Hi, I am amazed by garuda linux and installed it on a laptop I have however I want to ask some questions before finalizing my choice.
I have the Dragonized Distro installed on my laptop (core i7-8565u, integrated graphics), and noticed my cpu temps run high (one chromium tab open and I'm sitting at 46 degrees celsius). Or is there another distro that has a similar nice look like dragonized that I can switch to that isn't intensive.
If Dragonized Garuda requires more resources, does this mean installing this distro on my main gaming pc (ryzen 6 2600x, rtx 2060) will affect the performance I have while gaming?
46° celsius is a normal temp in use
by the way you said nothing how high is your core usage ^^
on mobile devices i have to change garuda dragonized to cpucontrol to have better performance in battery mode and set there the frequencies governor to ondemand it fits for me best
and design is also a temp riser more style means always more cpu power
FWIW, This is on Fedora 34. 46* isn't so bad, no matter how your keyboard feels. This is an older computer though, I probably need to redo the thermal paste.
