Hello,
I’m a bit new to Linux so bare with me.
Been experiencing crashes where my desktop would black screen, shut down all apps and processes, and behave as though I just turned on my PC and logged in. I am unsure how to reproduce it as it seems to occur randomly whenever I do some sort of action, such as copying and pasting, using the snipping tool, opening a Steam game, etc.
I’ve tried simply rebooting, updating my system, changing kernels, removing/changing widgets in the panel config, but nothing seemed to work.
Using journalctl and information from https://forum.garudalinux.org/t/desktop-randomly-restarts/45812, it has something to do with either plasmashell or the compositor.
I still do not know what causes them to crash or how to fix it however, so any help will be appreciated.
Kernel: 6.18.5-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
avail: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux
root=UUID=c9882c61-f15e-42bd-b25c-e3238d7b50d4 rw rootflags=subvol=@ quiet loglevel=3
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0 wm: kwin_wayland vt: 1
Type: Desktop System: Micro-Star product: MS-7C56 v: 6.0 serial: <superuser required> Chassis:
type: 3 v: 6.0 serial: <superuser required>
Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0 serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC. v: A.L1
date: 09/19/2025
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check
built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 0
microcode: 0xA201030
Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4100 min/max: 561/4654 boost: enabled scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 4100 2: 4100 3: 4100 4: 4100 5: 4100 6: 4100 7: 4100 8: 4100
9: 4100 10: 4100 11: 4100 12: 4100 bogomips: 88796
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Device-1: NVIDIA GB205 [GeForce RTX 5070] driver: nvidia v: 590.48.01
alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as of 2025-11)
arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s
lanes: 16 link-max: gen: 5 speed: 32 GT/s ports: active: DP-1,DP-2,DP-3 empty: HDMI-A-1
bus-ID: 2b:00.0 chip-ID: 10de:2f04 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9 compositor: kwin_wayland
driver: X: loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: nv_platform,nvidia,nvidia-nvswitch d-rect: 7680x1440 display-ID: 0
Monitor-1: DP-1 pos: center model: Dell S2721DGF serial: <filter> built: 2022 res:
mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-2: DP-2 pos: primary,left model: Viewteck FI24D built: 2019 res: mode: 2560x1440 hz: 75
scale: 100% (1) dpi: 123 gamma: 1.2 size: 530x290mm (20.87x11.42") diag: 604mm (23.8")
Monitor-3: DP-3 pos: right model: Dell S2417DG serial: <filter> built: 2018 res:
mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 123 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 2560x1440 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.3-arch1.2 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 5070/PCIe/SSE2 memory: 11.66 GiB display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 14 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 5070
driver: nvidia v: 590.48.01 device-ID: 10de:2f04 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.3-arch1.2 (LLVM 21.1.6)
gpu: nvidia-settings,nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GB205 High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 link-max: gen: 5 speed: 32 GT/s bus-ID: 2b:00.1 chip-ID: 10de:2f80
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4
chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Yeti X driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:7 chip-ID: 046d:0aaf class-ID: 0300
Device-4: FiiO K3 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-9:6 chip-ID: 2972:0047 class-ID: fe01
API: ALSA v: k6.18.5-arch1-1 status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:24fd class-ID: 0280
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.3:4 chip-ID: 8087:0a2b class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 4.2 lmp-v: 8 status: discoverable: no
pairing: no
Local Storage: total: 3.18 TiB used: 768.09 GiB (23.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS100T2B0C size: 931.51 GiB
fw-rev: 211210WD temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 990 EVO Plus 2TB size: 1.82 TiB
block-size: physical: 512 B logical: 512 B speed: 126 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 2B2QKXG7 temp: 35.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 020
ID-1: / raw-size: 465.47 GiB size: 465.47 GiB (100.00%) used: 77.48 GiB (16.6%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 664 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 465.47 GiB size: 465.47 GiB (100.00%) used: 77.48 GiB (16.6%) fs: btrfs
ID-4: /var/log raw-size: 465.47 GiB size: 465.47 GiB (100.00%) used: 77.48 GiB (16.6%)
ID-5: /var/tmp raw-size: 465.47 GiB size: 465.47 GiB (100.00%) used: 77.48 GiB (16.6%)
ID-1: swap-1 type: zram size: 31.26 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
System Temperatures: cpu: 54.8 C mobo: N/A
Memory: total: 32 GiB available: 31.26 GiB used: 4.85 GiB (15.5%)
Processes: 409 Power: uptime: 0m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.46 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 259
Packages: 1398 pm: pacman pkgs: 1342 libs: 353 tools: gnome-software,octopi,paru pm: flatpak
pkgs: 56 Compilers: gcc: 15.2.1 Client: Unknown Client: electron inxi: 3.3.40
Garuda (2.12.3-2):
System install date: 2025-10-19
Garuda release: 251002
Last full system update: 2026-01-16
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
25/26 checks run in 0.75 seconds ⌛
Powered by garuda-health 🦅
