Hello,
Only recently did a clean/fresh Garuda install.
Now, I'm unable to update due to the following message:
Dependency resolution failed:
libicui18n.so=70-64 <- thunderbird-appmenu, libicuuc.so=70-64 <- thunderbird-appmenu: could not satisfy dependencies
Output for garuda-inxi is below:
Please advise.
Kernel: 5.17.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=6d358332-1121-46d2-a2c5-bd235a269b18 rw rootflags=subvol=@
resume=UUID=c06ef7ff-534a-46d8-a0e0-a3052b377e5f loglevel=3
Type: Laptop System: LENOVO product: 20X7005AUS v: ThinkPad L15 Gen 2a
Mobo: LENOVO model: 20X7005AUS serial: <superuser required> UEFI: LENOVO
v: R1KET36W (1.21 ) date: 11/25/2021
ID-1: BAT0 charge: 42.2 Wh (94.6%) condition: 44.6/45.7 Wh (97.6%)
volts: 12.3 min: 11.1 model: SMP LNV-5B10W13896 type: Li-poly
serial: <filter> status: not charging cycles: 8
Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2681 high: 4415 min/max: 1600/4505 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2099 2: 1914
3: 1915 4: 3255 5: 3984 6: 4415 7: 2009 8: 2541 9: 3124 10: 2431 11: 2969
12: 2971 13: 1714 14: 1397 15: 3345 16: 2822 bogomips: 60687
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3
active: DP-2,HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 07:00.0
chip-ID: 1002:1638 class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-2:2
chip-ID: 5986:212b class-ID: 0e02
Screen-1: 0 s-res: 3000x2160 s-dpi: 96 s-size: 791x570mm (31.14x22.44")
s-diag: 975mm (38.38")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,top-left
model: Samsung serial: <filter> built: 2009 res: 1920x1080 dpi: 305
gamma: 1.2 size: 160x90mm (6.3x3.54") diag: 184mm (7.2") ratio: 16:9
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-r model: HP E223
serial: <filter> built: 2017 res: 1080x1920 hz: 60 dpi: 102 gamma: 1.2
size: 268x476mm (10.55x18.74") diag: 546mm (21.5") ratio: 16:9 modes:
Monitor-3: eDP-1 mapped: eDP pos: primary,middle-l
model: AU Optronics 0x2e8d built: 2019 res: 1920x1080 hz: 60 dpi: 142
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.3-zen1-1-zen)
v: 4.6 Mesa 22.0.1 direct render: Yes
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
snd_pci_acp6x, snd_sof_amd_renoir
bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
Device-4: C-Media USB Advanced Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1.3.1:6
chip-ID: 0d8c:0021 class-ID: 0300
Sound Server-1: ALSA v: k5.17.3-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8852 class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 6-1.1:3 chip-ID: 0bda:8153 class-ID: 0000
IF: enp7s0f4u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 5-4:3 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 87.5 GiB (18.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X081N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41720C20
temp: 40.9 C scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
used: 19.54 GiB (20.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 580 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 358.77 GiB size: 358.77 GiB (100.00%)
used: 67.96 GiB (18.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4
ID-4: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
maj-min: 259:3
ID-5: /var/tmp raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
maj-min: 259:3
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 14.53 GiB used: 3.03 GiB (20.8%)
System Temperatures: cpu: 54.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): fan-1: 3475
Processes: 428 Uptime: 3d 18h 20m wakeups: 3 Memory: 14.53 GiB
used: 11.74 GiB (80.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1890 lib: 553 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-04-06
Last full system update: 2022-04-15
