So, my laptop ran into low power and at 5% my laptop shutdown. After perfect charging i started garuda and all is fine except now laptop hasn't returned to normal state, the animations are not returned, the laptop is still in power saving mode I guess, I don't know how to revoke it please help me with it.
System settings > Energy Saving, then go from there.
Like Windoze, the app launcher has a search function on some DE's - type in 'power' and you'll find it.
Thanks for the suggestion, but I could not find apt tweaks for my problem in energy saving tab.can u further specify how would 1 do it
Search for pacman rosetta
You've given no system info as yet, the more details you do, the better.
Please provide output of inxi -Fxxza
System: Kernel: 5.10.15-120-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=16cfc4ee-6974-427d-bd6a-e7c18fbd10b1 rw [email protected] quiet splash
rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
Desktop: KDE Plasma 5.21.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IH_FA566IH v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506IH v: 1.0 serial: <filter> UEFI: American Megatrends v: FA506IH.314
date: 12/17/2020
Battery: ID-1: BAT1 charge: 41.2 Wh condition: 45.2/48.1 Wh (94%) volts: 12.3/11.7 model: ASUS A32-K55
type: Li-ion serial: N/A status: Discharging
CPU: Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600104 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71946
Speed: 1397 MHz min/max: 1400/3000 MHz boost: disabled Core speeds (MHz): 1: 1397 2: 1387 3: 1397
4: 1397 5: 1397 6: 1396 7: 1397 8: 1396 9: 1397 10: 1397 11: 1397 12: 1396
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA TU117M vendor: ASUSTeK driver: nvidia v: 460.39 alternate: nouveau,nvidia_drm
bus ID: 01:00.0 chip ID: 10de:1f99 class ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:1636 class ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 1-4:3
chip ID: 13d3:56a2 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: modesetting,nvidia
alternate: ati,fbdev,nouveau,nv,vesa display ID: :0 screens: 1
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.15-120-tkg-bmq LLVM 11.0.1) v: 4.6 Mesa 20.3.4
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 05:00.1 chip ID: 1002:1637 class ID: 0403
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 05:00.5 chip ID: 1022:15e2 class ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 05:00.6 chip ID: 1022:15e3 class ID: 0403
Sound Server: ALSA v: k5.10.15-120-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Lite-On
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000 bus ID: 03:00.0 chip ID: 10ec:c822
class ID: 0280
Bluetooth: Device-1: Lite-On Bluetooth Radio type: USB driver: btusb v: 0.8 bus ID: 3-1:2 chip ID: 04ca:4005
class ID: e001 serial: <filter>
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 476.94 GiB used: 38.8 GiB (8.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: P6MA001 temp: 40.9 C scheme: GPT
Partition: ID-1: / raw size: 80 GiB size: 80 GiB (100.00%) used: 38.78 GiB (48.5%) fs: btrfs
dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%) used: 25.8 MiB (10.1%) fs: vfat
ID-3: /home raw size: 80 GiB size: 80 GiB (100.00%) used: 38.78 GiB (48.5%) fs: btrfs
ID-4: /var/log raw size: 80 GiB size: 80 GiB (100.00%) used: 38.78 GiB (48.5%) fs: btrfs
ID-5: /var/tmp raw size: 80 GiB size: 80 GiB (100.00%) used: 38.78 GiB (48.5%) fs: btrfs
ID-1: swap-1 type: zram size: 619.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 619.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 619.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 619.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 619.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 619.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 619.4 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
Sensors: System Temperatures: cpu: 36.8 C mobo: N/A gpu: amdgpu temp: 35.0 C
Fan Speeds (RPM): cpu: 2200
Info: Processes: 304 Uptime: 10m wakeups: 1 Memory: 7.26 GiB used: 2.53 GiB (34.9%) Init: systemd v: 247
Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1214 lib: 323 Shell: fish v: 3.1.2
running in: konsole inxi: 3.3.01
greetings SGS
How would this help sir?
Maybe a misunderstanding...
What does apt
mean for you?
If it's about package search/install/upgrade, Arch/Garuda uses pacman
and Rosetta is a conversion table for apt users.
Apt meant appropriate sorry if it meant something else to you
I can't judge that because I don't know you but in general it helps if you know what you are doing and don't just take orders from others because it can also cause bad events.
Apt means appropriate.
Talk about misunderstanding.
On a serious note, you could try changing Plasma settings as was already suggested.
https://docs.kde.org/trunk5/en/kde-workspace/kcontrol/powerdevil/index.html
I found a way out, we need to enable compositor on startup an restart your pc to re enable regular behaviour of animations and layout s,
Btw Thanking to you all
