Hi all,
I’m having a graphical glitch with the icons on the dock, as well as the icons on the top right of the screen (i.e., the Bluetooth, network, notification, etc. icons). The issue happens when I hover my mouse over the icons, which results in the icons disappearing from their place, and overlapping on the left side of the dock. On the top right they simply disappear. I recorded my screen to show you an example: https://imgur.com/a/RLVDLXU. I am running Garuda KDE Dr460nized, and the issue occurs both on X11 and on Wayland.
I am having difficulties debugging the issue. I tried to search for other people with the same problem, but could not find any similarities. I tried switching to a different global theme but the issue persists. Is anyone here able to help me fix it, or point me in the right direction? Your help would be very much appreciated !
Below the output of garuda-inxi
Kernel: 6.10.3-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=d44c4f9d-e788-4ec7-8db2-42293d5d7690 rw rootflags=subvol=@
resume=UUID=423495b1-65c6-47ae-a96b-770cb2856fb0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: Gigabyte model: Z690 AORUS ELITE DDR4 v: x.x serial: N/A
uuid: 035e02d8-04d3-0532-a706-5d0700080009 UEFI: American Megatrends LLC.
v: F5 date: 12/17/2021
Info: model: 12th Gen Intel Core i7-12700K socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake gen: core 12 level: v3 note: check
built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151)
stepping: 2 microcode: 0x35
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 1095 high: 4809 min/max: 800/4900:5000:3800
base/boost: 3600/8500 scaling: driver: intel_pstate governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800
6: 800 7: 4809 8: 800 9: 2070 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 1424 19: 800 20: 800 bogomips: 144383
Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
alternate: xe arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: none empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0380
Device-2: NVIDIA GA104 [GeForce RTX 3060 Ti] vendor: Micro-Star MSI
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2,DP-3 empty: DP-4,HDMI-A-3
bus-ID: 01:00.0 chip-ID: 10de:2486 class-ID: 0300
Device-3: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11.3:9
chip-ID: 1b3f:2247 class-ID: 0102 serial: <filter>
Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
alternate: fbdev,intel,nv,vesa dri: iris gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 4480x1440 s-dpi: 92 s-size: 1237x402mm (48.70x15.83")
s-diag: 1301mm (51.21")
Monitor-1: DP-2 mapped: DP-0 note: disabled pos: primary,right
model: Idek Iiyama PL2760Q serial: <filter> built: 2019 res: 2560x1440
dpi: 123 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 685mm (27")
Monitor-2: DP-3 mapped: DP-2 note: disabled pos: left
model: Philips PHL 241B7Q serial: <filter> built: 2018 res: 1920x1080 hz: 60
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 555.58.02 device-ID: 10de:2486
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD
Graphics 770 (ADL-S GT1) driver: mesa intel v: 24.1.6-arch1.1
device-ID: 8086:4680 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.6-arch1.1 (LLVM
Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.10.3-zen1-2-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: n/a (root, process) with:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 1-11.2.3:10 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.96 TiB used: 1.13 TiB (38.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 32.9 C
SMART: yes health: PASSED on: 160d 3h cycles: 3,846
read-units: 91,840,005 [47.0 TB] written-units: 70,711,299 [36.2 TB]
model: WD10EZEX-60M2NA0 family: Blue size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 1A01 temp: 31 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 143d 13h cycles: 5604
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
family: based SSDs size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 2B6Q temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 342d 21h cycles: 5577
written: 17.9 TiB
ID-4: /dev/sdc maj-min: 8:32 vendor: HGST (Hitachi) model: HTS721010A9E630
family: Travelstar 7K1000 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: A3J0 temp: 28 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 236d 10h cycles: 10139
ID-1: / raw-size: 914.28 GiB size: 914.28 GiB (100.00%)
used: 592.05 GiB (64.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 914.28 GiB size: 914.28 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 914.28 GiB size: 914.28 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 914.28 GiB size: 914.28 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.39 GiB used: 2.68 GiB (17.4%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20
ID-2: swap-2 type: partition size: 16.94 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 36.0 C mobo: 29.0 C gpu: nvidia temp: 51 C
Memory: total: 16 GiB available: 15.39 GiB used: 5.34 GiB (34.7%)
Processes: 498 Power: uptime: 3h 41m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2254 libs: 598 tools: octopi,pamac,paru pm: rpm
pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13
Shell: garuda-inxi (sudo) default: Bash v: 5.2.32 running-in: konsole
inxi: 3.3.35
System install date: 2023-04-03
Last full system update: 2024-08-19 ↻
