Hello everyone,
Its my first ever post here on Garuda so please be patient if i make some mistakes.
I noticed that there is an issue on my DE, at random times it restarts like if you logout and login again, but without restarting the autostart applications that i have configured.
I tried to check the journalctl or even the logs that Garuda provides for debug purposes but without any result that could point to me what could be bothering the DE.
Could you please help me out and help me solve this issue?
Please find my garuda-inxi below
Kernel: 6.16.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=8e9eff86-6dc1-4902-983e-1010b0748257 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Laptop System: LENOVO product: 82EY v: IdeaPad Gaming 3 15ARH05
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ARH05
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_82EY_BU_idea_FM_IdeaPad Gaming 3 15ARH05
uuid: <superuser required> UEFI: LENOVO v: FCCN18WW date: 04/14/2022
ID-1: BAT0 charge: 26.2 Wh (69.9%) condition: 37.5/45.0 Wh (83.4%)
volts: 11.7 min: 11.4 model: SMP L19M3PF7 type: Li-poly serial: <filter>
status: not charging cycles: 55
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
microcode: 0x860010D
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1673 min/max: 1400/3000 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 1673 2: 1673 3: 1673
4: 1673 5: 1673 6: 1673 7: 1673 8: 1673 9: 1673 10: 1673 11: 1673 12: 1673
bogomips: 71867
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nvidia v: 580.76.05 alternate: nouveau,nvidia_drm
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
off: HDMI-A-1 empty: none bus-ID: 01:00.0 chip-ID: 10de:1f95
Device-2: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 50.0 C
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 13d3:56ff
class-ID: 0e02
gpu: amdgpu,nv_platform,nvidia,nvidia-nvswitch d-rect: 4480x2520
display-ID: 0
Monitor-1: HDMI-A-1 pos: top-right model: Samsung LS32CG51x
serial: <filter> built: 2022 res: mode: 2560x1440 hz: 144 scale: 100% (1)
dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
Monitor-2: eDP-1 pos: bottom-l model: ChiMei InnoLux 0x15e7 built: 2016
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11:
drv: radeonsi inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.5
renoir ACO DRM 3.64 6.16.4-zen1-1-zen) device-ID: 1002:1636
API: Vulkan v: 1.4.321 layers: 15 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.1-arch1.5
device-ID: 1002:1636 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 Ti driver: nvidia v: 580.76.05
device-ID: 10de:1f95 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.1-arch1.5 (LLVM
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.16.4-zen1-1-zen status: kernel-api with: aoss
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw88_8822ce v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:c822 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 0bda:c123
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 476.94 GiB used: 196.99 GiB (41.3%)
model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: AL2QFXV7 temp: 44.9 C scheme: GPT
used: 196.99 GiB (41.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.17 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 60.6 C mobo: N/A gpu: amdgpu temp: 50.0 C
Memory: total: 64 GiB note: est. available: 62.17 GiB used: 8.62 GiB (13.9%)
Processes: 428 Power: uptime: 23m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.8 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1925 libs: 571 tools: octopi,paru Compilers:
clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.0.2
Garuda (2.8.2-2):
System install date: 2025-08-24
Last full system update: 2025-09-03
22/23 checks run in 0.77 seconds ⌛
Powered by garuda-health 🦅
Thank you all in advance
