.Hi there I'm an old newb, loving Garuda wayfire well I was after it took me all-day to find it has a second installer. Clicked on connman it opened I connected to my wifi.All good .I then did some updates on the software. Then my Wi-Fi vanished, I click on connman now and nothing it won't open. I also can not right click on any programs it dosnt work. As I'm using my phone I have no idea how I can post cmd results. Thanks inadvance.
There's a rollback feature for a reason.
Use it, then make a note of which packages are updated.
There is what's it called please. Like I said I'm newb
Reboot, then the grub boot menu will appear.
Select a prior timeshift snapshot from the "advanced" sub-menu.
There’s a wiki link at the top of the page, and on the wiki is this:
This isn’t really an excuse.
Not sure what's happening it seems as if the messages from other members are not coming through until I reboot my phone. OK thanks for your help I will keep trying the snapshots until I get one that has the Wi-Fi. Thanks I will also read the restore link. Cheers
Fantastic thanks everyone.Wifi is back Now how can I prevent this happening again. ?Connman still won't open. But Wi-Fi is connected at the top .right click still dose not open any programs.Ctrl + C and Ctl + v are not working either its been like this from first install 3 days ago.
Check journal for errors of the previous date/time
https://wiki.archlinux.org/index.php/Systemd/Journal#Filtering_output
I have the list you asked for but as ctrl + c and ctrl +v isnt working i can not share it .right click copy isnt working to .can you give me a cmd please to copy this log.
Use Ctrl+Shift+C for copy after select the text (in alacritty?)
A
inxi -Fxxxza
is best to let now the helpers what you use and read the hardware specs.
And read also
Ok thanks that works fine i have the inxi i try to copy the results with ctrl+shift +c but it wont copy.
You mean paste?
It need then in other places / software
Ctrl+V
IDK what wayfire use but it seems buggy some times.
Maybe @librewish can help?
Ok so ctlrl + shift + c works then ctrl +v thanks again .
.%;888:8898898: josieslovemuscle@tufgamingfa506iifx506ii
x;XxXB%89b8:b8%b88: ----------------------------------------
.8Xxd 8X:. OS: Garuda Linux x86_64
.8Xx; 8x:. Host: TUF Gaming FA506II_FX506II 1.0
.tt8x .d x88; Kernel: 5.10.4-107-tkg-bmq
.@8x8; .db: xx@; Uptime: 1 hour, 38 mins
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@;
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Packages: 1125 (pacman)
,888S pd! Shell: zsh
8X88/ q Resolution: 1920x1080
GBB. Terminal: xterm-256color
x%88 d888@8@X@X@X88X@@XX@@X@8@X.
dxXd dB8b8b8B8B08bB88b998888b88x. CPU: AMD Ryzen 7 4800H with Radeon Graphics (16) @ 2.9GHz
dxx8o .@@;. Memory: 3079MiB / 15484MiB (19%)
dx88 .t@x.
d:SS@8ba89aa67a853Sxxad.
.d988999889889899dd.
~ 0.85 2% 10.85G 0B at 10:38:10 AM ─╮
❯ inxi -Fxxxza 36% 78 Mbps ─╯
System: Kernel: 5.10.4-107-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=e5b3e8d3-9f39-4813-a196-ca33c5ef8ddd rw rootflags=subvol=@ quiet splash
rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
Desktop: N/A dm: N/A Distro: Garuda Linux
Machine: Type: Laptop System: ASUSTeK product: TUF Gaming FA506II_FX506II v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506II v: 1.0 serial: <filter> UEFI: American Megatrends v: FA506II.309
date: 07/02/2020
Battery: ID-1: BAT1 charge: 13.9 Wh condition: 38.8/48.2 Wh (81%) volts: 3.4/11.9 model: ASUS A32-K55
type: Li-ion serial: N/A status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600104 L2 cache: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92708
Speed: 1397 MHz min/max: 1400/2900 MHz boost: disabled Core speeds (MHz): 1: 1397 2: 1398 3: 1414
4: 2500 5: 1402 6: 1569 7: 1721 8: 1520 9: 1397 10: 1397 11: 1461 12: 1281 13: 1427 14: 1386
15: 1576 16: 1607
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] driver: nouveau v: kernel bus ID: 01:00.0
chip ID: 10de:1f95
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:1636
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 1-4:2
chip ID: 13d3:56a2 serial: <filter>
Display: wayland server: X.Org 1.20.99.1 compositor: wayfire driver: amdgpu
note: n/a (using device driver) display ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3") s-diag: 583mm (23")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 144 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.4-107-tkg-bmq LLVM 11.0.0) v: 4.6 Mesa 20.3.2
direct render: Yes
Audio: Device-1: NVIDIA driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10fa
Device-2: Advanced Micro Devices [AMD/ATI] vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 05:00.1 chip ID: 1002:1637
Device-3: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 05:00.5 chip ID: 1022:15e2
Device-4: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.10.4-107-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000 bus ID: 03:00.0 chip ID: 10ec:c822
IF: wlan0 state: up mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 9.48 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AB size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: ECFK52.3
temp: 38.9 C
Partition: ID-1: / raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 9.48 GiB (2.0%) fs: btrfs
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%) fs: vfat
ID-3: /home raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 9.48 GiB (2.0%) fs: btrfs
ID-4: /var/log raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 9.48 GiB (2.0%) fs: btrfs
ID-5: /var/tmp raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 9.48 GiB (2.0%) fs: btrfs
ID-1: swap-1 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
ID-13: swap-13 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram12
ID-14: swap-14 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram13
ID-15: swap-15 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram14
ID-16: swap-16 type: zram size: 967.8 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram15
Sensors: System Temperatures: cpu: 44.2 C mobo: N/A
GPU: device: nouveau temp: N/A device: amdgpu temp: 44.0 C
Info: Processes: 357 Uptime: 1h 38m wakeups: 1 Memory: 15.12 GiB used: 4.3 GiB (28.4%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: pacman: 1125 lib: 292 Shell: Zsh v: 5.8
running in: alacritty inxi: 3.2.01
~ took 4s 0.84 2% 10.84G 0B at 10:38:19 AM ─╮
❯ 36% 39
IDK nothing about but what you want to install?
