Hi everyone,
I’m currently facing an issue with my display setup on Garuda Linux. I have an NVIDIA RTX 2070 GPU with two monitors connected:
- HDMI → ASUS VG248 (1920x1080) – working fine
- DisplayPort → LG ULTRAGEAR (2560x1440 @ 120Hz) – no signal, not even detected
I’m using the proprietary NVIDIA 575.64 driver with Wayland (KDE Plasma). This exact hardware setup was working yesterday with both monitors, but after a reboot today, the DisplayPort monitor stopped working completely.
What changed:
- HDMI output still works
- The DisplayPort monitor is no longer listed in
xrandr - I tested the same DisplayPort cable and monitor on another machine → works fine
- I also deleted
~/.local/share/kscreen/configs and rebooted → no change
I also checked the KScreen output folder (~/.local/share/kscreen/outputs/) and noticed that no new config was generated for the DisplayPort output after rebooting.
This suggests that the system doesn’t detect the DisplayPort monitor at all — not even at the hardware enumeration level.
Here’s some info from my system:
❯ xrandr
Screen 0: minimum 16 x 16, current 4480 x 1440, maximum 32767 x 32767
DP-1 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 143.87*+
1920x1440 143.84
1600x1200 143.89
1440x1080 143.80
HDMI-A-1 connected 1920x1080+2560+180 (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 59.96*+
1440x1080 59.99
1400x1050 59.98
1280x1024 59.89
❯ echo $XDG_SESSION_TYPE
wayland
inxi -Gxx
Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Micro-Star MSI
driver: nvidia v: 575.64 arch: Turing pcie: speed: 8 GT/s lanes: 16 ports:
active: none off: DP-1,DP-3,HDMI-A-1 empty: DP-2 bus-ID: 01:00.0
chip-ID: 10de:1f02
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-6:3 chip-ID: 046d:0825
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR res: 2560x1440 hz: 144
dpi: 109 diag: 685mm (27")
Monitor-2: DP-3 model: Asus VG248 res: 1920x1080 dpi: 92 diag: 609mm (24")
Monitor-3: HDMI-A-1 model: Asus VG248 res: 1920x1080 hz: 60 dpi: 92
diag: 609mm (24")
API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: swrast
gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11:
drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
display-ID: :1.0
API: Vulkan v: 1.4.313 surfaces: N/A device: 0 type: discrete-gpu
driver: nvidia device-ID: 10de:1f02
❯ garuda-inxi
root=UUID=400c2f0d-8924-468c-8c78-7fcabce37e16 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.0 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Desktop Mobo: ASUSTeK model: TUF Z370-PLUS GAMING v: Rev X.0x
UEFI: American Megatrends v: 3004 date: 07/12/2021
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88796
driver: nvidia v: 575.64 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DP-1,DP-3,HDMI-A-1 empty: DP-2 bus-ID: 01:00.0 chip-ID: 10de:1f02
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 046d:0825
Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2020 res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: DP-3 model: Asus VG248 serial: <filter> built: 2017
res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: N/A
Monitor-3: HDMI-A-1 model: Asus VG248 serial: <filter> built: 2017 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
max: 1920x1080 min: 640x480
API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2070 driver: nvidia v: 575.64 device-ID: 10de:1f02
surfaces: N/A
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 1038:12ad class-ID: 0300
Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
Device-5: HP HyperX QuadCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:3
chip-ID: 03f0:0491 class-ID: 0300 serial: <filter>
API: ALSA v: k6.15.3-zen1-1-zen status: kernel-api tools: N/A
IF-ID-1: br-4b8d6c58f1ea state: down mac: <filter>
IF-ID-2: br-a353907cd0ad state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-e1202b148fe4 state: down mac: <filter>
IF-ID-4: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
IF-ID-5: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-6: veth441dacf state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: vethca43e7e state: up speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: NetworkManager, nginx, sshd, systemd-timesyncd
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.3.3:7 chip-ID: 2357:0604
Local Storage: total: 2.28 TiB used: 662.67 GiB (28.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000S1024G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK51.2 temp: 31.9 C
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 32.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: KIOXIA model: EXCERIA SATA SSD
tech: SSD serial: <filter> fw-rev: 15.5 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: OCZ model: TRION100 size: 223.57 GiB
serial: <filter> fw-rev: 11.2 scheme: GPT
used: 50.7 GiB (22.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 616 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 46.97 GiB used: 5 MiB (0.0%) priority: 100
System Temperatures: cpu: 37.0 C mobo: N/A
Memory: total: 48 GiB available: 46.98 GiB used: 6.57 GiB (14.0%)
Processes: 434 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.71 GiB services: org_kde_powerdevil,
Packages: 1680 pm: pacman pkgs: 1674 libs: 466 tools: octopi,paru
pm: flatpak pkgs: 6 Compilers: gcc: 15.1.1 Shell: garuda-inxi default: fish
v: 4.0.2 running-in: yakuake inxi: 3.3.38
System install date: 2024-11-04
Last full system update: 2025-06-24 ↻
Relevant software: timeshift NetworkManager dracut nvidia-dkms
