Hey, i've got the issue that my desktop doesn't load sometimes, which means sometimes i need to reboot directly after i started the computer in order for me to use my main display ( i got two )
There was a post that kinda had the same problem, but as far as i've read it was resolved after restoring via timeshift ( or now btrfs assistant ), but the problem always has been there for me, just recently it became much more common and now i've already restarted my pc before i've gone to the garuda forum, and i'm annoyed about it not starting; the "broken" desktop does not feature any click-feedback, the files that are on the "broken" desktop don't appear on the second one, but on the folder "Desktop" they're still there, there's a photo of both my displays:
inxi follows:
Kernel: 5.18.0-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=59fb3e2d-83c0-4365-a80b-433fb57039f2 rw rootflags=subvol=@
resume=UUID=07dd9dba-6b0e-4958-8a6d-b047eca29fdd loglevel=3
Type: Desktop Mobo: Micro-Star model: B450-A PRO MAX (MS-7B86) v: 4.0
serial: <superuser required> UEFI: American Megatrends LLC. v: M.F1
date: 03/22/2022
Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2591 high: 2995 min/max: 1400/4268 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2809 2: 2560
3: 2391 4: 2394 5: 2991 6: 2398 7: 2994 8: 2389 9: 2394 10: 2394 11: 2995
12: 2393 bogomips: 86246
STIBP: always-on, RSB filling
Device-1: NVIDIA GM204 [GeForce GTX 970] driver: nvidia v: 515.43.04
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Maxwell pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 10:00.0 chip-ID: 10de:13c2 class-ID: 0300
Device-2: Logitech Webcam B500 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1:2 chip-ID: 046d:0807 class-ID: 0102 serial: <filter>
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: DVI-I-1 pos: right res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
v: 4.6.0 NVIDIA 515.43.04 direct render: Yes
Device-1: NVIDIA GM204 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 10:00.1
chip-ID: 10de:0fbb class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.1 chip-ID: 1002:1637
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6 chip-ID: 1022:15e3
Device-4: Logitech Webcam B500 type: USB driver: snd-usb-audio,uvcvideo
Device-5: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 0c76:161e
Sound Server-1: ALSA v: k5.18.0-zen1-1-zen running: yes
lanes: 1 port: e000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 3.64 TiB used: 760.2 GiB (20.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
type: SSD serial: <filter> rev: 041 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Silicon Power
model: SPCC Solid State Disk size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 9A0
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST500LX005-1CW162
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LVD1
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-1: / raw-size: 221.04 GiB size: 221.04 GiB (100.00%)
used: 59.76 GiB (27.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 221.04 GiB size: 221.04 GiB (100.00%)
ID-4: /var/log raw-size: 221.04 GiB size: 221.04 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.04 GiB size: 221.04 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 25.0 C mobo: 28.0 C gpu: nvidia temp: 37 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1341 fan-3: 1628 fan-4: 1142
fan-5: 1027 fan-6: 0 gpu: nvidia fan: 50%
Processes: 312 Uptime: 11m wakeups: 0 Memory: 15.58 GiB
used: 3.81 GiB (24.5%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1361 lib: 339 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.16
e[1;34mGaruda (2.6.3-2):e[0m
e[1;34m System install date:e[0m 2022-04-20
e[1;34m Last full system update:e[0m 2022-05-29
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m bluetooth-autoconnect.service
