Davinci Resolve keypresses are blocked / not registered
Hi I just installed davinci resolve through the davinci resolve website and ran the installer. At first Davinci wouldnt open, due to some unsupported packaged, so i found this guide on how to fix that: Blackmagic Forum • View topic - DaVinci Resolve will not Launch on Linux
That fixed one issue, but now I have another. When open davinci and create a new project, I can give the project a name with my physical keyboard. Note that this is done outside of the ig studio window. When I open the project and lets say add a video, then want to remove it by clicking on it and pressing backspace my keypress is not recognized. The same goes for when I want to rename anything in the studio window. I am using the dr460nized kde desktop environment and the tool window up top contains an option for search. When i click this and start typing my keyboard inputs are recognized, but as still not in the studio window.
Additionally when I try to use Resolve as a floating window, I can not resize it.
Lastly any super (meta / windows) keypresses / keybinds dont do anything if Resolve is my focussed application.
I believe there might be an issue with how the program is being opened. If i try to launch Resolve as sudo, I get an error stating the program is not found, however I can still open it from the apps overview, just not terminal.
I was unable to find any other people with the same issue as me. There was one guy who ran Resolve as sudo to fix a problem with keypresses and / or audio, but this remains unresolved: DaVinci Resolve - Either keypresses won't work or audio won't work
If there is any additional information or logs I should provide please let me know.
P.s. I at first tried to use Octopi to install Resolve, but that took 2,5h. I probably did something wrong there as well. Anyone else got this insanely long installation from Octopi?
Edit: no programs’ main windows seem to be recognizing keypresses if Resolve is open, tho the super key did work after first opening the app overview and then closing it with super.
Yep, please post your garuda-inxi as requested by the template. :wink:
It is not a good idea to install applications from a website on Arch/Archbased Linux distributions. Almost all available applications can be found in the official repositories or in the AUR (Arch User Repository).
And this idea is even worse…
davinci-resolve is in the AUR, you already found it there via octopi:
This has nothing to do with octopi - it takes so long because it is not a precompiled binary, but because it is compiled/built from the source code.
We generally advise against using gui tools like octopi to install packages (but they are good for searching). To install packages you should generally use pacman in the terminal, or an AUR-helper like paru to install AUR packages.
You should first try the AUR version and check if it works better than the version from the website:
paru -S davinci-resolve
And if you are using wayland, switch to an x11 session (login screen → button bottom left) and check if davinci-resolve works without isues.
Thanks for your response and helpful comments! Learn something everyday.
As for the garuda-inxi:
Kernel: 6.14.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=72b0eb66-9e98-4294-81e8-de152b212690 rw rootflags=subvol=@
quiet resume=UUID=05cbfdf1-7239-489f-b25d-643523880371 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.13.0
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
UEFI: American Megatrends v: 3611 date: 09/29/2024
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA500011
Speed (MHz): avg: 2393 min/max: 400/4673 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 2393 2: 2393 3: 2393
4: 2393 5: 2393 6: 2393 7: 2393 8: 2393 9: 2393 10: 2393 11: 2393 12: 2393
13: 2393 14: 2393 15: 2393 16: 2393 bogomips: 121607
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 570.144
alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current (as
of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
off: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2216
d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-2 pos: bottom-l model: MSI MAG342CQR serial: <filter>
built: 2023 res: mode: 3440x1440 hz: 144 scale: 100% (1) dpi: 111 gamma: 1.2
size: 797x333mm (31.38x13.11") diag: 864mm (34") modes: max: 3440x1440
min: 640x480
Monitor-2: HDMI-A-1 pos: top-right model: LG (GoldStar) 2D FHD TV
serial: <filter> built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 96 gamma: 1.2 size: 509x286mm (20.04x11.26") diag: 584mm (23")
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 9 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 570.144 device-ID: 10de:2216
Device-1: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aef
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:1637 class-ID: 0403
lanes: 16 bus-ID: 0c:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: RODE Microphones AI-1 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2
chip-ID: 19f7:000a class-ID: 0300 serial: <filter>
API: ALSA v: k6.14.5-zen1-1-zen status: kernel-api with: aoss
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0
IF: enp10s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7.2:6 chip-ID: 8087:0029
Local Storage: total: 2.75 TiB used: 68.4 GiB (2.4%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 233010WD temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 3L1QEXF7 temp: 29.9 C scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
scheme: MBR
ID-1: / raw-size: 896.97 GiB size: 896.97 GiB (100.00%)
used: 68.4 GiB (7.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.97 GiB size: 896.97 GiB (100.00%)
ID-4: /var/log raw-size: 896.97 GiB size: 896.97 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.97 GiB size: 896.97 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.13 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.25 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.6 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.13 GiB used: 5.44 GiB (17.5%)
Processes: 436 Power: uptime: 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.38 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1912 libs: 590 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date:     2025-04-04
Last full system update: 2025-05-10
When I run
I get an error:
:: Downloading PKGBUILDs...
PKGBUILDs up to date
nothing new to review
fetching devel info...
==> Making package: davinci-resolve 19.1.4-2 (Sun May 11 08:19:45 2025)
==> Retrieving sources...
-> Downloading DaVinci_Resolve_19.1.4_Linux.zip...
curl: (3) URL rejected: Bad file:// URL
==> ERROR: Failure while downloading file://DaVinci_Resolve_19.1.4_Linux.zip
Aborting...
error: failed to download sources for 'davinci-resolve-19.1.4-2':
error: packages failed to build: davinci-resolve-19.1.4-2
Which if it’s looking on my local machine makes sense as that file isn’t there, but if I’m not mistaken this is looking on the AUR servers(?).
Thanks again for the help so far, I’m really glad so far this community has provided helpful and meaningful responses even though I’m a bit of a nooby (:
Ask the developer please or check the PKGBUILD file