If you use terminal
sudo pacman -S connman
what is the output then?
Could be you must use -gtk for wayfire???????
But again, IDK about ![]()
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd-udevd[459]: nvme0n1p1: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devic>
Jan 05 01:37:28 tufgamingfa506iifx506ii kernel: r8169 0000:02:00.0 enp2s0: renamed from eth0
Jan 05 01:37:28 tufgamingfa506iifx506ii mtp-probe[552]: checking bus 3, device 3: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-2"
Jan 05 01:37:28 tufgamingfa506iifx506ii mtp-probe[552]: bus: 3, device: 3 was not an MTP device
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Starting Load/Save Screen Backlight Brightness of leds:asus::kbd_backlight...
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd-udevd[441]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Started Load/Save RF Kill Switch Status.
Jan 05 01:37:28 tufgamingfa506iifx506ii audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="system>
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Finished Load/Save Screen Backlight Brightness of leds:asus::kbd_backlight.
Jan 05 01:37:28 tufgamingfa506iifx506ii audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:asus>
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skip>
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Condition check resulted in First Boot Complete being skipped.
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Starting systemd-guest-user.service...
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
lines 1266-1290
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jan 05 01:37:28 tufgamingfa506iifx506ii kernel: EDAC amd64: F17h_M60h detected (node 0).
Jan 05 01:37:28 tufgamingfa506iifx506ii kernel: EDAC amd64: Node 0: DRAM ECC disabled.
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Starting Load/Save RF Kill Switch Status...
Jan 05 01:37:28 tufgamingfa506iifx506ii kernel: usbcore: registered new interface driver usbhid
Jan 05 01:37:28 tufgamingfa506iifx506ii kernel: usbhid: USB HID core driver
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd-udevd[463]: Using default interface naming scheme 'v247'.
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd-udevd[463]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd-udevd[459]: nvme0n1p1: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devi>
Jan 05 01:37:28 tufgamingfa506iifx506ii audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="syste>
Jan 05 01:37:28 tufgamingfa506iifx506ii audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:asu>
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being ski>
lines 1266-1290
lines 1266-1290
lines 1266-1290
lines 1266-1290
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd-udevd[463]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writabl>
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd-udevd[459]: nvme0n1p1: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/dev>
Jan 05 01:37:28 tufgamingfa506iifx506ii audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="syst>
Jan 05 01:37:28 tufgamingfa506iifx506ii audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:as>
Jan 05 01:37:28 tufgamingfa506iifx506ii systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being sk>
lines 1266-1290
-- Journal begins at Tue 2021-01-05 01:37:27 ACDT, ends at Wed 2021-01-06 09:50:50 ACDT. --
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: Linux version 5.10.4-107-tkg-bmq (linux-tkg-bmq@archlinux) (gcc (GCC) 10.2.0, GNU ld (GNU Binu>
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: Command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq root=UUID=e5b3e8d3-9f39-4813-a196-ca33c>
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: KERNEL supported cpus:
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: Intel GenuineIntel
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: AMD AuthenticAMD
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: Hygon HygonGenuine
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: Centaur CentaurHauls
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: zhaoxin Shanghai
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-provided physical RAM map:
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009bfefff] usable
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-e820: [mem 0x0000000009bff000-0x0000000009ffffff] reserved
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20cfff] ACPI NVS
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-e820: [mem 0x000000000a20d000-0x00000000ab672fff] usable
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-e820: [mem 0x00000000ab673000-0x00000000acb8cfff] reserved
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-e820: [mem 0x00000000acb8d000-0x00000000acbddfff] ACPI data
Jan 05 01:37:27 tufgamingfa506iifx506ii kernel: BIOS-e820: [mem 0x00000000acbde000-0x00000000acd8efff] ACPI NVS
lines 1-25
Read
please.
Thanks so much for your help i have now installed connman UI seems to work fine i can open my WiFi settings and connect to my phone hotspot.This is strange now i double left click it wont open in the tray,or from the menu .Now i understand why because connman ui was minimized ,you cant open it when its already open lol.
.But i still cant right click to open other programs so when i go to firefox instead of right clicking on the icon then open in a private window i cant.?
