Hello.
Referring to this post, which is quite helpful, but as I tried opening Reflector Simple and get a list of mirrors, all of them timed out, or were forbidden, or read operation timed out in some cases
System Info (inxi)
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=4e4f1661-daaa-48b5-83ea-ed183be4bc11
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Acer product: Nitro AN515-44 v: V1.04 serial: <filter>
Mobo: RO model: Stonic_RNS v: V1.04 serial: <filter> UEFI: Insyde v: 1.04 date: 02/04/2021
Battery: ID-1: BAT1 charge: 57.9 Wh (100.0%) condition: 57.9/57.5 Wh (100.7%) volts: 17.6 min: 15.4
model: LGC AP18E8M type: Li-ion serial: <filter> status: Full
CPU: Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600103 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71862
Speed: 2711 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 2711 2: 3090
3: 1540 4: 1397 5: 1397 6: 1396 7: 1396 8: 2244 9: 2369 10: 1393 11: 2074 12: 1398
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA TU117M vendor: Acer Incorporated ALI driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Renoir vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus-ID: 05:00.0
Device-3: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 3-3:2 chip-ID: 04f2:b64f
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.14-zen1-1-zen LLVM 12.0.1) v: 4.6 Mesa 21.2.4
direct render: Yes
Audio: Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10fa
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Acer Incorporated ALI
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:2600 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0 chip-ID: 8086:2723
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2 chip-ID: 8087:0029
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Drives: Local Storage: total: 476.94 GiB used: 11.72 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530 SDBPNPZ-512G-1014
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21103900 temp: 45.9 C scheme: GPT
Partition: ID-1: / raw-size: 149 GiB size: 149 GiB (100.00%) used: 11.69 GiB (7.8%) fs: btrfs
dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 1 GiB size: 1021 MiB (99.61%) used: 27.9 MiB (2.7%) fs: vfat
ID-3: /home raw-size: 149 GiB size: 149 GiB (100.00%) used: 11.69 GiB (7.8%) fs: btrfs
ID-4: /var/log raw-size: 149 GiB size: 149 GiB (100.00%) used: 11.69 GiB (7.8%) fs: btrfs
ID-5: /var/tmp raw-size: 149 GiB size: 149 GiB (100.00%) used: 11.69 GiB (7.8%) fs: btrfs
ID-1: swap-1 type: zram size: 7.14 GiB used: 512 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 49.8 C mobo: N/A gpu: amdgpu temp: 40.0 C
Info: Processes: 343 Uptime: 4m wakeups: 1 Memory: 7.14 GiB used: 2.74 GiB (38.3%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1283 lib: 307
My question is, can we setup our own mirror for packages via reverse proxy?
like on cloudflare worker maybe.
Or any other solutions?
while i also tried in Konsole:
╭─lostb053@lostb053 in ~ took 6s
✦ [🔴] × sudo reflector --latest 15 --age 2 --fastest 20 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
error: failed to retrieve mirrorstatus data: timeout: The read operation timed out
