Greetings!
I've been using Garuda Linux KDE Plasma on my Slimbook Pro2 since June, and enjoying the experience.
Since my last system update (with paru), the Desktop Cube Animation has disappeared from System Settings and I no longer can select it.
What is going on? Has it been permanently removed from Plasma? I hope not, because this is my favourite desktop animation to switch between desktops.
Congrats for the distribution and keep up the good worl!
Here's the output of inxi -Faz:
Kernel: 5.14.12-zen1-1-zen x86_64 bits: 64 compiler: gcc
v: 11.1.0
root=UUID=d5cf848f-e572-44fb-b6ea-20af2b408956 rw
rootflags=subvol=@ quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
Desktop: KDE Plasma 5.23.0 tk: Qt 5.15.2 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Type: Laptop System: SLIMBOOK product: PRO v: N/A
Mobo: SLIMBOOK model: PRO serial: <filter>
UEFI: American Megatrends v: 1.05.08 date: 10/27/2017
ID-1: BAT0 charge: 30.0 Wh (100.0%)
condition: 30.0/36.5 Wh (82.3%) volts: 12.9 min: 11.4
model: Notebook BAT type: Li-ion serial: <filter>
status: Full
Info: Quad Core model: Intel Core i7-8550U bits: 64
type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: A (10) microcode: EA cache:
L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
vmx
bogomips: 31999
Speed: 3840 MHz min/max: 400/4000 MHz Core speeds (MHz):
1: 3840 2: 3477 3: 3575 4: 4001 5: 3945 6: 3589 7: 3891
8: 4001
Vulnerabilities: Type: itlb_multihit
status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache
flushes, SMT vulnerable
Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
Type: spectre_v2 mitigation: Full generic retpoline, IBPB:
conditional, IBRS_FW, STIBP: conditional, RSB filling
Device-1: Intel UHD Graphics 620 vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: Chicony Chicony USB2.0 Camera type: USB
driver: uvcvideo bus-ID: 1-4:2 chip-ID: 04f2:b59e
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11
driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 1600x900 s-dpi: 96
s-size: 423x237mm (16.7x9.3") s-diag: 485mm (19.1")
Monitor-1: eDP1 res: 1600x900 hz: 60 dpi: 140
size: 290x170mm (11.4x6.7") diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 21.2.4 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl
Sound Server-1: ALSA v: k5.14.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit
Ethernet
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: e000
bus-ID: 3a:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp58s0f1 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi
v: kernel bus-ID: 3b:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
Device-1: Intel Bluetooth wireless interface type: USB
driver: btusb v: 0.8 bus-ID: 1-5:3 chip-ID: 8087:0a2b
Report: bt-adapter ID: hci0 rfk-id: 0 state: up
address: <filter>
Local Storage: total: 1.02 TiB used: 54.59 GiB (5.2%)
SMART Message: Unable to run smartctl. Root privileges
required.
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate
model: ST1000LM035-1RK172 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
model: WDS120G1G0B-00RC30 size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 1000 scheme: GPT
ID-1: / raw-size: 52.7 GiB size: 52.7 GiB (100.00%)
used: 44.88 GiB (85.2%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18
used: 576 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
used: 9.71 GiB (16.6%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-4: /var/log raw-size: 52.7 GiB size: 52.7 GiB (100.00%)
maj-min: 8:18
ID-5: /var/tmp raw-size: 52.7 GiB size: 52.7 GiB (100.00%)
maj-min: 8:18
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 31.23 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 55.0 C mobo: N/A
Processes: 291 Uptime: 1h 42m wakeups: 2 Memory: 31.23 GiB
used: 3.73 GiB (11.9%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 2044
lib: 565 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.07
