    logical: 512 B speed: 1.5 Gb/s tech: N/A serial: <filter> fw-rev: 1A01
  ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
    used: 43.26 GiB (44.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 584 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3
  ID-3: /home raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
  ID-4: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
  ID-5: /var/tmp raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
  ID-1: swap-1 type: zram size: 11.56 GiB used: 1.08 GiB (9.4%)
  System Temperatures: cpu: 53.0 C mobo: N/A
  Memory: total: 12 GiB available: 11.56 GiB used: 5.71 GiB (49.4%)
  Processes: 254 Power: uptime: 1h 33m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 4.61 GiB services: upowerd Init: systemd
    v: 256 default: graphical tool: systemctl
  Packages: 1645 pm: pacman pkgs: 1623 libs: 440 tools: pacseek,paru
    pm: flatpak pkgs: 22 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi
    default: fish v: 3.7.1 running-in: tmux: inxi: 3.3.35
  System install date:     2024-05-09
  Last full system update: 2024-07-25 ↻
As stated, Firedragon is upgrading all my http connections https despite me toggling this option on. Testing it on Floorp works just fine.
Firedragon is my daily driver now and I really don’t wan’t my connections upgraded.
Good thing you tried with Floorp.
Maybe there is a config set that forces this.
Can you follow the step (3rd one) about the config files in this post and it should help narrow-down.
Are you saying you cannot reach ANYTHING that starts with http://?
I know I can, so maybe it’s not the config file but let’s try.
I can reach sites with http://, it is just that the connections are upgraded to https://.
The problem is that:
  1. When going to the history tab and loading what I was previously viewing… since its going to https://, I will have to edit the url again back to http:// actually access the link I wanted.
Doing this once is not a problem, but having to do it over and over again is kinda tiresome.
Will try your recommendation and see… later on
Hum, when I take an http:// in my history and load it, some automatically switch to https:// as well, but it still loads the page and some others (local instance of Whoogle) keep http:// and loads the page.
You could also try to Manage Exception in the HTTPS-Only Mode. Of course you can’t add every site but just 1 to see if that works.
Not sure if a Proxy can affect here but I guess most people don’t use one.
As far as I can tell HTTPS-Only-Mode is not forced only activated by default for all sites (see line here). And I tested it in a fresh profile, I was able to deactivate HTTPS-Only-Mode.
Additionally HTTPS-Only-Mode normally does not upgrade to HTTPS when it is not available, it will show a warning message and allows you to continue to HTTP (see docs here). To not see this message you can also permanently add it to the exception list, as described in the docs.
If this does not work, check that your /usr/lib/firedragon/firedragon.cfg is identical to upstream. Or try testing it in a fresh profile (about:profile).
I don’t know how to explain,… I tweaked my theme to suite my workflow. I would love to create a new profile but I am kinda occupied.
As you can see this is a locally hosted site on my machine. Since its been upgraded to https, I can not access it. I will be able to access it when I go back to http, but it will automatically upgrade it to https.
Tested on a different profile and it is fine. Its going to take a lot of time to switch to it. So I will mark this as the solution.
Thanks @FGD @stefanwimmer128
[quote=“Yada, post:6, topic:38288”]
Tested on a different profile and it is fine. Its going to take a lot of time to switch to it.[/quote]
This weird behavior with such a solution isn’t uncommon, I personally got hit by that as well, during testing months ago. For some reason the Profile got corrupted and yes it took a while to migrate to a new one from fresh, but in the end the problem never came back.
Others have experienced their own corruption and in many cases the new Profile fixed it. Which most probably explains why it worked on Floorp since it was a new Profile there.
