Hey, I’ve run into an odd issue where if I go either of the two routes, I want to fix one or the other, but can’t find the way this should be done, so I’m wondering if anyone has ever heard of this issue before.
So AUR’s DaVinci package has been patchy, needed to remove some files to get it to run, but when inside the editor - Issue 1 - None of the keyboard shortcuts work to change tools, delete or copy.
If I were to open in DaVinci in console with sudo, I don’t have the same projects saved, but at least keypresses work! Issue 2 - I don’t have any audio.
Route 1 oddly registers me ctrl + mouse zooming the timeline and when checking the ‘Keyboard Customization’ menu with the keyboard layout and various shortcuts I could assign… pressing keys makes the respective icon light up. So the Application knows I’m pressing something, but won’t act on it.
The differences I’ve spotted is that with a regular launch DaVinci actually uses the top panel with all the KDE Window Buttons, Global context menu (File, edit, view etc) and I could resize the window. With a sudo launch the window buttons disappear, so I couldn’t close the application that way, but the context menu appears lower on its own line, as if it ignored KDE panels. Then it feels almost like now the window is fully focused.
If I were to try and search how I could possibly fix Route 2 and always sudo launch the application, then what frequently run into is PulseAudio vs PipeWire. I can’t get Pulseaudio-alsa, because it’s in conflict with pipewire-alsa and don’t know if I should try removing one for the other if the install came with PipeWire. Even if someone recommends that I still swap out pipe for pulse, is it normal to be opening the console and running the app with sudo?
I guess here’s the ‘garuda-inxi’ -
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=e40a9440-1b35-4ce3-9a5a-e98f781acac6 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop System: Micro-Star product: MS-7D78 v: 1.0
Mobo: Micro-Star model: PRO B650-P WIFI (MS-7D78) v: 1.0
Megatrends LLC. v: 1.40 date: 03/24/2023
Device-1: wacom_battery_0 model: Wacom Intuos Pro M serial: N/A charge: 100%
Info: model: AMD Ryzen 7 7700 bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4727 high: 5352 min/max: 400/5582 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5345 2: 5344 3: 5349
4: 400 5: 5337 6: 5342 7: 5352 8: 5348 9: 5347 10: 5350 11: 5346 12: 400
13: 5340 14: 5348 15: 5349 16: 5341 bogomips: 121597
Device-1: AMD Navi 32 [Radeon RX 7700 XT / 7800 XT] vendor: Tul / PowerColor
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-2 empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:747e class-ID: 0300
Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: Writeback-2
bus-ID: 12:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 47.0 C
gpu: amdgpu,amdgpu d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-2 pos: top-right res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 17.0.6 DRM 3.57 6.9.3-zen1-1-zen) device-ID: 1002:747e
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:747e surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 24.1.1-arch1.1 device-ID: 1002:164e
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM 17.0.6)
Device-2: AMD Rembrandt Radeon High Definition Audio
speed: 16 GT/s lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.4:9
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: up mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
Device-2: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:6 chip-ID: 0e8d:0616
Report: ID: hci1 rfk-id: 1 state: up address: <filter> bt-v: 5.2 lmp-v: 11
status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 5.2 TiB used: 2.43 TiB (46.7%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QJXD7 temp: 44.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
tech: SSD serial: <filter> fw-rev: 2B6Q
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: B1C2 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SHSS37A240G
tech: SSD serial: <filter> fw-rev: 00.Y scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD20PURX-64P6ZY0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 80.86 GiB (36.2%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
used: 27 MiB (28.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-5: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.51 GiB used: 1.93 GiB (6.3%)
System Temperatures: cpu: 61.1 C mobo: 48.0 C
GPU: device: amdgpu temp: 48.0 C device: amdgpu temp: 53.0 C mem: 68.0 C
fan: 0 watts: 51.00
Memory: total: 32 GiB note: est. available: 30.51 GiB used: 9.36 GiB (30.7%)
Processes: 387 Power: uptime: 1d 11h 23m states: freeze,mem,disk
reboot, suspend, test_resume image: 12.19 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1489 libs: 425 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-05-11
Last full system update: 2024-06-14
