Displaylink installation fails
I'm trying to install Displaylink Linux driver for the Dell docking station by using Add/Remove Software app, and the installation gets stuck with the following error:
Preparing...
Cloning displaylink build files...
Checking displaylink dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building displaylink...
==> Making package: displaylink 5.4-1 (Fri 09 Apr 2021 10:22:53 PM PDT)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
  -> Found displaylink-driver-5.4.zip
  -> Found DISPLAYLINK-EULA
  -> Found udev.sh
  -> Found 99-displaylink.rules
  -> Found displaylink.service
  -> Found displaylink-sleep.sh
==> Validating source files with sha256sums...
    displaylink-driver-5.4.zip ... Passed
    DISPLAYLINK-EULA ... Passed
    udev.sh ... Passed
    99-displaylink.rules ... Passed
    displaylink.service ... Passed
    displaylink-sleep.sh ... Passed
==> Removing existing $srcdir/ directory...
==> Extracting sources...
  -> Extracting displaylink-driver-5.4.zip with bsdtar
==> Removing existing $pkgdir/ directory...
==> Entering fakeroot environment...
==> Starting package()...
Adding udev rule for DisplayLink DL-3xxx/5xxx devices
Installing DLM systemd service
Extracting DisplayLink Driver Package
/var/tmp/pamac-build-andrey/displaylink/src /var/tmp/pamac-build-andrey/displaylink/src
(xfce4-terminal:80092): dbind-WARNING **: 22:22:54.424: Couldn't register with accessibility bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
xfce4-terminal: Unknown option "-title"
==> ERROR: A failure occurred in package().
    Aborting...
Please help!
Did you search about this error?
How you install?
Read
please
and post
inxi -Fxxxza
as text! Even if you personally think it is unnecessary.
and
:slight_smile:
Thanks for the quick reply! I'm VERY new to Garuda (i've being using Linux Mint for several years), so I need some more guidance on how to post questions on this forum. After I read your comments, I still have questions:
  • Was a format (copied text and not a screen shot) of the error information correct?
  • Instead of posting my question here, do I have to send a Bug Report or the Reporting bugs should be done in addition to the post here?
How/where/what app do I need to use to get that information?
Thank you.
Like in Mint, terminal, maybe clear with #?
# inxi -Fxxxza
or
$ inxi -Fxxxza
or is this root?
Maybe must be more specific in wiki???
Please start with answers…
Yes, I did, but didn't find an answer.
I was using the Add/Remove Software app. I found Displaylink drivers there, ran installation that hot stuck in the middle with the error message I copied in my initial post here.
I wasn't using Terminal, I did it in Add/Remove Software.
As in, type this into terminal and post output.
and post the out put from inxi -Fxxxza
Did you search ... ?
Read
https://aur.archlinux.org/packages/displaylink
Yes, I've read, but I can't find answers there.
WTH you do not post the inxi?
Note: Displaylink 5.4 needs evdi 1.9. evdi 1.9.0 is NOT compatible with kernel >= 5.11.
I am out.
Someone on that site suggested to use the installer created for Ubuntu. I've tried it with a such result:
<pre>[[email protected] ~]$ sudo /home/andrey/Downloads/displaylink-driver-5.4.0-55.153.run
[sudo] password for andrey:
Verifying archive integrity...  100%   All good.
Uncompressing DisplayLink Linux Driver 5.4.0-55.153  100%
DisplayLink Linux Software 5.4.0-55.153 install script called:
Distribution discovered: &quot;Garuda Linux&quot;
Unsatisfied dependencies. Missing component: libdrm.
This is a fatal error, cannot install DisplayLink Linux Software.
</pre>
I am out.
Next time you use .exe or some macOS files?
But
never-give-up-03-sgs
I am out. I am out. I am out.I am out. I am out. I am out.
realy.
Solved! "This was fixed by running sudo pamac build displaylink instead of using the pamac GUI."
This topic is going nowhere. And as the user already decided to go to another distro, it is pointless to have this thread open.
