This morning, booted my computer, launched discord, lutris, and FFXIV (get in the login queue while i do some chores). It was taking a while to launch the game and discord, so I walked away to get started making coffee, feeding pets, and cleaning the kitchen. Normal Sunday morning stuff.
I came back to discord frozen on the desktop, unable to move the mouse... I spammed the keyboard a little, clicked a few times, moved the mouse and decided it was hopeless. I long pressed the power button.
I reboot to an empty latte dock, no top bar. Looks like my configuration was completely lost.
I found a similar post here (that i'm unable to locate again, of course) and tried some things from there, most notably, reset to a snapshot from December. Did not work
Kernel: 5.15.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5ed66716-13d2-4876-8c98-0563b45e4251 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F34
date: 06/10/2021
ID-1: hidpp_battery_0 charge: 73% condition: N/A volts: 3.9 min: N/A
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3948 high: 4286 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3733 2: 4219
3: 4169 4: 4238 5: 4178 6: 4110 7: 4162 8: 4249 9: 4163 10: 4258 11: 4127
12: 3462 13: 3469 14: 3535 15: 4012 16: 4006 17: 4196 18: 4133 19: 3584
20: 4106 21: 3764 22: 3474 23: 4270 24: 3797 25: 4024 26: 4222 27: 4286
28: 3549 29: 3563 30: 3637 31: 4171 32: 3482 bogomips: 223585
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 09:00.0
chip-ID: 10de:1e84 class-ID: 0300
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x342mm (47.4x13.5")
s-diag: 1252mm (49.3")
Monitor-1: DP-2 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DP-4 res: 2560x1440 hz: 60 dpi: 109
size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: YUAN High-Tech Development driver: N/A bus-ID: 05:00.0
chip-ID: 12ab:0380 class-ID: 0480
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:10f8
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487
Device-4: TC Electronic GoXLR type: USB driver: snd-usb-audio
bus-ID: 1-2:2 chip-ID: 1220:8fe0 class-ID: 0102
Device-5: Texas Instruments ATH-G1WL type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.3.2:7
chip-ID: 0451:16ba class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.11-zen1-1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 04:00.0 chip-ID: 8086:1539 class-ID: 0200
Local Storage: total: 3.66 TiB used: 790.41 GiB (21.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX6000PNP
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V9002s85
temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
model: WD20EARX-00ZUDB0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-1: / raw-size: 923.02 GiB size: 923.02 GiB (100.00%)
used: 338.95 GiB (36.7%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 498 MiB size: 497 MiB (99.79%)
used: 235.5 MiB (47.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 923.02 GiB size: 923.02 GiB (100.00%)
ID-4: /var/log raw-size: 923.02 GiB size: 923.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 923.02 GiB size: 923.02 GiB (100.00%)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4
ID-2: swap-2 type: zram size: 31.35 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 27.0 C mobo: 26.0 C gpu: nvidia temp: 40 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 23%
Processes: 578 Uptime: 3m wakeups: 2 Memory: 31.35 GiB
used: 4.08 GiB (13.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2015 lib: 524 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
